Question about Electrolux Kitchen Ranges
I have a chef wall oven EOC633W which which is greatly overheating and not staying at it's set temperature. It seems to be ok for the first 30 mins and then becomes a furnace. thanx
5 Suggested Answers
  • 183 Answers
SOURCE: Magic Chef Oven lights and shuts off
This could be caused by a lack of air within the oven cavity, once the air is used up the flame will go out, it will then work again once it is relite, but will probably do the same again, this could be dangerous and requires on site proffesional attention. Regards Engineer
Posted on Jul 28, 2007
hemantraj
  • 638 Answers
SOURCE: Hotpoint RGB747GER oven does not heat properly
www.repairclinic.com
Posted on Aug 18, 2008
57 varieties
  • 1653 Answers
SOURCE: Oven is not reaching proper temperatures
You most likely have either a faulty thermistor or heating element that will need to be replaced.
Posted on Nov 10, 2009
johnrodgers1
  • 73 Answers
SOURCE: I just got my (new to me) pre-1990 Wolf 36
the oven pilot has 2 setting first setting is for you to light small flame, should not be all yellow if it is it has a dirty orifice inside the pilot hood, you can remove this by disconnecting the pilot line from the hood and removing orifice for cleaning, just rub it with a cloth.once clean and replaced you light pilot and check it out. if its ok turn on oven and secondary pilot will ignite that why it got bigger!! this heats a flame sensor to allow 100% safty vavle to open to let gas into burner so yuo can cook.
Posted on Feb 05, 2010
  • 74 Answers
SOURCE: Hotpoint Gas Stove #RGB745BEA8WH-The oven will
sounds like you have a bad regulator or oven safety valve
Posted on Nov 19, 2010
Sears kenmore oven shuts down while in use - display board goes blank - restores 30-45 minutes later
Hello there and welcome to Fixya
This problem has actually occured quite alot on these ovens so no you are not alone
Here is what they have found out and suggested
the oven controle panel has a micrprocessor IE computer built into it that is supposed to sence the correct temperature of the oven there tests have shown that this does not happenso what happnes is that the oven will run any where from 30 to 60 min then it will go blank and shut down and will restart after the computer resets itself after 30 min or so
Now here is the tricky part when they build the ovens there is a temperature sensor that is supposed to be compatible with the controle panel when assembled and depending where the oven was made that part was the wrong part ok? so that is why they are suggesting that you have the warranty used if you still have the warranty
However if it is not under warranty what you will want to do is to have the temperature sensor tested to ensure it is accurate to what the display is saying because if it is not then you may have the wrong sensor for the oven ok
In most cases people will just go ahead and replace the temperature sensor in the oven itself and it seems to solve the problem ok
But yes there are times when it turns out to be the controle panel is at faut which means you would have to replace that part ok
So keep me posted on what you find and i can help you test the sensor if needed ok
Best regards Michael
Dec 01, 2013 | Kenmore Ovens
I just got my (new to me) pre-1990 Wolf 36'' range connected (by a certified pro). 4 burners, 12'' fry top/charbroiler/cheesemelter thingie on left, 4 burners on right, 29'' oven - propane. It has not been...
Feb 02, 2010 | Wolf Range CHR-0-29-FT34 Gas Kitchen Range
Whe i set the oven to 350 it has an F3 and wont light. This is a magic chef gas pioltless stove
Hi ttommajor,
The F3 fault code description is a shorted or open oven temperature sensor (RTD). Please check the sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope it helps.
Thank you for using FixYa.
Nov 26, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic chef smooth top electric free standing oven temperature
Most likely a bad temperature sensor if the bake element is coming on and not reaching temperature.
The temperature sensor is in the back wall of the oven up high on the right or left side depending upon your model number. It is about 3 inches long and about the size of a thin pencil. It removes from the inside of the oven.
Nov 19, 2009 | Kitchen Ranges
THE OVEN TEMPRATURE IS NOT CONSISTENT.IT KEEPS BURNING FOOD.
Usually this is due to a bad temperature sensor. Sometimes it's due to a control board malfunction.
If you can get an accurate measurement of the oven temperature (which is not as easy as it sounds) you can do some diagnosis from the outside:
You need an accurate thermometer or thermocouple into a DVM. Make sure there are no obstructions in the oven (baking sheets, etc). Make sure you are measuring the temperature in the center of the oven cavity.
1. If the average measured oven temperature agrees with the display, the sensor is probably ok. The controller cycles the element on and off, at a rate that results in a correct average temperature. So you have to record the thermometer reading min and max over several cycles.
2. If the sensor seems ok from #1, it can be verified by disconnecting it and measuring its resistance. Should be 1080 ohms at 70F.
3. If the sensor seems ok, but the oven temperature is erratic, then it's probably a control board issue. We repair these at www.fixyourboard.com
Oct 05, 2009 | Frigidaire 30 in. Electric Gallery Series...
GE electric range with self cleaning oven. When
try to unplug power from wall and wait 30 min,then turn on
Jul 05, 2009 | Ovens
F2 error code on Magic Chef Wall oven
Replace the oven temperature sensor.
Jun 09, 2009 | Ovens
T3 electric wall oven - Temperature set buttons
I had the same problem. The entire control panel had to be replaced. That included the display, keypad and all the hardware behind it.. it's one integrated unit. Luckily I had the extended warranty, otherwise it would have cost close to $400.
Jan 20, 2008 | Maytag 30 in. Electric Single Wall Oven...
Kitchen Ranges Logo
Top Electrolux Kitchen Ranges Experts
Electrolux
Electrolux
 Fix Your Board
Fix Your Board
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
