Question about Cell Phones
Function openfolder failed - Cell Phones
    Brigadier General:
  • 7,752 Answers
Master reset or reflash the firmware on the phone this can be done by going to topsony.com or try a mobile service center close to you
Posted on Oct 15, 2008
WHY THE FREEZER FUNCTIONS BUT THE REFRIGERATOR SECTION DOES NOT FUNCTION ON A GE PROFILE BRITA FRIDGE?
Check for failed evaporator (cooling coil) fan motor, located in the freezer or a failed component in the automatic defrost system.
Sep 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
Panasonic VCR/DVD combo - stopped recording sound
Seek tech support. This is not a self repairable work. Need technical skill.
Jun 02, 2012 | Panasonic DMR-E75V DVD Player/VCR
Cant get my dimplex club electric fire to come on
Do the rest of the functions of the fireplace work? If so, turn the Master On/Off Switch to OFF and plug the unit for 12 to 15 minutes. After the time has elapsed, plug the unit back it and turn the Master On/Off Switch to ON. Then turn on the flame function switch. Hopefully, that timeout allowed the unit to reset itself and the flame function is now working. If it isn't, either the flame function switch is faulty or the circuity to the light bulbs and the ro-tater motor that turns the shaft, that he bulbs are attached to, has failed. Without knowing how old the unit is and how much use it's had, it's hard to pin down one thing that is causing the problem. If it's any consolation, you are not alone. Hundreds of these electric fireplaces (all makes & models) fail every year.
If all else fails, contact Dimplex USA, Technical Service at 888-346-7539.
Hope this helped to solve your problem.
Mar 17, 2011 | Heating & Cooling
Both headlights quit working simotaneously
There are just (3) possible reasons for this:
(a) your headlight switch has failed, or
(b) your headlight relay has failed.
(c) Fuse 1 (25 Amps) has blown
The headlight relay and fuse 1 are located (I think) in a fuse/relay block under the hood.
The headlight switch is part of the "Multi-function Switch" on the steering column.
Here's how to replace the 2001 PT Cruiser multi-function switch:
Multi-Function Switch Removal & Installation
1. Open the hood.
2. Disconnect and isolate the battery negative cable.
3. Remove both upper and lower steering column shrouds.
4. Disconnect both posi-lock harness connectors at the rear of the multi-function switch.
5. Remove multi-function switch mounting screws and remove switch from vehicle.
To Install the new multi-function switch:
Note:
If replacing the multi-function switch, the combination flasher and windshield wiper/washer switch
must be transferred to the new multi-function switch.
1. Remove the two Torx(R) screws retaining the wiper/washer switch, place next to the new
multi-function switch and install two screws.
2. Place switch into place and install mounting screws. Torque multi-function switch to column
retaining screws to 27 inch-lbs. (3 Nm).
3. Connect both posi-lock harness connectors at the rear of the multi-function switch.
4. Install both upper and lower steering column shrouds.
5. Connect the battery negative cable.
6. Close hood.
7. Verify vehicle and system operation.
Mar 15, 2011 | 2001 Chrysler PT Cruiser
Fail to Function
Sorry you are having trouble.
The grinding sound is a mechanical failure. It does not sound serious to me.
A trip to the shop will be needed as it sounds like there is a part or two that have gone bad.
Hope this helps
Apr 04, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Keyboard keys share functions. Right shift key inserts a z and then shifts. z key does the same thing . Left shift key tabs and then shifts. 9 key and = key both give =9. Other keys also share...
1. try to do system restore first from the time system was working fine. reboot system. if fails.
2. update your anti virus then run a full system scan. reboot system. if fails.
3. update the bios. download the latest bios for your system from the dell support drivers and download section. reboot system. if fails.
4. reseat the keyboard cable. if fails.
5. reinstall the OS. if fails
6. replace keyboard.
Oct 25, 2009 | Dell Inspiron 2200 Notebook
85 volvo dl fuel evaporative control functional (failed) @ smog check
replace the pvc valve and have the egr valve replace.make sure the vacuum hoses connect to egr valve and pvc replace.change air filter.all those things will cause high emission if not working properly.cause you to fail smog test.
May 31, 2009 | 1985 Volvo DL
GE Spacemaker microwave won't heat food
hello kmwnky,
You say that Everything went out at first ( which I assume means that all functions went dead) and then functions started to operate again later... if that is correct and you smelled something burning.. you may have a thermal fuse that failed, filament transformer that failed, magnetron tube that failed or a highvoltage capacitor that failed.. None of these components are something the untrained person should attempt to trouble shoot or replace since there are dangerous energies stored inside the electronics compartment even after power is removed.. Your Micro is > 8 years old and it's probably not worth the cost of repairing at this point. You'd be better served replacing it.. The cost to repair would exceed the cost to replace.. ( I feel like the grim reaper here..sorry..)
Regards,
Rick
Nov 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Printer not functioning!
Please write the EXACTE Error. What do you mean by posting: has failed function?
Nov 18, 2007 | Brother MFC 210C All-In-One InkJet Printer
Cell Phones Logo
75 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
