Question about Samsung CLP-300N Laser Printer
My samsung clp-300 printer is very hot
My new samsung clp-300 printer is very hot on the back even when not used in hours
  • 1 more comment
  • salas007 Oct 20, 2008
    Same with my clp-300. Really hot at all times. It draws so much power at start-up; I have to use an ext cord from an outlet in the hallway.
  • bj-lee Oct 25, 2008
    I have problems with heat...I have had this printer for about a year and it seems to have developed this high heat problem...
    What gives?
  • Anonymous Nov 11, 2008
    brand new and very hot. Heat kills, so I got a bad vibe about the longevity of this printer.
    Champion:
  • 220 Answers
Low voltage power sully and fuser need replacing.fuser is overheating.
Posted on Jul 03, 2009
Mine is the same way, to solve this I elevated the bottum by 2 inches, then i kept it off, also i blow a fan on it while running.
also, you need to clean the filter (the gray "L" inside) black dust should come out.
lastly, mine actually broke because it overheated.
matt
Posted on May 28, 2009
  • Anonymous Jun 05, 2009
    mine is the same way, to solve this I elevated the bottum by 2 inches, then i kept it off, also i blow a fan on it while running.
    matt
4 Suggested Answers
  • 12 Answers
SOURCE: Samsung CLP-300 Laser Printer partially faded prints and noise from the drum
The manual says if you are getting this clicking noise that the imager is loose and to take it out and reinsert it. This is the device that all the toner cartridges are inserted in. It just Pops out so it is easy to remove and reinsert. What happens is it gets loose in shipping sometimes and just needs to be reseated.
Posted on Jun 02, 2008
SOURCE: new trouble with my samsung CLP-300 printer
Can't believe the geniuses at Samsung didn't respond to this. I had the same problem and as usual, I started tinkering.  Two solutions: 1. Remove the used toner reservoir(located left on the toner cartridges...light grey, "L" shaped object) and discard(be environmentally aware).  Replace with new one. or 2. (My choice) Remove reservoir, empty contents carefully.  Wash thoroughly with cold water until water is clear.  Dry thoroughly with paper towel and blowdryer. Light must be clearly visible through the little magnifying bubble on the side. Works everytime.  Be patient. This takes about 5 minutes.  Can be very messy if you are not anally retentive as I am. :)  Al
Posted on Mar 03, 2009
  • 220 Answers
The chips on cartridges are causing the problems.
Posted on Jun 24, 2009
My Samsung CLP-300 Laser jet is "burning" the ink when printing mostly dark colors which causes it to bubble and flake off the paper.
What kind of paper are you using? This printer does not work well with glossy paper and will do the things that you have described. Try using ordinary 20 lb copy paper and see if this makes a difference. If you are already using copy paper, then the problem is with the fuser, getting too hot.
Aug 02, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Printer
smasung clp300
just clean toner weast chember and also drum unit.
sometime if u user refilled cartridges after use this u have facing this porblme.
pl do this it work perfect.
www.howtorefill.com
Jun 02, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP300 - All LED lights red and getting very hot when on
drl1069.dyndns.org/Public/CLP-300.pdf Ok above is your service and repair manual, inside is all troubleshooting procedures used by the engineers to troubleshoot and repair these units.
May 11, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP-300 printer, very poor black coverage
it is most likely your OPC Black Devloper is faulty which you will get uneven print out.
you will have to get it replace on the black dev (E)
laser printer got to run once every week if not the same issue will come back again & further more if your table is uneven it will cause this issue too.
May 09, 2010 | Samsung CLP 300 Laser Printer
Samsung printers are far from the best. I have the same printer and it needs a Fuser. The fuser part costs more than I paid for the printer and it's a little over a year old. Samsung will not sell me the part but will repair the printer for $135 plus the part which costs over $135. Shipping is $20. I only paid $141 for the printer. I'll stick with Epson and to hell with Samsung.
Mar 17, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP-300 Printer not printing black well
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It's best to do this each time you install a new cartridge. get more information and help from here .
Jan 10, 2010 | Samsung CLP 300 Laser Printer
Heat and electrical smell
The smelland heat is probably from the fuser as it gets extremely hot, if the printer's new it might settle down. No you shouldn't have to turn the printer off when not in use.
May 11, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP-300 printer is not recognized by new MacBook
Thank you for mentioning it, I can't believe it was the reason. It worked! Fabulous! I put about 8 hours figuring it out.   M.L.
Dec 07, 2007 | Samsung CLP 300 Laser Printer
Samsung CLP-300N Laser Printer Logo
667 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
