Question about Copystar (023-JF503) Fax
Im getting an f2 error code in my copy machine sharp 2020
As described above im getting an error code on my sharp 2020 any sugestion on what to do or how to reset it to get it back to work
    Problem Solver:
  • 6 Answers
SHARP 2020 F2-31 ID sensor error SHARP 2020 F2-32 ID pattern reading error SHARP 2020 F2-33 Grid voltage error SHARP 2020 F2-35 Grid voltage error
probably need a part
Posted on Nov 26, 2008
Sharp MX-M232D: F2-40 error. I was able to scan without issues. When I inserted a Sharp Genuine Toner cartridge into the machine, I receive an F2-40 error.
If you have reset the machine as described & then re--inserted the same toner cartridge giving you the same error code then I would suspect the CRUM chip that is installed on the toner cartridge is faulty.
If your machine is under a maintenance contract which includes the provision of toner then contact your service provider & they should replace it F.O.C. If you have purchased it yourself then contact the supplier advising them of a faulty cartridge. If you replace the toner with a new one, you must reset the machine as above before you insert the new toner.
Hope this helps.
Dave.
Oct 12, 2017 | Sharp Office Equipment & Supplies
Sharp SD-3062 error code F2 00
F2-00, ID pattern reading error.
For some reason and it may just require cleaning and recalibration, but the IMAGE DENSITY pattern is not being read properly.
It may need new developer, the drum may need to be.replaced.
First and foremost it should be cleaned, Optics coronas and machine cavity.
Hope this is of some help.
Ed
May 21, 2009 | Sharp SF 2020 Copier
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Service problem
This code is a fuzing unit code , one of your thermosters are busted or dirty so it is not picking up the heat correctly , ill sugest you take out the fuzing unit and clean both thermosters and try again , but you need to reset the code after cleaning the thermosters by pressing :yellow c 107 and hold down orange c until it shows copy sp mode press 1 # then turn the power switch on and of hope this helps
Nov 05, 2007 | Ricoh Aficio 2020 All-In-One Laser Printer
159 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
Oloyede Monsuru
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
