Question about Tascam DP01FX All-In-One Recording Package Microphone
TASCAM MIXER ISSUES
I receive a "System Error Code 4" when I turn the mixer back on and can no longer access the menu (or anything else).
The second problem - immediately before I received the above error code for the first time, I had been mixing down tracks because I had received a "No Free Disk" error, which had never happened in two years of using the equipment. I followed the manual instructions to copy the tracks and move them into another partition, but it seems as if the tracks just disappeared. I don't know if these two problems are interrelated...now I figure that even if I can advance past the System Error Code, my songs are gone for good.
  • Bookboy1998 Oct 15, 2008
    But how do I "reset" or "format" it if I can't get the mixer to advance beyond the error message?
    Okay, thanks.
  • 69 Answers
How big of a hard drive do you have? Ie: 3.5 inch hard drive. You may be able to erase it if you put it in a laptop or desktop.
Posted on Oct 15, 2008
  • 1,800 Answers
This problem occurs when the unit needs a software/firmware upgrade
1/ try to rset it or even format it
plz do aret this post so we can help further
  • Tascam Master
  • 19,396 Answers
Try first unplugging the system for ten or twenty minutes to reset the eeproms, see if you get the same problems when you plug it back.
  • 2 more comments
  • Ginko
    Ginko Oct 15, 2008
    Generally you get "System Error Code 4" when the hard disk partition is full, and there is no more space for other files, if the system still starts , try deleting obsolete files, if the disk is full it wont even allow you to transfer files to disk, returning "No Free Disk" error.
    Try making some space on the disk, if you are not able to delete files anymore because the system does not even starts, then the hard disk must be removed and connected to a PC to erase files.
  • Ginko
    Ginko Oct 15, 2008
    If you do not care about files stored on the hard disk , then you can re-intialize the system, this will format the hard drive, erasing all files (you lose everything and system goes back to factory settings).
    Here is the procedure to re-initialise the hard drive:
    1. While unit is off, hold down Track Edit and Shut Down buttons at same time,
    2. While holding the buttons down, turn on DP01-FX
    3. It will ask you "Are you sure?"
    4. Press enter, you will lose everything on the recorder
    5. Go through re-initialization following procedure.
  • kbakre1 Oct 27, 2010
    Man you are the best. I am gonna give for you 110% because for 2 years my DP01-Fx was saying Error code 4 I fexed by by those best 5 your procedure Re-initialist the hard Drive solution.Mr Ginko Thanks man thousend times. I never for get you byee God Bless you.
  • Ginko
    Ginko Oct 27, 2010
    Hi.
    You are welcome.
    I am glad to know it's fixed.
    All the best.
    Ginko.
DEAR SIR/MADAM WHEN I TRY TO RECORD MY VOICE VIA MICRO PHONE SINGING WHILE THE CD MUSIC TRACKS ARE PLAYING I COULD NOT RECORD THAT TO THE MINI DISC.PLEASE ADVISE ME HOW COULD I CONNECT IT DIGITALLY
It is much easier to use an analog mixer and microphone thru the mixer. I would plug the microphone into the mike input on the mixer and then the Karaoke machine to stereo LINE inputs on the the Mixer, then Mixer Output or Tape Output on the mixer to analog LINE IN on the MiniDisc recorder.
Let me know if you need more info.
Jan 16, 2016 | Tascam Audio Players & Recorders
Hi I have a tascam tm-d4000 it stopped working now shows on the screen "fatal error"
Usually, this is a symptom of a main board failure. Sometimes rebooting the mixer will temporarily stop the error. If there are any additional numbers (like 99-00000009-00) in the error message, you can try resetting the unit. Press and hold Shift and Mixer Position and then turn on the Mixer. The unit will need to be professionally serviced or replaced. Since it is a discontinued model, check your warranty. It may be cheaper to replace the mixer.
I wish that I had better news for you.
Jan 28, 2015 | Office Equipment & Supplies
I want to record using Tascam with my peavey xr1220 mixer
What Tascam recorder are you using? If you are multitracking you will be unlikely to be able to use this mixer. Otherwise get a phono lead to fit the tape out and suitable connections for the Tascam recorder at the other end. This will allow you to record the main mix but unless you are a solo act or putting everything through the PA this will probably be pretty useless to you.
Jan 07, 2015 | Peavey XR 1220 Powered Mixer Mixer Powered
How do I hook up my tascam fw1082 to a mixing board?
Hi, There are two ways you can connect it up. You have a TRS (Tip Ring Sleeve) monitor output that could be patched into the inputs of any analog mixer, balanced high level inputs.
You also have a S/PDIF stereo out. If a digital mixer doesn't accept S/PDIF you can get a converter to change S/PDIF to an AES, which any pro digital mixer will work with. I think HOSA has one for about $60.00, you might find something on Ebay as well.
Here is a Link to the TASCAM Spec page for you FW-1082
http://tascam.com/product/fw-1082/specifications/
I hope this helps,
Best Regards,
Mark
Jan 26, 2011 | Tascam Audio Players & Recorders
There is no power to my tascam x17 4 channel mixer
Sorry but it does sound as though the power supply has an issue then and would suggest someone with experience electronics etc. Most guys with audio electronic should be able to assist,
Hope that helps
Jan 27, 2010 | Tascam X17 4 Channel 19" DJ Mixer with...
No Audio
make sure your toggle switches are on tyhe correct line and the fader is correctly channeled check all killswitches
Jan 12, 2010 | Tascam X9 DJ Mixer System
I HAVE A TASCAM DIGITAL MIXER TYPE DM-4800. I NEED IT TO CONTROL MY TASCAM HARD DISC RECORDER TYPE X-48. I NEED CABLE CONNECTION AND SETUP INFORMATION
http://www.manualnguide.com/download/manual-guide/tascam-dm-24-digital-mixer-automation-manual.html
setup information in manual above-i think cable will be found in a music equipment store near you.
Jul 18, 2008 | Tascam Audio Players & Recorders
Tascam DM-24 Digital Mixer Problem
I purchased a used Tascam DM-24 mixer about 2 years ago, and it 's been running great. Just about 2 months, it frequently shut itself off with a message:
" Power Supply voltage (+5V) is too low for stable operation. Please restart DM-24".
Of course, many attempts of restarting the board, but it won't turn back on after several hours later, and only lasts about half a day work only. Very frustrating. Any idea I could get help or fixed? million thanks for suggestions. Brian
Dec 31, 2007 | Tascam Quantegy 120 Minute Digital Audio...
189 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
