Question about Sony Playstation 3 (PS3) Console
Ps3 went off and then came on with a blinking red light
Playing game, ps3 went off, turned it on and it first went green light, then yellow, the flashing red light. I have never had a problem with this ps3 before. Any ideas of what might be wrong or ideas on how to fix it?
    Novelist:
    Scholar:
  • 68 Answers
There are many reasons to cause PS3 turn off and goes green, yellow and red then blinks. It's waste your time and money if you send to somewhere repair - because the same problems will be back after then. The best way is to learn the repair techniques of yourself. There is a PS3 DIY Repair Guide : The author use text and video to show you how to use your hands to open your console and do some maintenance and fixes, at last you are amazing that why you can do that yourself. The best part is you can help your friends too!
Posted on Aug 20, 2010
    Sniper:
  • 85 Answers
Heat sync problem. CPU and GPU need re-seating as well. email dwdpcrepair@gmail.com for more information
Posted on May 16, 2009
Phantomgreen
  • 128 Answers
SOURCE: my ps3 wont turn on. light turns green, flashes
This is known as the yellow light of death.(ylod) It's about 150 bucks to have it serviced unless it's still under warranty.It says in the manual it is an overheating issue.
As for your problem, call customer support at 1-800-345-SONY
Posted on Mar 26, 2010
ripleymojica
  • 643 Answers
SOURCE: PS3
sounds like powersupply is bad. you can find one on ebay for about 40. not that hard to replace yourself. hope that helps.
Posted on Jul 01, 2009
JEFerrer
  • 87 Answers
SOURCE: Tried to play a game but the ps3 green light
Try following the 8 Steps to Troubleshooting Any PS3 Issue.
  • 1139 Answers
SOURCE: playstation 3 wont turn on
What you are referring to is called the Yellow Light of Death (YLOD). This indicates a general hardware failure normally due to overheating. When these PS3's were produced Sony decided to use lead free solder. The problem with lead free solder is that it is not as flexible as leaded solder but it is cheaper and more environmentally friendly. When the console gets hot and cools down hairline cracks appear within these solder joints and a good electrical contact cannot be made. This then causes the console to fail. It could be on a number of different components including the CPU, GPU or memory. There is a temporary cure that may or may not work but ultimately the console will need to be repaired professionally or replaced. As it is out of warranty Sony will not replace it but will offer a refurbished unit for around £130. If you look on Youtube for Yellow light of death fix there is a way that you can re-heat the solder joints using a heat gun but if you are not confident taking apart electrical items then this really may not be something you want to try.
I am sorry I cant give you any better news but unfortunately it is a very common problem with the PS3.
Hope this helps and thank you for using FixYa
Posted on Sep 13, 2010
gameaction
  • 89 Answers
SOURCE: green light then yellow light then blinking red light
If you don't want to find information on the web to resolve those PS3 red light blinking problem, take a look at PS3 Repair Guide . It is an all-in-one guide that fix many people's PS3 till now.
Posted on Nov 26, 2011
My PS3 was playing great the other night (playing Modern Warfare) and out of nowhere it turned off on me with the red light blinking. I tried to turn it on and the red light went solid like it normally...
It sounds like you have the dreaded Ylod its a common issue, Try resetting the system which works once in every systems,
If that does not work then you will most likely need to replace the Power supply, if your uncomfortable opening it,
Look on craigslist to see if there are any local repair shops in your area, that is uaually a 60 dollar fix on average but depends where you live.
Sep 10, 2010 | Sony Playstation 3 (PS3) Console
I was playing a game and it just shut off. It went to a red light on the left side. If I try to turn it on, the left light goes green, then yellow and right back to red and never engages.
If it continues to blink a red light when it turns off, this is known as the yellow light of death (ironic i know). This is caused by the unit overheating causing the solder on the board to melt and bridge(connect). Once this happens it shorts out the board causing the error you have now. Contact Sony and see if the unit is still under warranty.
Feb 05, 2010 | Sony Playstation 3 (PS3) Console
PS3 shuts right down to a yellow then a blinking red light
There are some reasons of PS3 goes green to yellow and red light with disc stuck. But don't waste money to find someone to fix it yet! It may be a minor issue that you can be fixed by yourself.
Remember, you are not the only one to suffer this problem! Because I had help so many people to fix the same problem now. You are so lucky to be there. I share a guide for you - It make me like a pro to help my friends and many people. It is too expensive to send back to Sony repair if your machine is out of warranty!
I had solved the same problems after bought this guide. The author of the book is really kind and helpful to his customers. May be you can buy it and share what you have learned !
PS3 Ultimate Repair Guide
Dec 24, 2009 | Sony Playstation 3 (PS3) Console
Green light to yellow in 1 sec then blinking red light
Hrm, is it well ventilated? Is it in an enclosed space? Try putting it out in the open so all the vents can properly breath. If that still fails to work you may have to get it serviced. You can contact sony at:
http://www.uk.playstation.com/Support/PS3
or
http://www.us.playstation.com/help-support/PS3
Hope this helps. Also be sure to rate if it did or not.
Jun 24, 2009 | Sony Playstation 3 (PS3) Console
Red light green light yellowlight red blinking light
From what I understand its a problem with the backwards compatibililty(the engine/drive that lets you play ps1/ps2 games)on the 60g.Sony says they have never heard of this problem yet these models are no longer in production.I have had mine for 2 years and it died today,same problem.
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
PS3 Green then Yellow flash then blinking red
or you can try to get your money back if you hve a receit i say give it bak and get you a new one. or see if you can find one ebay or game stores
Jun 01, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't start
u have to wait for about 30 mins before turning it back on
coz when it does that it's tired
hope this helps
Sep 19, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
224 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
