Question about Zenith C27A24T 27" TV
Can't get any volume aenith SG20315
8 YR OLD ZENITH TV can't get volume to go up
    Champion:
  • 252 Answers
Use a remote to control the volume ,coz maybe the volume up switch is defective. Change the volume up switch
Posted on Oct 16, 2008
Hi. I have a Zenith 42" plasma TV - Z42PQ20 that's
I had this exact problem on my TV, everything said it was the power board. It wasnt, luckily i was able to return that board. It was the YSUS board.
I should have done this this first but this is how i verified the old power board was good. Unplug TV, take the cover off and disconnect the wire harness going to the YSUS, plug TV in and turn on. If led stay blue its the YSUS.
Mar 19, 2011 | Zenith Televison & Video
My tv will only display ch. 2 my little 5 yr. old was playing with the settings it is a 15 yr. old zenith tv
Depending on your market, it sounds like all of the other analogue channels have been terminated (not your son's fault) in order to provide stronger HD signals. You may need to run to wallmart and get that $50 decoder box.
Apr 21, 2009 | Zenith SY2772DT TV
16 yr old 25" Zenith..1st colors went yellow/lime now TV is dead
Absolutely not worth repair. You have described a classic symptom of Zenith picture tube failure, and about 99% of the time the main board in the TV is ruined as well. You've gotten good life from the set (manufacturers figure tube life is around 7 years these days), so it's time to replace it.
Apr 09, 2009 | Zenith B27A11Z 27" TV
My zenith 52 wlcd-tv will not come on.
We had the same problem and cost 374 dollars and the remote control thing in the TV was replaced in our 52 inch projection tv (about 6 years old). Now it does not turn on with the cable remote. 2 months later now the tv (on its own starts to flip channels and the volumes goes up and down even when the all the remotes do not have batteries in them.
Feb 03, 2009 | Zenith R57W46 57" Rear Projection...
Zenith dvd/vcr mod #6711R1N211C. Need to prog the volume button.
In my manual, to control a sony TV.. the code is number 8 or number 9.
You will hold down TV POWER, hit 8 then release TV POWER.
If that doesn't work, try number 9. Once the batteries are removed, it resets the code, so write it down. It will also over ride your old codes once you input the new one.
Note: Depending on your TV, some or all buttons may not function on the TV, even after entering the correct manufacturer code.
I looked for the section on Stereo, but all I found was the above.
Hope this helps.
Nov 22, 2008 | Zenith XBR411 DVD Recorder/VCR
Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Nov 21, 2008 | Zenith DBZN-311 Remote Control
Zenith TV is Going Blurry
A Zenith model # would be helpful and mo/yr built on sticker on back.Problem sounds like bad pix tube.
Dec 02, 2006 | Akai CF2791 27" TV
Zenith C27A24T 27" TV Logo
227 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
