Question about Frigidaire FRS26R4A Side by Side Refrigerator
Frigidaire FRS26ZNH Freezer working great...but Fridge side won't stay cold enough...any suggestions...cleaned underneath but not sure if I got to the area where the condensor is...any other suggestions on what might be wrong... Turned temp on Fridge side all the way down to allow it to thaw out in case there was something freezing between the freezer and the fridge...just not sure what else it could be...has gotten worse and worse over the last 2-3 weeks...dont think its the defrost...and fan still runs at a normal interval.. Thanks..Loren
  • Thomas F. Schneider May 11, 2010
    Many of these have a fan that blows the cold air from the freezer side to the refrigiator side. Have you checked to se if the fan is blowing?
    Open the door when it is running , hold the light button in and see if you have air flow.
5 Suggested Answers
guide2u
  • 461 Answers
SOURCE: frigidaire refrigerator/freezer
bit confuse with your problem.. are you having a defrost issue or leaking issue? If defrost issue... Check your compressor it is working? compressor - The thing that make noise behind the refrigerator...
Posted on Sep 05, 2007
fridgetech
  • 473 Answers
SOURCE: New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Posted on Oct 07, 2007
SOURCE: frigidaire PLHS267ZDB2--Not cold enough
Replaced the fan and the damn thing works like a charm....Thanks alot for all your suggestions.This is a cool site and you guys are doing a great great job! Keep up the good work!
Posted on Oct 22, 2007
Krazytech
  • 725 Answers
SOURCE: Frigidaire Model number frs26znh defrost not working?
The defrost systems is:
218169802 HEATER-DEFROST
5303917954 THERMOSTAT-DEFROST
5303917954 TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Posted on Jul 25, 2008
SOURCE: Frigidaire FRS23H5AS side by side. condensor fan runs, no voltage to compressor
i replaced the control-defrost adaptive timer pc board after lighting storm and it worked fine for ten days then i turn off may power to my house to reground the house and my frig is doing the same thing fan not running evap freezing fan not running what is going on
Posted on Aug 22, 2008
Why is my frt18s6awx not getting cold enough in freezer & fridge?
Good Afternoon Friend,
I understand that your Frigidaire freezer, model# FRT18S6AWX, is not getting cold enough in either the freezer or refrigerator. I suggest changing the settings to a colder setting and give it 24 hours to stabilize at the set temperatures. Also, I recommend cleaning the toe grille and condenser coils. You can do this by taking the toe grille off and cleaning it with soap and water and rinsing it thoroughly with water. While the toe grille is off, get your vacuum with extension, and vacuum underneath your refrigerator. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire FRT18S6AW Top Freezer...
Frigh won't get cold enough
check the slot between the freezer and fridge with this model the freezer cools the fridge there a door in the slot make sure it is opening properly
May 26, 2012 | Frigidaire FRT18P5A Top Freezer...
Frigidaire side by side model FRS26ZNH is not cooling correctly. There is a very hot spot between fridge and freezer doors about 4.5 feet up from floor. Help please
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 03, 2011 | Refrigerators
Fridge not keeping cold..
Check the coils underneath the fridge. Carefully vacuum and brush the coils clean. Usually there is a condenser fan near the compressor and condenser and a evaporator fan in the freezer. Make sure they both are turning.
Jun 21, 2010 | Electrolux E23CS75DSS Stainless Steel
Fridge & freezer are cooling on bottom but not
when you open the freezer door do you hear the fan blowing?sounds like the air isn't moving,there's also a damper on the fridge side,the door opens to let the cold air in and then closes,make sure the door is opening,you can take the cover off and put an ice cube on the twirled up metal part to close it and put your hand on it to open it to see if it's working
Mar 21, 2010 | Frigidaire FRS26H5AS Side by Side...
Temperatures not staying cold, then getting too cold. First everything in freezer thawed out. Then, fridge wasn't cold enough. We moved everything to freezer just to keep colder (not to freeze). Then, days...
assuming fan now working. clean out vents/ drain holes (make sure no ice in bottom of freezer or in fridge unit)i.e. a total defrost.then check door seals all okay(no air leaks) if unit was trying to defrost itself and you reset to colder it will need to reset itself.....
Feb 11, 2010 | Hotpoint HSS25GFP Side by Side...
My side by side is not cooling well on either the freezer side on the refrigerator side...have both sides jacked up to nine ...it is still cooling but not cold enough!! The ice cream is soft, but the meats...
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath
Aug 07, 2009 | Refrigerators
Freezer not cold enough/ice maker not working
Check the coils in the freezer to see if they are blocked with ice.
May 01, 2009 | Frigidaire 11.6 cu. ft. / 328 liter...
Freezer and Fridge are both not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
hhsg
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Begin by turning the freezer temperature setting dial to a lower setting. Then wait a few hours to see if your problem is fixed. If that does not correct the problem you probably need to have the coolant system recharged. That requires special equipment so you will have to call in a repair person.
Dec 29, 2008 | Frigidaire FRT21H8 Top Freezer...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
409 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
