Question about Whirlpool Refrigerators
Whirlpool model ED25TW intermittent freezing
Whirlpool model ED25TW side by side. One day everything is fine, the next day everything is thawed. Compressor seems to be on and sounds normal but today I noticed no airflow in the freezer. Tomorrow, everything will freeze again! Any Ideas?
  • expresso4me Oct 15, 2008
    Side note: I just opened the refridgerator door for several minutes to clean out a few things, closed the door and the fan turned on. Now there is cold air flowing into the freezer again. It will probably work fine tomorrow and then stop again the day after.
  • expresso4me Jan 23, 2009
    Turned out to be the thermostat. I found that by tapping it with my finger, it would turn on and work again. Replaced it and it works as good as new.
  • 943 Answers
HI. it looks to me like a failing fan motor . it stops sometimes, then you close the door, and it goes. or could be hitting ice. remove the back panel ov the freezer, and check the fan motor
Posted on Oct 16, 2008
Freezer defrosting
You may have to reset the defrost timer.
Nov 23, 2017 | Whirlpool Refrigerators
Kenmore coldspot 106 freezer works intermittently
first clean the condensor coil the check if the fan working properly
Jan 20, 2013 | Refrigerators
Hi my freezer is freezing intermittently. For example, it will freeze the ice cream and then the next day the ice crease is soft. it may go two days working fine and then back to the same problem again...
Hi, The defrost timer is sticking on sometimes...replace it..
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Whirlpool GD5SHAX Side by Side...
My Kenmore side by side freezer stopped working for a day, all the frozen foods defrosted, then it started working again the next day. I have an appt. for Sears to come, but should I cancel?
The fact it stopped freezing to the point that your food thawed is a definite problem you need to have inspected. But keep in my mind, you apparently have an intermittent issue, and if you give your refrigerator repair service technician as many details about what you noticed in regards to your temperatures as you can, he should be able to pinpoint your problem if he knows what he is doing.
Oct 04, 2010 | Kenmore Freezers
Side byrefrigerator runs but not cold. Freezer is
take everything out of it, and let it thaw for 24 hours, using towels and whatever to clean up the water......then plug it back in, if it still does it, like 2 days later, it's broke, if it doesn't it was just the coil in the back that froze up. Happened to me.
Feb 15, 2010 | Whirlpool Freezers
Not freezing
It's probably frozen up due a bad defrosts system Call or email us with your model number and we'll be sure to send the proper part to get your freezer freezing again. How long has it been out? If it's been a few days of not freezing, you'll want to to make sure that the ice is all thawed from inside the back wall. You can do this by letting it stand unplugged all day or placing a fan in front of it all day. Then replace the parts. Hope to hear from you soon. Ella
Sep 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer cycling on and off, will freeze then thaw out
You have a defrost timer that has possibly slowed down because it is defective. I need you to time the defrost timer or turn the defrost timer inside the fresh food compartment until the refrigerator compressor stops running. It should remain off for about 20 minutes. If a lot longer and the refrigerator does not defrost regularly about 3 times a day then it needs to be replaced. Yes there could be something other than the timer, but if you need my help I'm here let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Jun 17, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Whirlpool conquest fridge; freezer isn't working
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
Oct 03, 2017 | Whirlpool Freezers
Ge profile refrigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Refrigerators
Freezer thawing and refreezing
The freezer is supposed to thaw at least everyday. Only, you usually kant tell because it doesn't do it long enough to melt the food so you don't notice it. You have a couple of components to check here. 1 is the defrost timer, which unless it has been changed recently, has the same pre determined defrost time. So you would have noticed by now. Next is the defrost termination switch. If you have excess ice on the evaporator, this will make the defrost longer than before. Unless the switch is going bad causing the defrost to go extra long, there is an excess amount of ice that is more than usual. Bad door seal will cause this. A slightly low freon charge. And a thermostat that is malfunctioning, causing the freezer to run continuously, will make excess ice buildup in the freezer. I would make sure the kids aren't leaving the door open and the gaskets are good. If not the case, call a repairman.
Jan 09, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
329 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
