Question about Roper REX4634KQ Electric Dryer
Not dring Clothes are in the barrel spins, open the door and it feels hot inside my glasses steam up. But the clothes are not drying they are staying moist WHY? I cleaned out the machine and the lint flu but the clothes are not drying for some reason ...can anyone help Please .
  • Technosavy May 11, 2010
    Is there hot air coming out the exhaust vent while drying?
    Scholar:
  • 147 Answers
The air is not getting out of the dryer. Your vent hose is crimped or cloged or the flapper outside the house is stuck.. Air is not getting out of the dryer thru the vent for what ever reason.
Posted on Oct 21, 2008
My dryer gets hot but doest dry my clothes i lifted the top and spun the barrell around and noticed that the seal is torn could that be the cause
Sounds like a belt problem with no clothes in the dryer turn the dryer on for a minute or so open the door if the drum is spinning it not belt if drum is not spinning it's more that likely the belt that turns the drum.also need to check the exhaust hose in back of dryer it could have a blockage check lint screen also.Hope this helps.
Oct 20, 2016 | Dryers
I have a GE dryer that won't dry our clothes. It heats up, but water is all over the inside door and the lint that comes out of the hose in the back is wet! The outside of the dryer (the top in...
It really sounds like your washing machine is not spinning the clothes out enough. Have they been wetter than usual lately? The dryer could just be struggling to keep up with the heavier / wetter load as there is no reason for it to create moisture on it's own.
Oct 06, 2010 | GE Dryers
Dryer does not dry clothes but seems to be hot inside when i open the door
Most of these guys get a bad blower wheel. The heat melts the hub causing it to spin free and airflow is reduced. This makes it take fifty forevers to dry a load of clothes. More Here
Aug 18, 2010 | Crosley Dryers
Dryer is hot when opened, but takes 3 or 4 timed cycles to get clothes dry on very dry setting and timed setting
Check for a restriction in exhaust system,not just behind unit but all the way to outside vent,should feel warm decent airflow at outside vent.If not all you will end up with is warm moist clothes,You need good airflow to take away the moisture in the clothes not just heat.This issue can happen slowly over time and next thing you know its taking two or three times longer to dry even though when you open the door its hot inside.
Good luck
Aug 08, 2010 | Amana Dryers
The dryer door always pops open stopping the dryer... how do I make it stay shut so the clothes will get dry without having to close the door every other minute?
Try putting less of a load in dryer. The weight of the clothes riding against the door, may be the reason why it pops open.
Apr 05, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
AF Code flashes briefly; Clothes don't dry - vent clear
Remove the back of the dryer and chek the lint filter area from the lint catching filter to the exhaust tube. There is a blockage in airflow even though you feel the air at the exhaust there still insn't enough air flow to allow the proper drying of the clothes. This symptom that you gave clothes being hot but not dry the only cause for this is improper air flow
Dave
Mar 31, 2010 | Dryers
Clothes wont dry but gets really hot
make sure your exhaust line is clear and not kinked
Oct 24, 2008 | Washing Machines
Hello, sounds like your cold water feed hose has got a kink in it. The machine needs cold water to condense the steam. Just pull out the machine and slowly slide back into place.
Oct 21, 2008 | Hotpoint Aquarius WD63 Front Load...
Not drying
I know you cleaned the lint vent but your vent hose is clogged or damaged and there is no air exchange thru the dryer Air can only hold 100% humidity. You could dry your clothes for 10 hours but the air in the dryer is saturated with water and can not hold anymore so your clothes wont dry. Check behind your dryer and Ill bet the vent line is damaged. The problem is the air is not getting out of the dryer. Check the flapper at the end of the vent line. With the dryer running go to the end of the vent hose and there will be no air coming thru.
Oct 15, 2008 | Roper REX4634KQ Electric Dryer
Drying cycle
Is the drying fan rotating(you should hear this)? Or the watertap closed. It uses cold water to make the steam into condense. If tap is closed, the machine has no water to cool the steam with. Check lint filter.
Jan 22, 2008 | Candy CNW156 Front Load Washer / Dryer
Roper REX4634KQ Electric Dryer Logo
138 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Roper Dryer Expert? Answer questions, earn points and help others
