Question about Dell Dimension™ B110 PC Desktop
Disk read error
When i turn on the computer it loads up and then their is a black screen with a flashing underscore then it says disk read error i think its the hard drive i dont know but i need help a.s.a.p so please hurry
  • 282 Answers
Try to run diagnostics,restart your computer, press f12, choose utility partition,choose test system, then run express test..that will tell you if hdd is bad, it will give you an error message/ number
Posted on Oct 15, 2008
Hi , went to bed at night laptop was fine. When I woke up and tried to open, The dell load screen appear and 1sec later it goes to the black screen with a white underscore blinking top left corner. Windows...
The hard drive may be going bad. Try booting into Safe Mode to see if it boots into Windows. Then I highly recommend backing up all documents onto a flash drive or portable hard drive.
Mar 22, 2015 | Dell Inspiron Computers & Internet
I have a dell inspiron 1318. whenever i turn the laptop on, there is a black screen with a "read disk error has occured" message...it keeps bringing me back to the same screen...what should i do?
Disk read error is indicative of a hard disk drive failure. If under warranty, call Dell for a replacement drive. If not you can buy drives at places like Newegg.com or EBay
Sep 20, 2010 | Dell Inspiron 1318 Notebook
Goes to intel screen thEn black screen with
That error means that the Boot Manager is Missing. This is usualy caused by either a failed hard drive, or a failed attempt at recovery. If you try to do a recovery and then suddenly halt the process, weather on purpose or due to somthing like power failure, then the first bit of the Recovery boot process, the BTMNGR, can be hosed. If this happens then your only option is to order recovery disks from the manufacturer and install the OS that way. These disks will run you about $15-$30
You might boot into bios (F10 on startup) and do a hard drive self test first to make sure you dont have a hard drive problem...
Thanks for using Fixya
proton
Nov 08, 2009 | HP Pavilion dv6000z Notebook
Blank screen blinking underscore Toshiba laptop after startup
if you can get into the BIOS-setup, verify if your hard drive is recognised as a bootable device and set as first boot device. if the disk is not recognised, you might want to verify if the P-ATA/S-ATA controllers are enabled. if this is all the case, but the problem remains, then your hard disk is probably broken.
Oct 05, 2009 | Computers & Internet
I have a ten year old compaq presario. i turned it on and a black screen came up with a white underscore at the top left corner. the underscore blinks repeatedly forever! i have looked inside my computer...
It sounds like the Hard disk has failed. You might be able to replace it if you can get one from a computer swap meet. but you are likely up for a new PC.
Jul 16, 2009 | Computers & Internet
Black sreen with flashing underscore
Try pressing "esc". If it doesn't help call the dell technical support hotline. Or ask the shop.
Good luck
Jun 26, 2009 | Dell Inspiron 5150 Notebook
Black screen and blinking underscore before loading OS
chipset drivers that are loaded onto the harddrive are not the same as the ones in the "new" computer you put it into.
The only way to do that is format the drive and start from vanilla.
This is very common. -Jeff
Feb 04, 2009 | Gateway e-4200 P2 400MHz Tower...
A hard disk problem is preventing windows from starting.
The black screen with flashing cursor can be caused by the files needed to boot being located in sectors of the hard drive that can no longer be read.
You can try booting to the XP CD, and go to recovery console and RUN CHKDSK /F See if that fixes the file structure and allows the system to boot. If that fails, you can try a repair installation of Windows. If that fails, the most likely resolution is replacing the HDD and reloading Windows and the drivers.
Jan 31, 2009 | Acer Aspire 5520-5908 Notebook
TECRA 740CDT
Try taking the battery out and use only the AC. If everything turned out fine, it could be a problem on the battery or on the port.
Oct 07, 2007 | Toshiba Tecra 740CDT Notebook
Dell Dimension™ B110 PC Desktop Logo
141 people viewed this question
Alun Cox
