Question about Garmin GPS
Unit will not power on. Checked fuse and replaced. Tried to use battaries. Tried plugging unit in with the usb cable.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Model please??????????????????????????
Garmin streetpilot i5
Posted on Oct 16, 2008
Doesn't want to stay on
If your GPS unit powers down before it can fully boot up, use the steps below to charge the GPS unit and test the vehicle power cable:
  1. Connect device to a computer that is powered on
    • The unit should power On when you plug it in showing a computer plugged into the GPS unit on the screen (Mass Storage Mode)
  2. Press Reset button on the bottom of device if it does not power On*
  3. Allow the unit to set and charge for 3-4 hours
Once the device is charged please take it to the vehicle and test it on the vehicle power cable.
  1. Connect the device to the vehicle power cable
  2. Connect the vehicle power cable to outlet on vehicle
  3. Power the vehicle On
  4. Device should automatically power on
    • If a battery icon appears directly to the left of the time then it is not receiving a charge from the vehicle
    • Please check the fuse in the vehicle power cable
      • The end of the cable unscrews to reveal this fuse
      • Check to make sure the wire element inside the fuse is in contact and that there is no discoloration.
      • If you see either of these the fuse needs to be replaced with the replacement fuse specifications listed on the sticker attached to the cable.
      • If the fuse looks good and there is still no light, the vehicle power outlet may need to be checked to see if it has power.
*Note - The reset button may be found on either the left or right side. In some cases if the device does not have a reset button slide the power key to the left or On position for about 10 - 15 seconds.
Oct 23, 2010 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 265 keeps shutting off
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sounds like a bad or low battery. Do you have the Garmin approved charger / car charger?? You may have to send your 265 in for battery replacement or try this:
There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F respectively) then it will not charge. When connected to external power it will only be operating off of external power.
2 - The Quest® and Quest® 2 will not charge using a USB cable.
Dec 27, 2009 | Garmin Nuvi 265W GPS Receiver
My nuvi 260 will not display anything . It turns on okay with the Garmin introduction and then screen goes blank
Sounds like a battery problem. You may have to send to Garmin for replacement of the battery as it's not user fixable. I also highly suggest using a Garmin approved charger/ car charger if you don't have that!!
Or understand this:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
Oct 06, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 265W just will not switch on!
Bad or very low battery
Replace at Garmin
But first know this:
Aug 06, 2009 | Garmin nuvi 265 Car GPS Receiver
Clicking sound and in use/memory light flashes. Canon PIXMA MX850
I had this problem and found that I had plugged the usb cable into the wrong plug hole. I had tried a reinstall of teh printer which failed when it tried to recognise that teh printer was on and connected. When I moved the usb cable to teh correcr socket (closest to teh side of teh printer) it was fine.
Brian
Jul 13, 2009 | Canon Office Equipment & Supplies
Why doesn't my garmin nuvi 200 gps system charge?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sounds like a bad or low battery. Do you have the Garmin approved charger / car charger?? You may have to send your GPS in for battery replacement or try this:
Jun 30, 2009 | Garmin nuvi 200W GPS Receiver
My garmin nuvi turns on for a second then turns back off whats wrong?
Jun 10, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi unit was indicatig battery charging when i . conneted to my computer. I removed and tried to turn this on ...it did not and then I have re-connected to my computer again and even tried to...
It take a day to charge the 260 WITH the correct cable for your computer as it will only trickle charge it.
Car charge does it in 2 - 3 hrs. If car is not charging it check the fuse in the end of the charger
And:
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
Jan 04, 2009 | Garmin nuvi 260W GPS Receiver
Unit doesn't work with vehicle power cable
if you are using the USB cable, that won't work. You must use the bracket plug. the USB cable will charge the unit and you can't use it while it's charging. If using the USB, the system thinks you are either charging the unit or connected to a computer. This is a design flaw.
Jul 04, 2008 | Garmin nuvi 200W GPS Receiver
GARMIN STREET PILOT-330 GPS
Hello KTFORE1,
The Street Pilot 330 comes with both a vehicle power cord and a USB cord for connecting the unit to the computer. If I understand you correctly the GPS isn't getting power from the vehicle power cord. Does the GPS charge if connected to a computer using the USB cable? If so the problem is likely the power cord or cigarette lighter socket you are using. If the GPS doesn't charge from USB port on your computer then the problem is likely the GPS itself.
If you determine that the cable is the source of the problem, check and replace the cable's fuse. You will probably also want to check and replace your vehicle fuses as the circuit that powers the cigarette lighter might have a blown fuse. If replacing the fuses doesn't solve the issue then you might need to replace the power cord.
Best Regards.
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
48 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
