Question about Lexmark Office Equipment & Supplies
I have a lexmark2500 series all in one printer but it only does copies and scans not printing.when i installed it on my computer but no solutions, please help me out
    Genius:
  • 1,124 Answers
If you are having problem with your printer, do the following:
Check all connections first (if necesary replace the cables)
Be sure the printer is ON
Go to Printers Folder (Start >> Control Panel >> Printers) And be sure your printer status is marked as "READY"
Check the port that the printer is using (Start >> Control panel >> Printer >> Port)
(if your printer has USB cable must be appear connected to USB Virtual Port)
Go to printer folder and Cancel all pending printer documents (queue)
Turn off your printer
Turn off your computer
Turn on both and try again
If still not working uninstall and install the printer software again
This will fix your problem.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Posted on Oct 15, 2008
  • Pablo Csaky
    Pablo Csaky Oct 15, 2008
    Check the status of your cartridges
Lexmark pro 900 will not print properly or copy or scan
There is a firmware update for the Lexmark Pro900 Series printer that addresses print quality issues. Please visit the Lexmark website to download and install the Lexmark Pro900 Series Firmware Update.
After successfully updating your printer, try to print, scan or make a copy again to verify that the problem is fixed.
Should the problem continue, it might be a printhead problem. Please contact Lexmark Technical Support Center for further assistance.
Dec 29, 2011 | Lexmark Office Equipment & Supplies
Once a doc is scanned on a 8300 series all in one, how do I get the scanned image from the printer to a word doc? Looked
You can actually scan directly to an application(ex. MS Word application). Also, make sure the Lexmark OCR scan software is installed on your computer (the software is available on the install disc that came with your printer).
1. Load an original document into the ADF or on the scanner glass. 2. Press Scan Mode. 3. Press ? or ? repeatedly until the MS Word application is highlighted. 4. Press check button. 5. Press Start Color or Start Black to start scanning.
Source: Lexmark 8300 Series User's Guide page 72.
May 14, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
My HP PSC 1500 printer won't scan.
if it is still printing and copying it will probably be down to the adresss of the folder that you had you will have to set up the folder again and install the scan driver as well if you go to run and input you ip address for the computer it should show any folders you have set up and give you the address ie 192.168etc and then//scans if that was the name of the folder to get your ip adress go to run and typoe ipconfig this will give the details of you computer.. good luck A
Jun 16, 2009 | Office Equipment & Supplies
My Dell (vista) computer does not see the lexmark x2500?
I got a new hard drive. The disk will not install. So I need to install. I have a Lexmark 3-into-one 2500 series.
Apr 06, 2009 | Lexmark X2500 All-In-One Printer
C3180 will not scan
If you are getting this message when you are trying to scan from the All-In-One.
And If the software is successfully installed in your computer, then you should have a icon in your desktop as HP Solution /HP Director (if not got to Start> All Programs>
HP> HP Solution Center)/HP Director Then try scanning from there, if you are able to scan from there then try the steps bellow.
Open solution center> Settings> Scan settings> Scan to setup> Then in this window click on Restore defaults> Then apply or ok and close all the windows and try to scan from the
All-In-One printer.
If it still does not work then try the bellow steps:
Go to:
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
And if the software is not installed the you will have to install the Printer driver / Softaware Sucessfully first.
Good Luck
Oct 05, 2008 | HP Photosmart C3180 All-In-One InkJet...
Hp laserjet m1319 mfp series
Are you using the software that shipped with the machine? I use the" HP Scan To" program which allows me to scan it to a slew of file types.
The only downer: I can't put the software on more than 1 computer. Apparently, it recognizes that the printer is hooked up to another machine and won't let me install any drivers on other computers (except the print driver).
Sep 25, 2008 | HP Laserjet M1319F Laser Multifunction...
I lost the cd to install printer need another way to use my lexmark2500 printer
Hey there
Click Here for the Lexmark Drivers and Downloads page.
Type in X2500 to the search box
Select your Operating System and follow the prompts.
That should get you going.
Mike
Sep 19, 2008 | Lexmark X2500 All-In-One Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
