Question about Dell Inspiron 8600 Notebook
Problem Using stand alone monitor with laptop computer
I have been using a separate monitor for my laptop because the built in monitor went black. Everything was working fine until this morning. The laptop screen is coming on, but it is dark. I can just barely see my desktop on the screen. The separate monitor says it's in power saving mode or says "input signal out of range". I'm pressing (function - f 9). Any ideas?
    Problem Solver:
  • 10 Answers
It could just be in the power saving mode. if it is its easy to fix. just go to the notebook mobile settings or battery settings and change the screen brightness or mabey you have a screen brightness changer on your keyboard?
Posted on Oct 15, 2008
    Master:
  • 538 Answers
Signal out of range suggests that your laptop is asleep..open the display settings, and disable those, until you get this resolved.
My computer is a SyncMasterP2570HD i cant get any sound to come out but it is detecting sound how do i fix it
The Samsung SyncMaster P2570hd is a monitor with speakers; it isn't the computer itself. I'll assume that you are dealing with a computer connected to the monitor and not a set-top box. Make sure that Mute is not enabled on the computer. There should be an icon on the lower right hand side of a Windows desktop. If the mute is enabled, it will have a red circle with a diagonal line through it. Left click on the icon to remove the mute (change the volume or click on the mute icon). Test the monitor's speakers by connecting it to another device with known good audio output.
Next how are you connecting the monitor to the computer (VGA, DVI or HDMI)? If you are using VGA or DVI (including DVI to HDMI), you need to connect an audio patch cable (3.5 mm) between the speaker (green port on the back of a sound card) or headphone jack of the computer and the audio input jack of the monitor. The audio input jack is between the DVI and VGA ports. You can test the output of the speaker jack on the computer with regular computer speakers. Plug in the power cord (or USB cable) for powered speakers. If the free-standing speakers work, check the volume setting on the monitor with the +/- buttons to the right of the menu button. Do not press menu first, though. If that doesn't solve the problem, continue using the separate speakers. (Unless the monitor is still under warranty, it usually isn't worth taking apart a monitor to replace the speakers. You may be able find replacement parts online.)
If you are using an HDMI cable, check the output audio setting to see if the HDMI audio is available. For Windows, click on Start > Control Panel > Hardware and Sound (Windows 7). Then click on Manage Audio Devices under Sound. In the Playback tab, check what available audio devices you have. Make the HDMI the default device by right-clicking on it and selecting Make this the default device. (Other versions of Windows will a slightly different route to this panel.) You may need to restart the computer to get the audio signal on the HDMI cable after setting this. Note: not all video cards/computers support HDMI audio. If you don't see HDMI listed in the Playback devices, connect an audio patch cable as with a VGA or DVI cable, described above. Use stand-alone speakers if the monitor's speakers are bad.
I hope this helps.
(I have had the speakers fail in monitors; <$30 separate speakers are an adequate replacement for those built into a flat panel monitor.)
Jun 26, 2012 | Audio Players & Recorders
I hav a asrock p4i45dv mother board , its cpu lights appear but nothing is displayed in monitor may i know the cause of this problem and soluton
This is either a bad monitor, a bad video card (if you're using a stand-alone card), or a bad motherboard. Test the monitor by connecting it to another computer. If the monitor works, then it's the video card or MOBO. Use a stand-alone (PCIx/AGP) video card that you are certain works. If this does not work, then the MOBO is not working. I hope this is helpful and best of luck!
Sep 21, 2011 | Asrock P4I45GV R5 Motherboard
My Sony Vaio VGN NW225F laptop won't start up.
First thinkg I'd do is to connect an external monitor to the laptop to see if you can get an image, any image, during booting. If you can't see anything, either using the laptop's screen or external monitor, then you have a hardware failure in the laptop that's probably beyond the abilities of a novice to repair. Get somebody who knows about how to clear the CMOS of the laptop.
Nov 08, 2017 | Sony Computers & Internet
I have the Dell 1525. The screen is black with only the cursor appearing. Please advise
Check to see if you have the machine switched out to a stand alone monitor. This is a feature on many lap tops that lets you re-direct the signal out to a larger monitor, or if your monitor fails you can display the computer info on another screen. This feature is engaged by holding down the Fn key and tapping teither the F4, or F6 key on many lap tops. This feature can be toggled by both displaying at the same time or switched to the stand alone or the Lap top.
The other cause is that the machine has malfunctioned usually because of the CPU failure and there is nothing to boot the machine up.
Dec 30, 2010 | Dell Inspiron 1525 Notebook
Monitor is black
Try booting in safe mode per instructions here: http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
You need to find out if the proper video card driver is installed when you use recovery disk. Compaq usually supply separate disk for the drivers.
Try using resolution of 1024x 768 @60 Hz first and go up from there.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 04, 2010 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
My Dell Latitude x300 monitor is dark (black) while the computer is running. I plugged it into a stand alone monitor and it was also black. how do it fix it.
Your graphics card adapter is damaged!
buy a new card to your dell laptop
and let someone with experiense change it.
This is your solution! Please vote!!!
Feb 28, 2010 | Dell Latitude X300 Notebook
Monitor is blinking green light but no dark screen
does you cpu have a built in vga or you use a separate card? check at the back of the cpu, if you are using a cpu that has a built in vga and youre using a separate vga card may you have just connected your lcd monitor on the built in in which many cases will not work you need to connect your lcd on the separate vga card, if that is not the case and you head a beeping sound with intervals then there a problem with your vga card now if you use built in video you need to put on a separate vga card agp or pci-e which ever is supported by your motherboard, hope this help
regards
michael
Nov 20, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Stand alone monitor won't come on after Vista automatic downloads
I'm just "guessing" here, but when the updates are installed, you may have to restart the computer. On a laptop, unless you go into the control panel and designate which monitors are installed, it reverts to the built-in monitor and you have to use the Fn and whichever function key controls the monitor assignment.
Yes, there should be a way to permanently tell the machine that the external monitor is the primary one. I think (since I don't run Vista here) that you would get into the control panel and the display settings and designate the attached monitor as the primary. I'd be interested to know if this works. Be sure when you go to the display properties that you right-click on the external monitor and choose "attached".
Anyway, give that a try.
Mar 12, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 8600 Notebook Logo
298 people viewed this question
Alun Cox
