Question about Maytag MMV5156AAS Microwave Oven
Does not heat
Our microwave mmv5156aa does not heat and is making a loud humming noise, but the turntable is still working
  • Maytag Master
  • 9,098 Answers
Chances are you have a shorted high voltage rectifier diode or a failed magnetron.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
Thereshould also be a "mini-manual" hidden inside the unit behind thecontrol panel or hidden on the left side behind the grille, which isvery helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Oct 20, 2008
Microwave will not heat, but will turn on. Clock and Timer still work. Turntable turns. Making a loud humming noise and light flickers
This clearly indicates a bad magnetron, "heats food" in most cases it is cheaper to replace the microwave oven than have it repaired, since the magnetron is the heart of the unit.
Mar 01, 2012 | Microwave Ovens
Runs but has loud humming sound. Does not heat. Turntable, timer and lights work.
The diode that connects to the capacitor needs to be replaced. Once its replaced microwave will begin to heat again. (If it wasn't heating and wasn't making a humming noise, then your magnetron would need to be replaced). If you are thinking of doing it yourself and need instructions, i'll be glad to help.
Feb 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
KitchenAid KCMS1555RSS stopped heating. Everthing else works, full display works, time counts down, turntable rotates, light comes on, etc. but no heat. makes loud hum. Magnatron? Cost to replace? Unit is...
If it is making a loud noise, check the diode and magnetron for damage.
BEWARE OF LETHAL VOLTAGES!
The fault may be just the diode and a reasonable cost will be involved. If it is the magnetron, depending upon where you purchase one from will command the price.
Hope that helps.
Nov 13, 2010 | KitchenAid KCMS1555RSS Stainless Steel...
The unit is 3 years old and when I turn it on there is a loud hum. Theunit also does not heat but turns the turntable?
From your description it sounds like the magnetron has failed in this oven. That's the part the makes the microwaves to heat the food. It typically fails by shorting out and making a loud hum noise. It not usually worth fixing since the price of a replacement magnetron is almost as much as a new oven.
Jul 01, 2010 | GE Profile Spacemaker JVM1871 Microwave...
Microwave not heating
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 08, 2010 | Whirlpool GH8155XM Microwave Oven
MICROWAVE, NO HEAT, TURNTABLE WORKS, COULD THIS BE A FUSE
Please reply back with your brand and model number so we can help you.
Jan 07, 2009 | Maytag MMV5156AAS Microwave Oven
Loud humming noise
If all of your door switches check out, replace the magnatron, capacitor, and diodes.
Oct 27, 2008 | KitchenAid KHMS145KSS Microwave Oven
Over range micro
Same with ours does not heat but makes a loud humming noise
Jan 12, 2008 | Maytag MMV5156AAS Microwave Oven
Noisy when running - not the usual humming noise
check turntable motor or bush, this very easy problem, you can use oven no problem..
Nov 11, 2007 | Whirlpool GH8155XJ Microwave Oven
Maytag MMV5156AAS Microwave Oven Logo
330 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
