Question about Philips 42PF9630A 42 in. Plasma Television
Philips 42PF5520D The power keeps tripping and it goes to stand by. Once unplugged and turned back on it may last for a few seconds before it trips again, or a few minutes or even an hour plus. It seems to last longer the longer it has been off (e.g. half an hour or a whole day off). Any suggestions
  • glloftis Feb 06, 2009
    I have same proiblem, mine last for 4 to 6 seconds and popps off. Power back on and same thing. How do I find caps?
  • 30 Answers
The capacitors in the power supply are probably bad. The best way to check them in circuit it with a ESR Meter. Or you can do what us old technicians call shotgun it and replace all the caps on the power supply module. Let me know it this helps.
Posted on Oct 16, 2008
Why wont my sharp lcd LC-32D44U turn on?
Well, there could a be few issues. First thing is to verify the breaker that gives power to that wall has not tripped off in the home's break power panel. If it is not tripped then verify the wall outlet that the TV is plugged into has a reset button, like a GFI (ground fault interrupt) If it does then verify that it has not tripped. If the GFI on the wall plug is tripped simply push the reset button back in and then try plugging in your TV power plug again. Then if that checks out or does not have a GFI outlet, verify that the power plug going into the back of the TV is not loose. Unplug and replug power plug that plugs into the back of the TV in and verify it is securely connected. Lastly, the power supply in the TV might have gone out.
Aug 22, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Pentair intellitouch electronic breaker keeps tripping
check pump see if popping or heater unplug auxs until it doesn't pop if keeps maybe bad transformer
May 04, 2012 | Pentair Intellitouch Power Center Includes...
How can i reset when the MAINT REQD indicator comes on?
Turn igniton to on position and put odometer in trip mode, turn off ignition.
Hold trip button in and hold it in as you turn ignition to on position, it will flash
Turn off ignition.
Maintenance light should go and stay off
Read more:
Apr 25, 2011 | 2007 Toyota Camry
Second hand Fisher & Paykel keeps tripping power off
sound's like you have dead short to ground in the start mode of the compresser.
Nov 22, 2009 | Maytag MSD2651 HE Side by Side...
We have a TV that does this after we have left it off but plugged in for awhile when we go on a trip. Just unplug the TV, wait a few seconds and plug it back in. If it's like ours, you'll find that resets it.
Nov 19, 2009 | Loewe ARC332 32" TV
Plasma philips model 42pf5520d/10 working few seconds and go for stand by led
I have seen this once before and the reason was a capacitor on power supply board.
My bet would be Power Supply board, before we troubleshoot anything else. Check the continuity of the board. There might be many capacitors or diodes. Check the voltage across them. Sometimes, you can find a faulty capacitor by naked eye. Usually, the defective one are swelled.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 03, 2009 | Philips Televison & Video
Philips 42PF9956/37 Plasma TV - Looking for y sustain board
it isnt the Y-SUS board, it is the Power supply, iv fixed this exact problem twice in the last month, try turning the tv on, and when it turns green, unplug it real fast, while light is still green, after 15 seconds plug it back in, then hit the power button, if it dont come on, hit the power button again, this time, as soon as it turns off, hit the power button again to turn back on, sometimes you can trick the tv and it will turn on, at least i was able to do it, and once it comes on, it should work fine, untill you turn it off again.
Jan 10, 2009 | Philips 42PF9431D/37 TV
Power Supply Keeps Tripping Fuse
Freeze the capacitors is a trick worth trying. These usually are the problem
the way you run this is too use freeze spray to freeze each capacitor one at a time . Turn the TV on and if it doesn't trip for a few second longer you know that is the capacitor to change. Freezing capacitors only helps identify the fault if it is a capacitor issue (usually is with power on TV's)
Dec 24, 2008 | Philips 32MF231D Television
No Image but power
find the manufature of the video card, use the old monitor and go to the video card manufacture and download the video driver.
Jun 30, 2008 | Philips 170B4MG 17" LCD Monitor
Philips 42PF9630A 42 in. Plasma Television Logo
325 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
