Question about HP OfficeJet 7310 All-In-One InkJet Printer
HP 7310 all in one printer
There is a wire spring(?) where the 96 cartridge should go. The spring looks fine, but the plastic piece that the spring goes onto is broken. What can I do?
  • 1 more comment
  • Anonymous Oct 16, 2008
    I have the same problem with the plastic holding the spring having broke off apparently when I put in a new cartridge. I used masking tape to hold the spring in position but I can't get the error message to go away no matter how many times I take out the 96 print cartridge and reinsert it. When I contacted HP, they could not help me. The printer worked fine until I had to put in a new color print cartridge. The All-in-one is useless now. I can't even send a fax.
  • Anonymous Nov 04, 2008
    Yeah I have the same problem only with the black cartridge. Now i don't know what to do. Do you have any suggestions?
  • Anonymous Nov 07, 2008
    I have the same problem. I have found no solution. I ended up going to a used printer dealer and purchased a used 7410 model. Waiting to find a replacement cartridge assembly.
  • 181 Answers
If the issue is with the carriage chute your printer has an extended warranty and will be replaced by hp (at no cost) if you call in. If they act like they don't know this tell them there was a recall on all printers with certain serial numbers.
    Locate the serial number on the printer. If the third and fourth digit of the serial number is 55, 56, 57, 58, 59, 5A, 5B, 5C, 61, 62, 62, 64, 65, 66, 67, 68, 69, or 6A, you will receive a replacement unit and free Extended Support and Service Warranty.
Please read this document and look at the photos in Step 1.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&rule=22243&product=391182
If not then this is not a user replaceable product and you are looking at paying to have it serviced by hp or replacing the unit altogether.
Posted on Jan 29, 2009
I used fishing line and tied it back into place and has worked fine ever since..
Posted on Feb 02, 2009
Hp officejet 7310 black cartridge error message
the clip on the side came out i put it back and i saw puncture in that pins plate in the printer maybe is a scratch when that spring clip come out itry turn on and off and put back the black cartridge but i receve same message to remove and check black cartridge?
Apr 26, 2010 | HP OfficeJet 7310 All-In-One InkJet...
X-spring tab broken in ink receptacle (HP officejet 7310)
I think you right. There are a lot of small parts which are finely tuned in a printer and most likely something else is still affected.
You probably are better off purchasing a new unit, unless you have the time and patient to figure it out.
Good Luck!
Sep 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Ink cart error
Is there a metal wire (clip) hooked on black plastic in the ink carriage? If not, these are notorious for breaking the small plastic hook....when broken, the cartridge is not held in proper postion so printer won't recognize that the ink cartridge is installed......no replacement parts are available for this series of printers.
Jun 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I changed my color cartridge #97 on my HP officejet 7310
Remove the color cartridge. Make sure the contacts in the print carriage are clean. Chek to ensure the contacts on the cartridge are clean. Reinsert cartridge.
Mar 20, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I need a parts diagram for an HP Officejet 7310
Here's a direct link to your model on HP's "part surfer". You should be able to find what you're looking for:
http://partsurfer.hp.com/cgi-bin/spi/main?sel_flg=modinfo&model=OJ_7300_SERIES
*please rate me :)
Mar 15, 2009 | HP Officejet 7310 All-In-One Printer
The ink cartridge I replaced in my printer is not working.
I have one of these printers (7210-7310) with this same problem and this is what is wrong with it. There is a small wire spring that holds the ink cartridge in place in each cartridge holder. Remove the color cartridge and inspect the ribbon cable (it gray) inside the ink cartridge holder. There is a big problem with these HP printers where the spring pokes a hole the ribbon cable breaking one of the wires and rendering the printer useless. Poor design by HP, sorry.
Mar 07, 2009 | HP OfficeJet 7310 All-In-One InkJet...
The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Carriage Jam
I tried all these steps and it still did not work was ready to throw the printer out from frustration. Instead I traced what I did when I had the jam. I believe if the factory can fix it so can I. My printer is now working and it was so simple yet HP does not tell you how to fix it.
Jul 20, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Hp office jet 7310 all in one printer problem
When you install your printer, did you install the driver first ??? If not, unplugged the USB cable from the printer and uninstall the printer of your computer and restart your PC.
Re-install the driver first and connect your USB cable when the software prompt you to do so....
Let me know !
Mar 31, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
230 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
