Question about Toshiba Satellite M45-S165 Notebook
New RAM and Computer won't Boot
I purchased 2 Dimms of 1GB RAM and installed them in my computer. Now the system wont boot up. I can access the BIOS and Boot Menu but it keeps giving me the screen to chose safe mode or normal (No option works, it just freezes up) Any idea how RAM could hose my system like this? How can I fix it?
Thank you.
  • Fred May 11, 2010
    I used to have a dell and it was the same thing i replaced the memory with an upgrade and it will not boot up just beep. it might be propriatary, meaning that you might have to acquire the memory thru
    Toshiba rather than a PNY or any other generic memory card. If you reinstall your old memory does it boot normal?
    Master:
  • 461 Answers
Try booting with just one module inserted, then switch to just the other to see if the problem is with one of the new DIMMs. Does it still work fine with the old RAM?
Posted on Jan 16, 2009
I purchased 2 GB chips to try to increase the speed of my desktop. After putting in the chips my computer won't boot back up, my monitor is black and the computer is making a constant beeping nois
OK. First, I'm assuming that you have a Dell Vostro 200 as per the topic title. That said, you machine has a maximum memory capacity of 4GB. So, if you added the 2 - 2GB DIMMS in slots 3 and 4, leaving your original memory in the machine, you will have problems. You must be using DDR2 667 or 800 MHz RAM and the two DIMMS must be in slots DIMM1 and DIMM2 ( closest to the processor). No more than that can be installed.
Apr 03, 2012 | Dell Vostro 200 PC Desktop
I have an IBM Netvista A30p that I am trying to upgrade the memory in. It currently has 640mb and I am trying to go to 2GB. I have 2 1GB dimms to install but it will not boot with them. It will not boot...
are the modules of the same brand and type
make sure the sockets and ram modules are dust and corrosion free and are securely seated
you might swap each module over then reboot one might be faulty
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
    hope this helps
  • Nov 17, 2011 | IBM NetVista A30p PC Desktop
    Having a problen installing 1gb ram. unit is 1gb ddr2 dimm 533mhz. computer turns on, shows that it has updated the memory, but does not boot
    if the computer states that the memory has been recognised. but fails to boot. it may not be compatable memory for your CPU/Processor. Or system bus. check your previous memory stick, to ensure it,s the same running speed 533mhz. Failing this if your computer does not support this.
    check the manufacturers website, to see further details:- Maximum supported memory/Speed et,c.
    Systems bios date, and whether an update is available. your only other alternative is to install 2 x 512mb sticks of Ram.
    Mike @ compurepair.
    Jun 11, 2009 | HP Compaq dc7600 Small Form Factor PC...
    PC wont boot
    It seems that one of your DIMM slots on your mobo has conked out, sorry pardner but might have to end up changing the entire mobo. Also try out your old RAM sticks on another PC for confirmation.....sodeep
    Apr 05, 2009 | HP Pavilion m7640n PC Desktop
    Dell Latitude D600 - RAM not recognized
    One of the DIMMS might be incompatible or faulry.
    Put one DIMM in at a time to determine which is not working.
    If they both work separately then it appears they are incompatible together. Try to get the DIMMs from the same manufacturer, with the same specs.
    Mar 08, 2009 | Dell Latitude D600 Notebook
    Install memory not showing total only half
    Hey,
    it should show in the bios as 2048.
    looking at the details of the motherboard
    Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 2 x DIMMs Supported RAM speeds 400 MHz
    Got the right speed ram etc?
    Thanks,
    Ekse
    Feb 20, 2009 | Computers & Internet
    ASUS A8N5X Unresponsive after RAM Upgrade
    Just to verify, are you certain the new DIMMS are unbuffered? That MB does not support buffered DIMMS.
    If so, try to install the old ones in A1 and B1 and the new ones in A2 and B2. See if it will boot. If so, check your system to see if the total RAM is being "seen". Comment back.
    Dec 13, 2008 | ASUS A8N5X Motherboard
    P4m800-m7 Rev:3.1 RAM PROBLEM!
    the problem is with the new ram.
    its phsically damged.
    may be little bit that you cant see it.
    try checking the other 1GB ram.
    Nov 08, 2008 | EliteGroup P4M800-M7 Motherboard
    Cant boot up Computer- Memory address line failure
    From the failures its probably a RAM memory problem , which means that you should try a different ram module that is working , or if possible try the ram module of this pc in another one thats working.
    Aug 30, 2007 | Dell OptiPlex GX110 PC Desktop
    Toshiba Satellite M45-S165 Notebook Logo
    77 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
