Question about Jabra BT250 Consumer Headset
Not charging up nor Starting, what next!
My bluetooth headset is not working now.. not used for six months.. seem to be in good condition till
It is neither connected with phone nor charge it up.
Model: Jabra BT 250V
Help me what to do next..
Ellin Scott
  • kellykots Jan 10, 2009
    I already have one Jabra BT 250v and loved it so I bought another for my daughter, used but in excellent condition. I have tried both chargers and it doesnt seem to charge or turn on. The light blinks once (blue) when the connection is made in the charging cradle, but thats all. It will not turn on after leaving it on the charger overnight either. Whats wrong with it? Can it be repaired for a reasonable cost?
    Contact me at:
    Thanks! Kelly
  • Anonymous Jan 12, 2009
    When connected to the cradle a blue light blinks once and then nothing. The headset was not used for a while. Can someone please tell me whats wrong and how I can solve this ? Thanks in advance
  • 4 Answers
I can't connect with my phone
Please follow the detailed instructions below for the proper pairing of the headset with your phone.
Before using, you must first charge your headset.
20 minutes = minimum charge
2 hours = full charge
Light is solid red when battery is charging.
NOTE For the best user experience, keep your headset fully charged.
CAUTION Do not use headset while charging and do not connect the charger while the headset is in use.
Press the control button for 2 seconds to power on. Press the control button for 3 seconds to power off.
Step One:
Prepare Phone- Turn on Bluetooth For most phones, go to Settings/Tools menu and select Bluetooth or Connectivity and select "On."
Step Two:
Prepare Headset- Pairing Mode Begin with headset turned off. Turn headset on (hold call control button for four seconds until the light flashes blue) and it will automatically go into pairing mode, flashing red and blue.
Step Three:
Pairing- Add Headset to Phone For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device, then Select "220Plantronics." For passkey enter
0000. Headset will flash blue when paired successfully. It is now powered on and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with another device, follow pairing instructions below.
If headset has been previously paired with another device, please follow these instructions for pairing a second time. Be sure the headset is fully charged.
1. Press and hold down the call control button for 8 seconds until the headset status
indicator begins to flash blue then red.The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing,use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
NOTE: The headset can pair to multiple Bluetooth devices, but will only connect to one device at a time. The headset will automatically connect to the last device to which it was connected.
Please don't forget to rate me if satisfied.Thanks for choosing Fixya.Good Luck.
Jun 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
The blue and red light doesn't. Come on at all
First, make sure to charge the unit for a few hours. Next, try pairing with the following link:
How to Pair Plantronics Voyager Pro Bluetooth Headset
If it still doesn't enter pairing mode, the unit is defective and needs to be replaced. It comes with a 12 month warranty. Contact your supplier to receive a replacement.
Good Luck from Headsets Direct!
Apr 27, 2011 | Plantronics Voyager PRO Bluetooth Headset
Even after charging the jabra stone does not come on nor pair
I am having same problem. Stone seems to be charging, but headset will no longer operate. Have used successfully for 5 months.
Sep 15, 2010 | Jabra Stone Bluetooth Headset
This is the second Plantronics earpiece that stopped working
I am sorry to say but the Plantronics are cheap and not well made. Sounds like you might have a weak battery and because of that it wont have enough charge to turn on. I myself have gone through many and now spent a little bit more and got a better earpiece.
Sep 08, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics Explorer 220 bluetooth won't pair with LG NV3 phone. It's in discovery mode and I'm getting the red/blue flashing on the bluetooth like the manual says, but it just keeps searching and will not...
Well I got it working, of course, try turning the phone off on again instead of just the bluetooth, it worked. I should have done that before posting the question.
Jul 28, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth headset doesn't hold a charge very log
hold call button down till it blinks, than youll get intermitant light for about 30 seconds, than youll know its on. to turn it on hold call button down till it starts blinking at least 6 seconds. to turn it off hold call button down , itll blink for about 3 seconds than move your thumb off and when it ceases to blink its off. good luck
Jan 12, 2009 | Jabra BT350 Bluetooth Headset Headset
Not charging up nor starting
Typical non use problem answer is on this site use this link
Oct 15, 2008 | Jabra BT250 Consumer Headset
Lost pairing?
First when ya call connects, hit the Menu key (three lines inthe center) choose USE HANDSET.
Second Make sure the Bluetooth is fully charged, andit seems to lose charge fast.
Dec 15, 2007 | Motorola Mobility H300 Wireless Headset
Jabra BT250 Consumer Headset Logo
158 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
