Question about Canon imageCLASS D320 All-In-One Laser Printer
Printer will not print: Canon imageCLASS D320
What does supply rec. paper tray:A4 mean?
  • 2,012 Answers
The paper size selected in the menu system must match the paper size in the rec. (recording) paper tray. If you have 'letter' size paper in the tray and the menu system is set for 'A4' paper you will get this message. Either put A4 size paper in the tray, or change the paper size in the menu system to 'letter'.
Posted on Oct 16, 2008
I CAN NOT PRINT FROM WORD OR EXCELL DUE TO THE PRINTER DEFAULTING TO A MESAGE - SUPPLY REC PAPER. ICAN PRINT EMAILS ONLY.I CAN PRINT FROM ANOTHER COMPUTER BUT NOT MY LAPTOP. IAM USING XP AND OFFICE 2007....
in the Printing Preferences under the A4 setting there in a setting that is probably set as Match Paper size. You will have to set that olso on A4 format.
Let me know how that works.
Jun 06, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
Light under memory/alarm is flashing red. Window
if the error is change paper size also, under printer properties set the paper size i.e. A4, by default its ltr and these can cause problems.After that turn off and on.
Hope that helps.
If not, send more detailed description.
Aug 27, 2010 | Canon imageCLASS D320 Digital Copier
Supply rec. paper tray:ltr
1) unplug machine from power supply.
2) Under printer properties, select custom paper size and set it on A4 if you use A4.
3) Power on the machine and then try to print.
Hope that helped
Jun 29, 2010 | Canon imageCLASS D320 Digital Copier
Flashing supply rec. paper tray legal
I pressume that you try to prin something out.Is this true?
Turn off and on the copier.Under printer properties, under page setup, mark the appropriate paper size, eg. if in cass. A4, in the drivers must be A4.
Jun 07, 2010 | Canon imageCLASS D320 Digital Copier
Supply rec paper tray - what does this mean when the tray is loaded?
OK, I was having a similar problem: Tray full of paper and tray adjusted properly.
Whatever I tried, the printer kept saying load paper.
I went to print menu>properties button (windows XP this is next to the printer name)>paper source tab.
It tuned out that the paper source had been changed from cassette to multi-purpose tray.
Change it back to cassette and you should be golden.
Jun 03, 2009 | Canon MF8180C Color Laser MFC Printer
Machine won't print, copy or receive a fax
With red button stop the copy, or switch off and on.
If you print on this unit make sure that you did choose a right format of paper (A4,A5,...)
You can change the format ap printer properties or preferences
May 21, 2009 | Canon imageCLASS® MF6550 Laser Printer
"Supply Rec. Paper Tray : LTR"
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
I do not have a manual. What does supply REC. paper mean?
supply rec paper mean stay paper in copier cassette or that the paper print
it is mean insert paper in cassette
Dec 16, 2008 | Canon imageCLASS D320 Laser Printer
Canon Imageclass D320 supply rec. paper malfunction
My problem was that I was trying to print from a PDF file. I found out that the file was legal size and that the setting for the printer to "choose paper source by PDF size" was checked. I unchecked it so that it would print on letter size paper. Hope this helps
Jun 05, 2008 | Canon imageCLASS D320 Digital Copier
Canon imageCLASS D320 All-In-One Laser Printer Logo
899 people viewed this question
old marine
old marine
