My GE fridge model pss25ngnacc reached 91 degrees overnight. The freezer side seems to work however the frige gets hot. We have had it unplugged for days and when we plugged it in the same problem occured.
We had the same problem. it was caused by the light staying on after the door was closed. service tech replaced a faulty on/off switch
Is you freezer freezing if yes is your evaporator motor in the frezeer running.
if yes then it might be you damper assy that is not opening but on GE'S most of the times that run call with that problem the evap motor is not running does your frige have a computer at the back if you do then you have to trouble soot that computer or call a tech or just repl that board and if it doesn't work just return it
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
My GE profile artica model PSS25NGN was 99 degrees when I opened the door this morning. The freezer still worked fine. After I threw out all of my food I unplugged it for 10 minutes and then plugged in back in. It did cool down again, but the express thaw light is on every time I open up the door. I was wondering if that had something to do with it. The light switch works when you push it in, so I think that is fine. I am afraid to buy any food because I don't know if this will happen again. The warranty is up. Does anyone elses express thaw light keep coming on, and if it does do you think this has something to do with it?
Refrigerator heats up unexpected 90 plus degrees had the circuit board replaced 1 yr ago and it is starting again.
