Question about Lexmark X2330 Printer
Lost disk to install
Working with windows xp lost installation disk
Heaven lost disc to install
  • Lexmark Master
  • 19,396 Answers
Lexmark does not distribute replacement install disk for all models.
Contact Lexmark here, to see if the disk for your printer is available.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading, find thefile,double click on the file, then if you get introubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printer does not work on Vista
Posted on Oct 15, 2008
I want to instal a windows XP SP3 on Foxconn 915 series with north bridgegrantsdale G-i915G with a IDE H.D.D (pata) and sata O.D.D,it seems that i need a floppy disk for raid driver,but i lost motherboard...
There are a couple options.
  • Check in BIOS to see if your motherboard supports IDE emulation mode. If it does turn it on and XP will install just fine.
  • Download and read about using nlite to incorporate sata drivers into an Windows XP installation disc. (You will need another working computer. Download nlite and insert the XP disc run nlite and select your CD as your windows install file location. Download generic sata drivers, intel has a bunch you can get for free. In the nlite menu to add drivers select folder option and select the folder with the drivers. Set anything else you want in nlite and burn the new XP disc. This disc will install just fine as it now has sata drivers.
Comment if you need further instruction.
Aug 18, 2011 | Foxconn 915P7AC-8KS Motherboard
Restore disk has been lost. I need to know how to change bios to allow straight Xp to be installed
This isn't a bios setting, it's a setting that Compaq put somewhere (probably the MBR) of your OS to only allow it's restore discs.
If you want to use straight Windows XP OEM discs, just boot to the disc and you'll be able to install Windows. If that doesn't work, just format your hard drive(you'll lose everything) then boot to the XP and install that way.
Jun 11, 2011 | Compaq Computers & Internet
I lost the operating disc that came with the my emachines T4010 how to do restore
Use a regular Windows install disk and find from here
http://www.emachines.com/support/drivers.html
and install the drivers yourself.
Jun 15, 2010 | E-Machines eMachines Desktop PC
Not recognizing hard disc drive for windows xp reinstall .
You aren't using the correct install disk . The generic XP install disk can't recognize a SATA disk.You will have to load the appropriate driver during install. Here it is ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32492.exe
Or you could create a custom install disk  as explained here
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
May 13, 2010 | HP Compaq Presario C304NR Notebook
I CAN'T INSTALL A WINDOWS XP SOFTWARE
Thank you for choosing Fixya.com
Yes you can install the Windows XP on P4X266.
Here could be five various steps you can go about.
  • Method 1: Perform a clean install of Windows XP
    Use this method for a clean installation of Windows XP. A clean installation removes all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk.
  • Method 2: Upgrade to Windows XP
    Use this method if you are upgrading to Windows XP from Microsoft Windows 98, Microsoft Windows Millennium Edition, or Microsoft Windows 2000 Professional.
  • Method 3: Install Windows XP to a new hard disk
    Use this method to install Windows XP to a new hard disk. This is typically done when a new hard disk is installed on your computer.
  • Method 4: Install Windows XP to a new folder (parallel installation)
    Use this method to install Windows XP to a new folder (parallel installation) to either run two operating systems, or to access, repair, or retrieve data from a damaged disk.
  • Method 5: Perform a multiple boot operation
    Use this method to install Windows XP as a separate operating system on your computer. This lets you install more than one operating system on your computer and select which operating system that you want to use every time that you start your computer.
To check the detailed information, check this Microsoft Knowledge Base Article.
http://support.microsoft.com/kb/316941
Hope this would help !!
Regard's
Anurag Shukla
Sep 08, 2009 | VIA P4X266 PE11-L Motherboard
Lost intallation disk
click this link: http://downloads.lexmark.com/perl/downloads/downloads.cgi
Just choose your operating system: Windows XP or Vista and you can download the drivers (installation software).
Apr 19, 2009 | Lexmark X4270 All-In-One InkJet Printer
Installed windows xp disk with a scratch and now wont boot up
If you have the Windows Key/License for the XP disk you can use someone else's copy of the XP disk or call Microsoft and ask for a replacement. You need the license and it must not have been installed on another PC previously.
Mar 14, 2009 | Compaq Presario 5000 PC Desktop
Proplem Installing Windows XP Home media edition
Unfortunately, you will need to purchase another operating system disc, even though you have the product key. That key is assigned to the disc that came with the machine. Why exactly did the Xp disc of your father's not work?
Aug 21, 2008 | Toshiba Satellite A105 Notebook
Heaven, here is the link for your software/drivers. Just follow the instructions on the page and you'll be all set. If this solves your problem, please don't forget to rate this as fixed. If you need more help just add a comment and I'll be glad to help you further. Thanks and have a good day.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-19447-3&lc=en&cc=us&dlc=en&product=90770&os=228&lang=en
Apr 22, 2008 | HP PSC 1210v All-In-One InkJet Printer
Lost installation disk.
Helloo
I Dont Think Anyone Gets An Installation Disc With A ROM
Wierd..........
Anyway U Should Just Plug It In (The Drive) And It Should Plug and Play Function. If You Are Running Vista or XP
OtherWise If A box Appears That Cannot Locate Driver Or Insert Installation Disc Like In Vista Just Browse My Computer From There and Put This Address to Search - YOur Win Drive
ex -: C:/Windows
And Search All Drivers Should Get Installed IF This Doesnt Work Just Comment Or If U Dnt Understand Just Comment On This I Have Some More Solutions...................................................................
Good Day.
Jan 13, 2008 | KHypermedia (KDVRW8X) (20730176) DVD+RW...
Lexmark X2330 Printer Logo
148 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
