Question about Durabrand CD Player with Cassette Recorder, CD-2036 (Silver) Boombox
Replacement Telescoping Antenna
From where or what manufacturer can I obtain a telescoping antenna to replace the original on a Durabrand CD-2036?
  • Anonymous Jan 17, 2009
    need a new antenna
Looking for replacement antenna for Sony CFD-S300 with base insert
Posted on Nov 24, 2011
    Problem Solver:
  • 15 Answers
If you just need a replacement antenna that is straight and telescopes out, you can find those at Radioshack. If you need one that has a right angle about an inch from the end, those are hard to find. I've tried all my usual electronics links on the web and only one carries them. Check out Russell Industries. http://www.russellind.com/Russell/Antennas/main.htm
I've not ordered from them in the past. I'm starting to think it would be cheaper to find a replacement antenna on a junk radio at one of those barely used stores or a garage sale.
Posted on Dec 24, 2009
    Problem Solver:
  • 5 Answers
Yea you can do it okay
Posted on Oct 16, 2008
How would I attach an external antenna?
The manual may be generic, covering a number of models with and without external antenna connection provisions.
Aug 26, 2015 | Radio Communications
How can I buy a new antenna for model sony cfm-165tw
Many boombox antennas are attached by a small screw through the pivot point. This is usually a #1 Phillips screw. Some do not have a swiveling antenna; for these you have to remove the back of the case to get at the attachment screw. Keep the screw; it's guaranteed to fit when you attach the new antenna.
The hard part is finding a replacement. If you have the pivoting/swiveling antenna, the Radio Shack 28" Replacement Telescoping Antenna 270-1405 ($5.99 online) will probably work. You might even be able to use it for a non-pivoting antenna that telescopes into the inside of the case.
Jul 22, 2014 | Sony Boombox Am Fm Tv Weather Band...
Replacement Telescopic Antenna
See if this fits the bill. Otherwise stop in at a radio shack store. They sometimes have these n stock.
BuyTraxxas
Mar 01, 2014 | Radio Communications
How do you rebuild a Telescoping Antenna?
Don't try to remove the segments because they will be destroyed. The easiest way is to change over the whole "stick". Try to find a way to fix the working one at the broken 's place.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 11, 2010 | Durabrand CD Player with Cassette...
Grundig YB400PE broken antenna
Unfortunately, your description of the problem means that your radio must be taken apart to be fixed. Replacement antennas can be found purchased. It would require installing the new antenna and most likely soldering it to the broken wire. Do you have a picture?
Apr 05, 2009 | Grundig YB 400PE AM/FM/SW Radio
Antenna
Radio Shack carries various replacements. Make sure you know how your broken one mounts because they can look the same, but there may be a variation that will prohibit you from connecting it. If you can, take the broken one with you to match up. If they do not have it, check with a local electronics shop. They may also have a replacement for you.
May 22, 2008 | Durabrand CD-203 Boombox
Sangean ATS 808A-replacement aerial antenna
The antenna should be available from Sangean, or C.Crane.
To replace the entire antenna, about 6 screws from the back must be removed, and the back also removed.
Or you could replace it at the antenna's "elbow". However, this is almost impossible to do without loosing the 2 tiny washers. If you do loose the washers, the antenna will work, but will be loose, and not stand up and support itself.
May 10, 2008 | Sangean ATS 808A AM/FM/SW Radio
1,393 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Rod
Rod
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
