Question about Kenmore Elite 45986 Front Load Washer
Model 4778* Kenmore Elite
F 35 code ?
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: what does error code F 35 mean
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
marka19
  • 1430 Answers
SOURCE: Kenmore Elite HE 5t 4778 (or 4779?) : Stopped
If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked
Check the drain pump filter for debris
If all the above checks out good . This would indicate that the pressure switch or also called the analog pressure sensor has failed. First you will need to remove the top lid. Usually 2 or 3 screws on the back and the top comes right off. The pressure switch has a clear hose and a clump of wires going to it. Then unplug the hose and blow thru it it should be clear. Check the hose for leaks or obstructions. Also in the back of the washer on the left hand side is a air dome this is where it gets it pressure reading from, make sure it is not obstructed. If all is clear the pressure switch will need to be replaced. Here is a link to help with accessing the pressure switch also if you need diagrams or illustrations of your particular model.
Posted on Sep 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite model 42934. Problem washer only
Posted on Oct 01, 2010
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
Have a kenmore elite washer f35 fault code help!!!!!!!
this is to do with a pressure switch ..take the pipe of and blow in to it ..then blow into the switch..put together..and put on rinse a few times...ifstill the same change the pressure switch
Mar 18, 2014 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite HE 5t 4778 (or 4779?) : Stopped during cycle and flashes the code F 35. I had to pull the plug to re-set the washing cycle, as pushing the stop button twice as instructed did nothing. What is...
Sep 30, 2010 | Kenmore Washing Machines
Kenmore elite stops working. display gives F 35 code
Just tilt the washer back and prop it up with some wood blocks. Three screws are right on the front at the very bottom. Use a 9/32 socket to remove them. The front cover slides right off. The drain trapclean out is right in the middle. Turn the large white knob counter-clockwise to remove it and clean.
Thank you !!
Aug 15, 2010 | Kenmore Elite 45986 Front Load Washer
Jul 26, 2010 | Kenmore 42822 Front Load Washer
Code "F 35" What does this mean?
Jan 09, 2009 | Kenmore Elite 45986 Front Load Washer
What does error code 35 mean on a kenmore elite induction cooktop model 790.4290. I believe the unit is made for Kenmore by Electrolux
it has a fatal or error condition. try turning the power off and than back so it the cook top can reset it's self. if that does not work you will need to contact sears for service.
Aug 23, 2008 | Electrolux Kitchen Ranges
Can't raise temperature
35-37'Celsius is very warm. room temperature is around 19-23'c idealy
Can you post me the model number so I can get the user manual with the instructions on how to adjust the temperature?
Aug 06, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 45986 Front Load Washer Logo
77 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
