My computer wont work out of safe mode - Computers & Internet
  • Michelle Russo Oct 15, 2008
    could you plese help me fix my computer so it responds out of safe mode.
  • Michelle Russo Oct 16, 2008
    I will try this but I have windows vists ultimate which is making things pretty difficult to get out of safe mode.
My Dell laptop is not working at all! When I turn it on all it does is show the Dell screen and then, it says erra operating system F12 And F2. I press the bottons for F12 and F2, and it still does not turn on. What is the solution for this problem? Can you post a solutiong.......
Posted on Oct 16, 2008
My pc has ukash virus, screen is blocked menu board comes up but nothing works when pressed task manager comes up but wont work in safe mode so cant type anti virus software in
There is no way to fix this outside of safe mode. If it is that serious, then you have to get into safe mode or reset the entire software.
Sep 13, 2013 | F-Secure Anti-virus Client Security...
Keyboard wont work
Try booting to safe mode and check if the keyboard has the same problem inside safe mode. if the problem is not present in safe mode, then I suggest that you update the drivers using RadarSync which is an automatic driver updater. It won't provide you with bad drivers.
If the problem still occurs inside safe mode, then you need to check the connection of your computer and the keyboard. If worse comes worst, then you would need to replace the keyboard.
David
Jul 15, 2013 | Samsung NC10-14GW Notebook
My computer wont recognize new wireless mouse
Make sure the batteries are inserted correctly and have charge
make sure the usb device is properly inserted
make sure you turn the mouse on depending on type/brand of mouse it will vary it could be a button or switch on top or bottom also you might try safe mode
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer then if your mouse works
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
hope this helps
Nov 20, 2011 | Computers & Internet
CANT GET INTO ACCOUT password wont work
Resetting password & user name on Windows:b>*Start your computer
*Keep pressing "F8" as the computer starts.
*This will enter the computer in Safe Mode.
*(When the window "Advanced Boot Options" opens, choose "SafeMode" with arrow key and confirmby pressing the Enter key, then computer enters Safe Mode.
*Once you are in the Safe mode Click "Administrator" on the Windowslogin screen.
*Take note that you have set the Administrator password before, you need toinput the changed password instead of leaving "Password" field blank.
*Then click Start > Control Panel > User Accounts > Select the accountthat is locked and change the password.
**Restart computer and login into the account you just created using your newpassword.
Nov 07, 2011 | eMachines eM250-1915 Netbook
Please explain step by step how to reboot a computer into a safe mode?
to boot a system in safe mode restrt your computer as the computer starts press F8 you will see a set of command like safe node safemode command etc click safe mode you will see set of files running wait till the safe mode starts the you will be able to see the mouse icon then it will ask do you want the computer to start in safe mode click yes now you are in the safe mode section in safe mode section the system starts in defult setting you wont be able function somefunctions safe mode is for correctiong your computer or to remove unwanted software or hardware
Oct 26, 2010 | Computers & Internet
Resolution set too high ..no picture cant get safe mode to work up down arrow buttons wont move ..computer wants to start normal...cant get into computer with no monitor display ...help...brand new...
Sounds like you need to boot up in VGA mode instead of Safe Mode
Step 1. Power Down your computer.
Step 2. Powwer on your computer and press F8 to enter Safe Mode
Step 3. Instead of selecting Safe Mode, Select VGA mode.
Step 4. Once in Windows, uninstall your graphics card for your Monitor.
Step 5. Restart your machine, when you log back in Windows will reinstall the drivers for your monitor.
Apr 21, 2010 | ViewSonic VX2025wm 20.1" LCD Monitor
Laptop is stuck in safe mode Acer
I faced the same problem with my laptop. I tried several methods. But none of them worked. But finally when I tied the following procedure it worked.
The following instructions work on a computer running Windows XPmag-glass_10x10.gif only, this is assuming that your laptop has XP installed on it. Use this only if your computer wont come out of safe mode by restarting it.
Go to Start > Run and type "msconfig" in the dialog box that comes up. Press Enter or OK and the System Configuration Utility box should come up. Click on the "BOOT.INI" tab. Down in the bottom left corner of the window under where it says Boot Options there will be several checkboxes. Make sure that the /SAFEBOOT box DOES NOT have a check in the box. When it is unchecked restart your computer and you should be out of safe mode.
Dec 28, 2009 | Acer Aspire 5315 Notebook
Computer wont start in safe mode
Click On Start---> Run---> MSCONFIG---> click on BOOT.INI --> Then Click On Safe Boot --> Click Apply And Click Ok---> Restart Your system u'll get what u want.......... Temme If u need any help in virus removal...
Plz Rate This Solllution If It Works For u
May 21, 2009 | Microsoft Windows XP Home Edition
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
