No color on our color tv
The color just stopped working. if we hook up a different tv to the cable jack we get color on the tv
    Champion:
  • 252 Answers
Re solder your tv, then change the crytal value 3.579 it is a rectangular metal with 2 pin beside the jungle IC.
Posted on Oct 16, 2008
How to hookup a bose 321 to a toshiba 58l7300 tv
The Bose system does not appear to have HDMI output. The best-quality method would be to use Component (RGB) cables with analog audio. One RCA pair will be for audio and these are often RED & WHITE connectors, but don't have to be. Any RCA pair will work. Connect these to the Bose RED/WHITE jacks found in the "TV" labeling. Connect the other ends to the Toshiba's RED/WHITE jacks on the bottom row, first two jacks.
Now you need a Component cable. This has three RCA connectors at each end and are traditionally RED, GREEN, and BLUE. Again, colors do not matter as long as you connect the ends so they match. Under the "Component" labeling on the Bose, you will find the three colored jacks. Connect these to the Toshiba's same-colored jacks which are next to the RED/WHITE ones you used previously. These three connectors carry the video signals. They will transfer Hi-Def 1080i signals, not 1080p, but you wouldn't be able to tell the difference.
Switch the input on your TV to "Component".
Dec 29, 2013 | Toshiba Car Audio & Video
How to hook up a cable remote to a Samsung cable box?
    • 1 Examine the back of the your cable box and the back of your Samsung HDTV. Note which cable jacks are of an identical size and color. Those are the ones that can be used to connect the two devices. Samsung HDTVs cluster all the jacks in a single panel near the power cord.
    • 2 Look at the square rectangular boxes labeled "HDMI In." These are for high-definition multimedia interface cables--combination A/V cables that provide the highest possible image and sound clarity. Look at the back of your cable box for an identical jack labeled "HDMI Out." If you see one, connect the two jacks using an HDMI cable. If you don't, you need to use another set of cables to hook up your cable box.
    • Sponsored Links
    • 3 Check for a series of three round jacks labeled "Component In" and color coded in red, green and blue. These are component video jacks, which provide a good HD picture, but not as good as HDMI. If your cable box has an identical set of "Out" jacks, use them to connect the two components.
    • 4 Look for a pair of red and white jacks (possibly connected to a yellow one). These are audio RCA jacks. If you're using component video cables to hook up your cable box, you will need to hook these two up as well: Component video cables don't provide sound. Any cable box that uses component video cables should also have "Out" jacks for RCA audio cables.
    • 5 Find the raised circular jack with a pinhole in the center of a milky white plastic interior. This is the coaxial jack. Samsung HDTVs label them "Ant In." Every cable box should have a corresponding jack labeled "Out" or "Ant Out." If none of the other cable jacks on the cable box match, use a length of coaxial cable to connect the TV to the cable box through these two jacks. You can also use this connection to hook the TV directly to the wall cable.
    • 6 Turn on your TV and cable box, and set the TV to the input jack connected to the cable box. You can do this by pushing the Menu button on the remote, scrolling down to the "Input" option and pushing "Enter." That will let you cycle through the various input options, labeled by cable type (HDMI, component video). Press "Enter" again when you reach the right component, then exit the menu. You should now be able to watch TV as normal.
Read more: How to Hook Up a Cable Box to a Samsung HDTV ' eHow.com http://www.ehow.com/how_4867255_hook-cable-box-samsung-hdtv.html#ixzz2DwgQRtRE
Dec 03, 2012 | Televison & Video
MY TV will not show color on the tv .I have a protron PDS2315 .I don't have the cables that came with the DVD player Does that make the deference?
Hi zapchenk,
First of all, thank you for posting your question here at Fixya.com.
The most common caused of "No color" fault when viewing movies through DVD player are :
1. Wrong TV/DVD format - If your TV is a NTSC system format and not knowingly your DVD player is set to PAL/Secam system format, then there's no color generated to your TV due to incorrect video frequency signal coming from the DVD player.
Solution : You have to sync/match the system format of the TV and DVD player. Check first the system format of the DVD player through the menu. Try to change it from PAL/Secam to NTSC.
2. Wrong hooked up - Since the problem is in video, you have to check the video hooked to your TV and DVD player. HDMI jack is the best option to avoid wrong hooked up because it come with Audio and Video in just one cable. If you are using one RCA cable to connect the video, make sure that it is hooked up to Video in of the TV and Video out of the DVD player, it is usually color yellow RCA jack. If you are using the component video hooked up, you must have 3 RCA cable for video alone. It is color coded as green(Y), blue(Pb/Cb), and red(Pr/Cr) RCA jack.
My advice is to check first the system format and then the video hooked up.
Hope I helped you.
Have a nice day!
Good luck and take care!
Kind Regards,
Jdvillanueva
Dec 10, 2011 | Televison & Video
I need help getting a manual for my tv so i can hook my dvd vcr combo up My tv is a 37ld450 flat screen> If you dont have info on ownners manual can you help me hook up the red yellow white wire...
What is the name and model of your tv?
There are two ways to hook up a dvd/vcr to at tv.
1. Coaxil Cable - From VCR Cable Out To Tv - This goes to the tv cable jack. Tv should be on channel 3 or 4 to use it this way.
2. There are Yellow, Red, White Jacks on the vcr/dvd player. There should be a couple sets actually. One set should say OUTPUT on them. The colored jacks go from the vcr/dvd OUTPUT and goes to the same color jacks on the tv that say INPUT
TV must be on an A/V or Input channel for this to work
That is about all there is too it. If you need more info, just let me know. I am more than happy to help.
Mar 30, 2011 | Televison & Video
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
I have a cablevision box with a set of red, green and blue wires and another set of red and white wires. How do I hook the cable to tv to get cable? The colors on the front and back of the Mickey tv are...
hi. The colored cord you described are for high definition, there should also be some jacks on the back of the cablevision box that say "video out" "left""right"
Find those, and the video out is the yellow in jack on Mickey, and the Left is the white jack on Mickey
If you can't find those, then use the cable tv out from the box to hook it up to your tv.
This is all that is needed to hook up really, just the coax cable from the box to Mickey.
I know Mickey has a antenna cable jack on the back.
Just run a cable from the box to mickey, put Mickey on channel 3, or 4, depending on what the setting is on the box, and you should be good to go!
Feb 08, 2011 | Disney DT1300-C 13" TV
I'm installing 2 phone jacks in my newly remodeled home. We are supposed to have one phone line. Each of the boxes with phone wires in them has two cables coming out of it. In the first box, the one cable...
Pity that whoever did your remodel didn't give you a floor plan. In new construction, we make everything go to a central point. Old style was to loop everything through. It would be easy to tell, because you'd see the loops.
If you want to do this yourself, and save some money, give this a try.
The color code is that the green/red/black/yellow go to the jack. Hook all 4 wires (8 because you're going to hook both cables together to a jack) to the jack. Then, down the road, when someone has to add a second line they won't have to open this back up again. When it comes to the paired cable, look at the wires. One of the wires has more white than blue (White/Blue lead) and one has more Blue that white (blue/white lead) and so forth. You're going to be working with the blue pairs and the orange pairs, and spare out the green and brown pairs.
Strip the 4 remaining wires (the ends so they can go on the screw terminals) and connect them as follows:
White/Blue to Green Blue/White to Red White/Orange to Black Orange/White to Yellow.
If you're using Insulation displacement jack (the kind with caps where you push the wires into the slots), STOP! You're going to need more parts.
Mar 31, 2010 | Lands Phones
Tried to hook up hd cables and seems good but no audio tried to hook up but can't get to work
You cannot get AUDIO from Component Video, as it is only VIDEO, you must get another set of Cables RED & WHITE, and connect them from the AV, AUDIO Jacks, OUT on the "Sender" The DVD, Receiver etc, to the AV AUDIO IN on the TV. So you will have 5 Cables connecting BOTH Video & Audio. The Component Video, uses Blue, Green, & Red, these go color to color on the RCA Jacks at BOTH ends PLUS the Red & White Audio, color to color at BOTH ends. .Hope that clears things up.
Feb 14, 2010 | Hitachi 46W500 46 in. TV/DVD Combo
How do you make the dvd player work
This is the Apex SUPPORT website have a look around in here and see if it helps>
http://www.apexdigitalinc.com/support.asp
Aug 31, 2009 | Apex Digital AD-1600 DVD Player
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
