Question about Canon PowerShot A75 Digital Camera
Lebs makes clicking noise and sometimes sticks
When i try to use the canon a-75 the lens makes a clicking noise when it telescopes in and out , Sometimes it sticks,but by turning the on and off button on and off several times it goes back in > its a terrible clicking noise like it is getting hung up on something ? > I am still able to take a pic but it will not focus very well getting stuck > i did change batteries etc > your help would be highly appreciated > thank you Terry
    Problem Solver:
  • 9 Answers
Dear terry your problem seems to be with the lense barrel  probably has the camera fallen on the lense or while the lense was out did someone try to push it in  the lense drive mechanism consist of plastic parts which can take a certain amt of external shock possibily the drive mechanism must have got disturbed so hence you are facing this issue it has to be opened by a qualified engineer who knows his job to sought this out
Posted on Oct 15, 2008
Can you give me the instructions on how to assembly/disassemble the ef 75-300 f/4* lens?
you can get it on ebay.com for cheap price .But first - try to look it for free on google.com. Sometime you can easily find it.
Jul 27, 2014 | Canon EF 75-300mm f/4-5.6 IS USM Lens
Is the Raynox DCR 250 compatible with 75-300mm Canon lens?
Have a look at this page for discussion about this adapter. Depending on the lens you're using it with - the DOF can be extremely shallow and make focusing difficult. If you're in Auto Focus mode - try switching to manual and see if you can get better results.
Aug 21, 2012 | Canon EF 75-300mm f/4-5.6 II Lens
Tripod mount for canon 75-300 mm lens
The XTi (400D) needs to be attached firmly to a tripod with a tilting head to enable you to counteract this.
Jun 26, 2012 | Canon EF 75-300mm f/4-5.6 IS USM Lens
Tamron lens makes a clicking noise
It is dealing with the films. when closing the lens in the fabric, the electrical film changed its position to an unwanted situation. This makes noise sometimes. It is not important for functinality of the lens. But it only gives you an unwanted noise. There is nothing to do because film dries as the times passes. It needs to be changed but is not cheap. So it is better to go on to use it.
May 28, 2010 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Canon EF 75-300mm f/4-5.6 III USM Lens Auto focus motor keep working back and forth but lense is not able to stop on focus right. Had eror 01 also sometime with manual focus.
If your AF motor is hunting then the lens probably needs to be looked at. I wouldn't recommend this as something to do at home so you will need to either find a repair shop if it is out of warranty or return it to Canon if it is in warranty.
Jan 17, 2010 | Canon 75-300mm f/4-5.6 III USM EF Lens
Broken lens : error
The lens unit will have to be replaced. This is a factory level service. It will most likely be more feasible to replace the camera!
Jerry G.
Apr 26, 2009 | Canon IXUS V2 Digital Camera
Camera lens
Hey kgconstruct,
The lens description that your posting is categorized under is a 75-300 f/4-506 DL lens for Nikon AI. If this is correct then no this lens won't work on a Canon camera. I am assuming this isn't correct and the lens you have is for a Canon camera, and if this is true this lens should work on the XTI. If you’re thinking of buying this lens I would go to a local camera store that carries this Sigma lens and try it out first to make sure you like it. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 16, 2008 | Sigma 75-300mm f/4-5.6 DL Lens for Nikon...
Canon SD900
First off, see if Canon can help you. If not, the following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 28, 2007 | Canon Digital SD900 / IXUS 900 Ti Digital...
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
Error message E25
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix you problem. In any case it could not make it worse Good luck!
Oct 09, 2006 | Canon PowerShot A100 Digital Camera
Canon PowerShot A75 Digital Camera Logo
61 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
