Question about Kitchen Ranges
Wirlpool accubake system code E3F1 oven failure
  • Anonymous Apr 17, 2009
    Can you not hold a button down for reset
3 Suggested Answers
huuum
  • 750 Answers
SOURCE: wirlpool oven accubake system problem
What is your model number?????????????
trying to help!
Posted on Oct 16, 2008
huuum
  • 750 Answers
SOURCE: oven not working on wirlpool
Hello perryalpha,
Welcome
You said, your whirlpool oven Accubake system problem code E3 F1
Either way, it prints out as the fault codes E3 -F1 or F3-E1 this code calls for this repair listed below!
Fault Code F3 - E1 Oven temperature sensor shorted = Replace oven temperature sensor
let me know how the repair goes.
Thank you,
Huuum
Please remember to leave me a solved rating
What is the problem with a wirlpool accubake code E2, F1
Hi
Error code F1-E2 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Whirlpool Ovens
The oven doesn't work
unplg the system for 15 minutes then plug it back it. When you plug it back in make sure everything goes in straight. this is just trying to reset the system
Jan 02, 2010 | Whirlpool Accubake RF362LXTS Electric...
Whirlpool Gold Accubake Duo. ''E4 - F3'' or ''E0 - F3''
HI. These codes are an indication of oven temperature sensor failure. The sensor is damaged. This will not allow for proper operations. The affected part must be replaced, asap.
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner.It will look like a 4 inch long slender probe. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Dec 28, 2009 | Kitchen Ranges
Wirlpool gold accubake system is not working properly. Broiler works but oven does not heat up properly
If your broiler is working but not the oven, you just need a new bake element. This is a very simply part to replace. Just give us a call or email us with your model number and we;ll send the correct part out to you right away. 972-859-0929. We'll ship this to you and you'll be cooking in no time! We look forward to working with you and hope to hear from you soon. :>)
Oct 03, 2009 | Ovens
I am getting a PF code - I have a self cleaning - accubake system electric silver with black top and sides - not sure how old the oven is
the "PF" simply indicates at some point the power to the unit failed, hence the "PF" (power failure). turn the range breaker off for a minute or two, or unplug it for said amount of time. after that if you push the cancel bottun on the control it should go away, then you can set the time of day/clock etc.
If that doesn't get it right, make another post on here and we'll go from there.
hopefully it's that simple :)
good luck
Sep 29, 2009 | Whirlpool Ovens
My whirlpool accubake built in oven has error code E1F1 due to a power failure. How do I fix this?
It is always a good idea to include both model and serial numbers when requesting help on any appliance... but try...
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
May 06, 2009 | Whirlpool RBS305PDS Electric Single Oven
Oven clicks to self cleans or f3, the door locks and food burns
Replace the oven temperature sensor.
Take your model number to any appliance parts store for a replacement sensor.
Apr 20, 2009 | Whirlpool Accubake RF362LXTS Electric...
Wirlpool oven accubake system problem code E3 F1
trying to help!
Oct 15, 2008 | Kitchen Ranges
Oven not working on wirlpool accubake system
I have a Whirlpool Accubake System stove / oven. About 50 p% of the time I go to push the "Bake" and "Start" button, it goes to "Cal" or "EO -F2-" what ever that is. It won't let me clear it . Needless to say I am not happy with the fact that when I go to bake something, the oven doesn't work!!! Please help!
Oct 15, 2008 | Whirlpool Kitchen Ranges
Kitchen Ranges Logo
166 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
