Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
Uplate the power is on but no picture, cant change channel, cant use menu
  • Zenith Master
  • 5,138 Answers
Replace tuner.
Posted on Dec 12, 2008
There is no picture on screen i can turn the power on and off thats all i can do i cant change the channel go to menu or anything else
Is the audio coming from the TV's internal speakers, or from an external sound system? In the 169 series chassis, if the power supply caps or secondary rectifier are bad, or if the high voltage splitter has shorted inside, the set will not run and there will be no picture or sound from the TV. If the picture is completely black but the TV still has audio, press the menu button and see if the menu comes up on the screen. If the menu is there, check your cables on the back of the TV. If you are using a cable or satellite box, the box could be bad or the video wire could be bad or loose. If you do not get the on-screen menu, then I would guess that the solder joint next to the flyback transformer that sends filament (heater) voltage up to the picture tubes has cracked, or the low value resistor in the heater circuit has opened up. If that is the case, have the set serviced by a qualified tech familiar with the 169 series chassis.
Oct 15, 2008 | Televison & Video
Dont have the remote control cant turn to channel 3 or 4 dont have a menu button
Isn't there a channel Up/Dn button at the front panel of this TV. It should be there. Only Menu button is not. There is Ch up ' Ch Dn and Vol Up ' Vol Dn buttons, beside a power button. Even pressing the channel Up ' Dn button, the channels cannot be changed, check the micro switches inside the TV. Replace them all at one time. You ave to open the TV to access these components.
Aug 02, 2012 | Sylvania 6719DF 19" TV/VCR/DVD
The tv worked fine. The tv is on but it is not showing any picture it wont even show me the menu. what do i do?
Try reconnecting the wire from the cable box, or satallite, to the tv, if not try giving it a good wack
May 06, 2012 | Hitachi 50VG825 TV
My admiral tv 32 inc goj12390 dont have the remote control and i cant see the dvd on tv scren beacause is only on chanel 3, 4 and i can put it on aux or imput
This worked for my Admiral TV model GRD15272:
Using the buttons on the TV, go to the setup menu, and scroll to "editchannels" by pressing "setup" button until "edit channels" ishighlighted. Then, using the channel up/down buttons, go to channel 91and press + volume. This should add the video input2_bing.gif to your channels. 92 is S-video. It is helpful to have what ever device (dvd player or game console) hooked up and powered on, so you know when you are on the right channel, but it should be 91.
Mar 08, 2010 | Televison & Video
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Sanyo Flat screen
try to check the settings of your tv if all ok. if ok its a problem in your TV circuit board try to resolder maybe some sections is cold solder. if not its a service mode. trust me!
May 20, 2009 | Sanyo DP26648-R 26 in. LCD TV
PICTURE CHANGES SIZE
turn off auto format setting in user menu
Oct 06, 2008 | RCA D61W20 61" Rear Projection Television
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
ESA ET413E LOST INSTRUCTION MANUAL, NO SELECT KEY!
when picture is displayed on your tv after pressing menu,press the channel up/down button on the remote or tv. there can also be a button that shifts right to left. this may hilight the the settings you want to change. if the up/down button scrolled you thru the settings, then the right/left buttons should change the settings.
hope it works
wg
Jan 27, 2008 | ESA ET413E 13" TV
Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
