Question about Acer Computers & Internet
How to hide or eliminate boot selection on Acer Veriton s460...there wasn't any security selection in the computer BIOS?? thanks
  • 128 Answers
When you turn on your computer, certain application,drivers,services are automatically started at the beginning of every window session. you can disable certain application to shorten your computer's booting process by the following steps:
click Start then Run and type "msconfig" (without the qoute) then click OK
there would appear a System Configuration Utility window. On the upper portion, select the Startup button. there you will see the applications that are started during bootup. you can unmark the check box in front of an entry to disable it and the program will not be started the next time you start windows. just be careful to choose the programs that you do not need to start automatically. some applications are needed by windows in order to start successfully.After doing so, click Apply then Ok and you will be given an option to Restart your pc or to Exit without restarting. Hope this helps.
Posted on Oct 15, 2008
    Guru:
  • 558 Answers
Login to window,,
Go to start --> Run --> type there msconfig
this will open a window, now inthat go to Boot Tab
And check if the two option given, if you have multiboot operating system (Viz Win 2000 and other one Win Xp)
Then it will show you each time during bootup (you can only setup one as default)
You also can setup the time for it to take in bootup.
Let me know if you need further help
Ellin
  • Puneet Jain
    Puneet Jain Oct 16, 2008
    Hey dont vote till you reach to a final conclusion, let me know the current status.
    Otherwise give solution to Helpful or Fixya.. (Dont give negative voting till the we fix the issue.)
Acer Veriton M498g - ui3540c won't start
Need more info, Give as much detail as you can. What happens when you push the on/off button? Fan spin? LED's Blink? Any thing on the screen? Sound? Does the computer try to start and a second later shut down? Check the power cord, check the AC outlet? Is it on a UPS? Try AC outlet? Can you get to BIOS or Boot Menu? ETC.
Feb 14, 2013 | Acer Veriton M498G-UI5650W Desktop PC...
How can i format a pentium 3 acer desktop computer.
you will need to get an operating system boot disc, such as an original windows XP, vista or windows 7 disc,, or use the restore disc that came with the product.
1.) boot from the disc (usually f9 at the boot pompt) thn select your cd drive as the boot device.
2.) follow the onscreen instructions..
3.) select new instillation instead or repair or restore.
4.) follow onscreen instruction.
Dec 27, 2012 | Acer Veriton PUV9803001 Desktop Computer...
Im try to format my acer veriton 7100 but the computer cannot boot any drive.. teach me how to do it
when the pc starts you'll see a splash screen that says hit "*" key * being some random key usually delete, or f2 or f1. once in bios change the boot order to DVD/CD first. save changes and exit. upon reboot you should see the computer say press any key to boot from DVD.CD
Feb 16, 2012 | Acer Veriton 7100 PC Desktop
Return to Factory Settings
Restart your computer now as soon as you hit the power button keep on holding Alt key & keep on tapping F10 key Alt+F10 it will open the recovery console select full factory restore and follow on screen instruction
(Note:this will erase all datas on the computer)
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps you
Feb 07, 2012 | Acer Veriton S460 (VT.S4155.830ZE-B22) PC...
Wether acer veriton 3600gt supported nvidia geforce 9500gt
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
if your computer came with a motherboard disc the drivers could be on it
or you could downoad them
http://download.cnet.com/driver-complete-rar/3000-2112_4-210081.html
Oct 30, 2011 | Acer Veriton 3600GT P4...
My acer veriton m661 desktop--i cannot set the time,checksum corrupt,possibly flashed with wrong acer bios-acer europe-any fix??
Examine the setup options to see if there's a failsafe mode or a BIOS reset/restore. Otherwise contact Acer tech support to see if they can provide a BIOS reset. You may have to send it to them. Older motherboards had BIOS on a 28-pin socketed chip called an EPROM. These could be ordered from various suppliers with upgrades, etc. I have not seen these in use lately.
Dec 12, 2009 | Acer Veriton M661 PC Desktop
Can't boot computer I get a warnig mssage unofficial case opened
Yes, you can clear this from the BIOS. First make sure the case is completely back together.
I can't recall the exact setting but if you search through the BIOS you will see it. Here's a link to the manual too which might help.
Don't forget to rate my solution if it helps! Thanks.
http://www.nodevice.com/user_manual/acer/desktop_systems/veriton_580068007800.html
Apr 05, 2009 | Acer Veriton 5800 PC Desktop
I have a Acer m420 4850B new I put in a PCI
Try going to the horses mouth (Acer) next time. From their on-line support:
Product
Veriton M420
Issue
Chassis Opened Warning Error
Solution
To disable the Chassis Intrusion Alert, please follow the steps below.
  1. With the system powered off; press and release the power button.
    Immediately afer releasing the power button, begin tapping on the Delete key.
    This will enter the system BIOS.
    In the BIOS, use the arrow keys to navigate the menus.
  2. Navigate to Integrated Peripherals and press Enter.
  3. On the Integrated Peripherals screen, there is an option labeled OnBoard IO Setup. Select OnBoard IO Setup and press Enter.
  4. Look for the option, Chassis Opened Warning.
    Select Chassis Opened Warning and press Enter.
  5. Change the currect selection from Enabled to Disabled and press Enter.
  6. Press F10 and then press Enter to Save the Settings and reboot.
The computer should boot without the intrusion alert message.
Feb 20, 2009 | Acer POWER APS290-UC4201P MT CELERON M 420...
BIOS Upgrade?
Hi you have selected Veriton 3500 as your computer.
everything including bios updates are available on this page
http://support.acer-euro.com/drivers/desktop/veriton_3500.html#bios
perform bios update at your own risk.
Feb 06, 2009 | Acer Veriton 3500 PC Desktop
Computers & Internet Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
