Question about Dishwashers
Kenmore dishwasher model 363.15322100
Dishwasher comes on but water does not come into the machine and from looking at the schematic it appears the problem would be the water valve,flood switch,or the timer. what is the most common failure
  • halfay Oct 15, 2008
    no water coming into the machine
pnoble194
SOURCE: flood protection is activating
I have had the KUDD01DPPA drawer dishwasher since 12/30/05. The "Flood Switch" has been activated 8 TIMES. Our dishwasher is not freestanding - it is under the counter; therefore it does not move. Tilting it would be impossible. We've had service on it twice. There answer to us was to "shut off the breaker for several days and see it that works." We need another dishwasher!
Posted on Apr 16, 2007
Had the same problem on a Miele mashing. In my case trying to clear a drain blockage in a kitchen sink had probably forced water back into the washing machine and caused an internal leakage. Rather than remove the whole machine and tip it over, I opened the small panel at the front bottom (behind the skirting panel) (needs 'special' screwdriver for the 2 screws) and removed the water that was lying on the base of the machine. Not much (less than 5mm) but enough to lift the white polystyrene float (a round disc about 10cm diameter) which was activating the micro-switch and causing the F70 message.
Posted on Apr 13, 2008
  • 11 Answers
SOURCE: Dishwasher leak
ya
Posted on Jan 23, 2009
  • 3 Answers
SOURCE: Dishwasher does not drain, instead drains through overflow valve in sink. No apparent clog seen.
Usually the sink connection is not an overflow, it is the main drain from the dishwasher. It is more likely your s-bend is blocked under the sink- try putting a bucket under it and unscrewing the u-shaped piece and cleaning out (remember don't wash it in that sink while the pipe is off)
Posted on Apr 27, 2009
  • 15 Answers
SOURCE: The flood switch has been activated on my dishwasher
Remove the bottom drawer by pressing in the tabs on either side of the drawer (bottom edge towards the front).
Dry out the compartment with towels and let air dry.
Posted on May 01, 2009
Where can I obtain Electrical Schematic details for my Kenmore dishwasher?
Hi Pepper
If Kenmore themselves don't have the Schematics then they may be hard to find. Usually manufacturers don't provide that sort of detail any more.
It's usually easier to use troubleshooting knowledge to figure out where the problem is.
A multimeter is necessary here. Or a test light or buzzer.
Find the solenoid attached to the water drain pipe.
See if it is being actuated electrically. If not then it would be traced back to a timer unit of some sort.
If it is getting voltage (being actuated) then the Diaphragm and Actuator inside the valve section should be disassembled and cleaned. Even tapping the solenoid can often open the valve.
Either way, you have to get inside to have a look and test wires with the voltmeter.
Good Luck
Find Kenmore Dishwasher service manual by model number Appliance Service...
Jul 08, 2015 | Kenmore Dishwashers
Periodic water leaking from Kenmore Elite K701
hello Adrian. I am suspicious that the standing drain pipe behind your machine may sometimes over flow. To find out, pack some dry newspaper around the drain hose where it enters the drain line behind the machine. If that newspaper gets wet you will know that the drain is sometimes overflowing. If that is the case, snake that drain or force a garden hose down it and run hot water thru it for ten minutes. J.
Jul 05, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
Kenmore Dishwasher 17372 is leaking water through tub water inlet
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
wqeyrad
Jan 07, 2010 | Kenmore 24 in. 17372 / 17374 / 17379...
While not in operation dishwasher slowly fills up.
water valve is clogged try to turn your valve to dishwasher under sink
Nov 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishlex
Hi there, now I do not remember the original problem, if there is not water coming into the appliance, start checking the water pump. Also locate and check the water level floarting switch, that stop the pump.
If water is not drained out, then you need to check the drain pump.
Try entering the exact model number here and see if you can get schematics for your appliance.
Oct 26, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Dishwasher Model 665 stops cycle and a message appears on the control panel that says Delay water heat.
The top shelf of my Kenmore dishwaher Model 665 will not come clean - the bottom rack is AOK . Can anyone suggest a possible problem - do I need to call a repair person?
May 07, 2008 | Dishwashers
Kenmore 17245 won't drain.
Try blowing into the drain line with a wet/dry vac. This sometimes removes clogs. Otherwise, hold the hose above the unit and fill it with water. If there is no clog the water should appear at the bottom of the dishwasher after a few quarts.
Nov 29, 2007 | Kenmore 17245 Dishwasher
Dishwashers Logo
204 people viewed this question
Top Dishwashers Experts
