How do you adjust the fine grain convergence on an hitachi 53hdx01b?
  • 61 Answers
Your problem description is not clear.May be you have convergence problem with your unit.
Press flash Focus button on the control panel of the unit.If the flash focus complete one full cycle there is no problem with convergence amp.
Inorder to adjust convergence you need to enter the unit into service menu.
Good Luck
Dals123
Posted on Oct 15, 2008
How do you line up bulbs with remote
This set with front grill removed has a tiny blue button on front edge of chassis on left side that will manually take set to convergence mode but you must have the Hitachi working remote to do adjustments---different buttons on the remote adjust and save the adjustments, I have the Hitachi book that shows all remotes they use and which buttons do what---if convergence is real bad most likely the two chips for convergence need to be replaced if Magic focus will not help.
Oct 14, 2012 | Hitachi 43UWX10B 43" Rear Projection...
Changed ic's need to reset picture every time i try keeps saing over load
If the convergence adjusts ok in the customer mode do not worry about the "overload" it only has to do with the Magic focus feature---
There is a way to overcome that but It is tricky and one wrong move and you have real problems--it involves DECAM--de-converging and clearing the set's memory of the convergence adjustments--It means the convergence has to be adjusted from scratch--I have seen this done by an expert and I have done it but no one not totally familiar with the process should attempt it.
You know there is a Tech Menu for fine adjustment of the convergence?
That is not hard to access but I have a Hitachi book that tells which buttons on the Hitachi remote do what in this mode---The remote will have on the face of it a CLU number--tells which remote it is.
If the convergence adjusts do not worry about the Magic focus--it only adjusts the convergence at about 16 places on the screen---in the Tech menu you adjust at over 60 places--much better way to go.
Get me the Clu number on your remote and I can scan the page from Hitachi---we will need to find a way for me to get it to you...............
If this helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 13, 2009 | Hitachi 53SDX20B 53" Rear Projection...
Hitachi 43FDX01B green is out of whack
The green is not adjustable in the customer menu because it is considered the 'master' color. It is adjustable in the technician mode however but if it is curved it won't even adjust properly that way either. The problem is the convergence ampifier responsible for green convergence has failed. The convergence output IC's need to be replaced.
May 27, 2009 | Hitachi 43FDX01B TV
Hitachi 53" projection
there might be some resistor that shorted
Apr 28, 2009 | Hitachi 53UDX10B 53" Rear Projection...
I have 46ux13k hitachi tv and i need to know if there is atrick to adjusting the convergence.
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACHI REMOTE. NONE ELSE WILL DO
1. Receive an NTSC signal.
2. Press Magic Focus to begin magic focus
3. Press magic focus again during the magic focus process to get the “stop” screen.
4. While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and the service grid (64 point grid).
5. When you first get in here? I believe red is the selected color by default (it is flashing).
6. To choose other colors to converge, use the following buttons on the R/C:
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
ONE COLOR WILL NOT MOVE. YOU WILL NEED TO MOVE OTHER COLORS TO ALIGN TO IT.
7. Start from the center of the screen and work your way out on one color at a time. I adjusted red across the whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
may want to go back and adjust some red again? etc. until the convergence looks good.
· Use 4, 6, 2, and 5 on the R/C to move the cursor position (dotted lines).
· Use thumb stick to move the convergence point color.
Then going along the lines and adjusting, you may run into the problem of getting an ‘S’ curve on the line. You’ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the line between the points will not straighten out (it bends between the points). To fix this, the manual recommends going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in (13x9) mode (64 point). If you have serious problems, the grids work as:
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
10) To get to each of these patterns use the following on the R/C: (only if you need to)
1. (3x3) Press “STATUS” 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point… depending on where you start, work your way up, and always finish on the 13x9
12) When finishing up the 13x9 mode, to get additional ‘grids’ on the edges of the screen, press the PIP CH button on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence as necessary. To exit, press PIP CH again.
13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write displayed data to ROM.
14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
15) Green dots will be displayed when operation is completed.
16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
17) Turn power OFF.
18) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just to make sure the magic focus still works (and that you did the last few steps properly)
Mar 21, 2009 | Hitachi 43FDX01B TV
Hitachi 42" 43gx01b Convergence problem
You have convergence output failure. The output ICs will need to be replaced and possibly a small component like a resistor or two as well. Expect to pay a service company $350-$450 to resolve this.
michtech
Feb 17, 2009 | Hitachi 43GX01B 43" Rear Projection...
Can't set red convergence on 65" Hitachi
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 24, 2008 | Hitachi Director's Series 65XWX20B 65"...
Hitachi 51S500 51 in.
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Aug 11, 2008 | Hitachi 51S500 51" Rear Projection...
HITACHI PROJECTION MODEL53FDXO1B CONVERGENCE PROBLEM
Replace both IC's with first quality Hitachi upgade STK394-160
part # CZ 01341 and inspect near-by resistors for over-heating.
.......................T.
Feb 15, 2008 | Televison & Video
Hitachi 51SWX20B Convergence problem
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in or warped.
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Jan 28, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Open Questions:
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Electro Med Services...
