Question about Kitchen Ranges
Broken bracket holding handle to oven door - Kitchen Ranges
  • Molsie Oct 17, 2008
    What solution? KitchenAid Superba Model KECO-375MS - so far I've gotten NO information and more confusion. Help Me or refund.
    Genius:
  • 3,422 Answers
HI,
Can you please give me the make and model no. of your oven so that i can help you find a replacement handle.
I will be waiting for your reply.
Posted on Oct 17, 2008
    Genius:
  • 1,847 Answers
Give me the model No# and the make, will check for the spare part.
    Genius:
  • 1,550 Answers
You need to provide brand name and model number .
Need to replace door handle
1. Unplug microwave oven or disconnect power. 2. Open the microwave oven door. 3. Pry the choke cover away from the top door pin, and remove the top pin from the pivot bracket. Lift the door off the bottom bracket, and remove it. 4. Place the oven door front side down on a padded surface. 5. Remove the choke screws from the door frame. 6. Starting at the top right corner, pry the choke cover out with a putty knife, and unsnap it from the choke. Only remove the top, bottom and right sides of the choke cover at this time. You will remove the handle end of the choke cover later. 7. Starting at the top edge of the door near the center and working clockwise, use a putty knife, and pry the latching tabs of the choke out of the door frame slots. Lift the choke as you release the tabs so they do not snap back into the slots. NOTE: When you reach the handle side of door, pull both the choke and the choke cover away from the door frame, and then separate the two components. 8. To remove the door switch actuators from the choke, remove the screw from each actuator. REASSEMBLY NOTE: When you reinstall the door on the oven, insert the top pin into the pivot bracket and press down on the pin until it snaps into place
Read more: http://www.appliancepartspros.com/whirlpool-microwave-door-handle-w10246505-ap4418092.html#qa1#ixzz2qpA2P5CA
Jan 17, 2014 | Whirlpool MH3184XP Microwave Oven
Removing glass from whirlpool oven door
I've removed all the screws that I can see. Looks like the brackets that hold on the handle are keeping the whole thing from coming apart, but the brackets are behind the glass and the screws enter from the inside meaning that I will have to remove the glass to be able to remove the handle.
Resource: http://b2b.lovemyhome.net/
Nov 06, 2012 | Ovens
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Interior door handle is broken in saab 93s how do you fix problem
I'VE GOT A SIMPLE SOLUTION TO THIS PROBLEM!
August 16, 2012
My Mother-in-law has a 2004 Saab 9-3 convertible, she wasn't able to find a fix for this problem because the plastic bracket that holds the door cable in place on the inside of the door panel broke off and it's actually part of the door panel itself. Since the bracket broke, pulling on the inside door handle would no longer pull the cable that's need to open the door.
She was out of luck and had to roll the window down to use the outside door handle to exit the car (that gets annoying really fast).
Basically without rigging it, she would've needed a replacement door panel because of this ridiculos design flaw (around $600 + installation if you could even find the panel, she couldn't because Government Motors SUCKS!) .
I simply used an L bracket that I had (can find it at any Home Depot, Lowe's etc.) and used two sets of channel lock pliers to bend it into a "squared" J shape. I then drilled 2 holes into the inside metal door frame and used 2 sheet metal screws to secure the bracket to the door frame. To make sure that I mounted the new and improved bracket that I created in the proper location (not too much or too little slack). I simply made a template with a sheet of paper by tracing where the old molded plastic bracket was in relation to the two screw holes of the door panel ( actually had to mount the bracket about an inch forward to make up the difference since the bracket is no longer attached to the door panel).
I also had to drill the **** in the bracket a bit to make sure the cable wouldn't get hung up on it when pulled, but in all it only took 15 mintues to redesign GM's crappy design.
Here are 2 pictures, hope this will solve your issue with your broken handle.
Jan 09, 2010 | 2008 Saab 9-3
Outside glass dooor on Whirlpool oven fell off, what do i do?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Sep 15, 2009 | Whirlpool MH1150XM Convection/Microwave...
LG LMV1650ST handle falling off and needs to be replaced
The lower door handle bracket broke and I'm trying to find out how to replace it. I already have the new bracket.
Jun 23, 2009 | LG LMV1650ST Microwave Oven
2001 Ford Explorer Sport
Common problem on 2001 Ford Explores. The reason why your door handle doesn't unlock the door(can't be unlocked by remote either)is due to a broken spring located on the backside of the door handel INSIDE the door. True that your one(or two) of your small exterior springs on your door handle are broken(will cause your handle to flap) but this IS NOT YOUR PROBLEM. The door locks will work if there is a bit of tension holding the handle bracket up. I know it's hard to explain without pics. but here's the ONLY WAY TO FIX THIS. It's not that hard.......... Remove the door panel, only a few screws and a few more holding trim around exit handle then, pull out "snap in" clips on bottom. With a flashlight you'll see back side of door handle. To get to that area you'll have to remove one bolt holding a window frame. Do that(with window in up position) then slide down rail, out of your way. Now, get back to handle. With your light aimed at the backside of handle left slowly the door handle as normal, and you'll realize(while looking at the mechanism) that tension(pulling down of bracket) needs to occur in order for locks(manual and remote)to work properly. Trust me.....you'll figure it out. Once you do, get a spring(pen spring, 30 cent hardware store spring, any small spring!) and hook one end to bracket and the other end to ANYTHING(OUT OF THE WAY) below the door handle thus, causing SLIGHT tension. Try your locks...THEY WILL WORK! YEAH! Replace that one window frame bolt(try your window...just the make sure), replace door panel and your done. TOTAL COST: 30 cents or FREE(if you have a small spring) Ford dealers will charge $150 to $285! Yikes!
Jan 08, 2009 | 2001 Ford Explorer
Maytag electric range door handle (how to replace?)
The above solution is fine, but you don't have to remove the door.  Open the storage drawer for access to the trim screws (3) on the bottom of the door, remove the screws.  Have a helper hold the glass along the bottom. Take the three screws on the top of the door trim out.  Slide out the glass and put in a safe place.  Remove the four screws that hold the handle brackets in place, remove the handle (or tighten if loose). Install the new handle (one screw on each side).  Reinstall all parts in the reverse order of disassembly.  The entire job took less than 30 minutes.
May 01, 2007 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
110 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
