Question about Singer 7462 Mechanical Sewing Machine
Old model singer 275k tried to use it the other day and sewed maybe 1 inch long and the needle is stuck down will not come back up I did see a tangled mess with the bobbin and removed it and all tangled threads that I could see what else could I try??
dupina
  • 110 Answers
SOURCE: singer solid state-bobbin part
Check your tension disks, with your presser foot up, and the tension dial on zero. Sometimes a piece of cotton breaks off between the tension disks and then prevents the disks to work properly. Also make sure when you thread the machine, the thread does go through the disks and over the take up lever. After you threaded the machine, before putting the thread through the eye of the needle, lower the presser foot and while pulling on the thread with your left hand, increase the tension with your right hand. Do it slowly and you should feel in difference in tension. If this is the case, your machine should work fine. Also use a ball-point needle on t shirt material. Good luck!
Posted on Nov 03, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
  • 69 Answers
SOURCE: Singer Touch & Sew won't loop bobbin thread
I believe you have a broken gear. These are difficult to repair on your own.
Posted on Feb 12, 2009
  • 69 Answers
SOURCE: How do you adjust the bobbin tension on a Singer
With your slide plate open, you will see 2 screws on the bobbin case. You need to adjust the one on the inside (not the one that sits at the edge of the metal strip). Do so very slightly. If you can't seem to get it adjusted, take a look and make sure there isn't any thread or lint in between the two pieces of metal that the thread feeds through. This can cause a loose tension.
Posted on Mar 01, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
Needle stuck in right position
Try directing heat from a handheld hair dryer into the internal mechanics where you applied oil. If the old oil has solidified, it is probably preventing the parts from moving freely. Be sure to always use Fresh, good quality sewing machine oil (NO 3-in-1, WD-40, cooking oil, or old stinky oil from grandma's sewing basket). Also apply only 1-2 drops each spot. Frequent oiling should be around every 40 hours of sewing time, or at least every 3 months.
Here's a manual if you need one (oiling instructions on pg 74):
5050 Singer Sewing
Apr 22, 2016 | Singer 5050 Mechanical Sewing Machine
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
Singer CG500 Needle hits the needle plate. Needle was replaced. Verified needle in correctly. Tried hand wheel - still hits. Machine has yet to be used!!
Unless you need all the bells and whistles to sew get you a pre-1930 treadle or handcrank. I have 2 electric Singers, 1947 model 66 and 1948 201-2 both with attachments. Also I have 1903 Singer handcrank made in Scotland. The plastic new one just don't have the ability to hang in there .... All my pre 1930 Singers sew... I love them!
Apr 17, 2014 | Singer CG500 Mechanical Sewing Machine
Needle wont move singer 478
I have a Kenmore sewing machine. I'ts about 30 to 40 years old. I have never had a problem with it until today. The needle got stuck down where bobbin is. I don't know if it should be seen by a pro. I can not get the needle out. The Bar on the side will not move either way. help...........!
Jul 06, 2013 | Singer Sewing Machines
My sewing machine singer 7256 giving me a problem causing my fabric underside stitches bird nesting and suddenly the bobbin case comes out from its place and thread strangles and stuck, Why?
try changing the needle-- Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
rethread the machine top & bobbin
make sure the thread has not come off the thread take up lever
also check the top thread tension
do you have a manual?
Jun 04, 2012 | Singer Sewing Machines
Hi I am having a problem with my 7470 singer sewing machine. Even with thread in the needle and in the bobbin no stitches come on the fabric. I tried manually pulling the wheel towards me to see how...
Is your buttonhole lever down by accident? If, that isn't it, it could be your timing is off. One other thing to try, is your needle all the way up in the shaft? I hope that it is something simple, call Singer at 1-800-4singer and maybe they will have quick fix because the timing is not a do it yourself job.
Dec 30, 2010 | SINGER 7470 Sewing Machine
I sewed a few days ago, put my singer machine away and today when I was ready to sew, it will sew backward, but the needle won't go down into the bobbin to sew forward.
Try the old hair dryer trick, take off the cover, pay attention where the screws go, put some gloves on, then work the reverse lever, button or whatever you have on your machine and your stitch length dial. It may have old grease or oil that needs to soften. Now put your machine back together. Clean and Oil your machine as per your manual. Try rethreading and a new needle before you sew. If you don't have your manual, go to www.singerco.com and under customer support and download one for free. Good luck. I hope that I have helped you, my advice is free.
Nov 02, 2010 | Singer 1725
Motor spins, but doesn't sew
Oh, mine did that a while. Then, I dropped a needle in it. I turned it upside down and shook. The one I dropped came out, along with another rusty one. I tried it, the needle worked again, but it didn't sew. Now it works, but again, doesn't sew. Try turning it up-sde down with the place where you put in the bottom thread and the other pannel exposed. My model id very, very old. It's an ELNA Transforma.
Jul 04, 2008 | Sewing Machines
Needle jams and breaks off
Needle jams....Thread is caught in the hook...solution...Remove the upper thread and bobbin case,turn the handwheel backwards and forwards by hand and remove the thread remands.
Needles breaks
1. Needles is damaged..Insert new needle
2. The needle is not correctly inserted....insert flat side towards the back
3. Wrong needle size for the fabric...Choose a needle to suit the thread and fabric.
Mar 24, 2008 | Singer 1116 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
94 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
