Question about Maytag MZD2669KE Side by Side Refrigerator
How do I get my fridge level to put the doors back on
I moved my fridge and had to take the doors up, when we put them back on they do not line up correctly, have spent all day trying to fix this.. How do I do this
On my Refrigerator Doors, there are Screws either on the top or bottom of the DOOR that besides holding the door on, also move it up and down to put it into alignment.
Hope this helps.
Posted on Oct 15, 2008
Water does not drain out back of fridge, then pools bottom of new fridge
check to make sure your fridge is level side-to-side and front-to-back. Look to ensure that the drains and lines are not clogged.
Mar 05, 2015 | Dometic RM4601R-A ElectroLux 2-Door Deluxe...
How do I level my domestic kelvinator fridge . the floor seems to be level . I recently relocated to Cairns
the front feet under the door opening are adjustable screws. You may have to use a shifter to get them to move as they mat be rusted . adjust so the fridge slopes slightly to the rear. This keeps any moisture on the back wall to drain out the hole and the door will close if left open
Mar 03, 2015 | Kelvinator 12 cu. ft. / 340 liter Chest...
Adjust door on kenmore 22
Your Fridge need be leveled and door need be adjusted after fridge is leveled
Dec 06, 2013 | Kenmore Refrigerators
Fridge door doesn't stay open
make sure frige is level left to right. then make back slightly lower than front. while making sure it is level left to right.
Apr 19, 2012 | Refrigerators
I have a new 4 door Samsung Refrigerator. Is there a way to level the fridge from front to back? The fridge slopes back 1" from the bottom to the top. The delivery people said it was tilted back so...
the front supports are threaded to allow for the adjustment and levelling
while you want the appearance to be in line with everything else, the next complaint will be that it is not cooling properly or the door will not close properly
unfortunately fridges do not come with a self closing door and people are forgetful and that is why it is best to have a slight slope to compensate for forgetful people and yes it is good old cheap gravity
Aug 06, 2017 | Samsung RF265AA Bottom Freezer French Door...
I need to level the refrigerator. The back needs
Hello Monty, If you can roll the fridge out, you'll likely see the adjustment screws for the rear wheels, (if equipped). If the rear wheels are fixed, as most are, you can put a couple of wooden shims down on the floor where the wheels will be and roll the fridge back into place and then make the leveling adjustments from the front wheels.
If the amount of height adjustment is greater than a half an inch, you can use a solid piece of plywood the width of the fridge and about 4-6" wide and place that at the back. Roll the fridge in until it hits the plywood and tilt the fridge forward about 2 inches and push it back until the rear wheels are on the plywood. You can then, again, level the fridge using the front wheel/leg levelers.
I've found that it's easier to get a good idea of just how much out of level the space is where the fridge is being placed. Then you can make the changes using the best materials for the situation. Shims are fine for small adjustments, while the full width plywood is more consistent and easier to adjust, as the fridge will likley get moved out every 6 months or so, for cleaning of the coils and behind the fridge.
Remember that ideally, you want the front of the fridge just slightly higher than the back, so the doors will close by themselves, when opened almost 90 degrees and released by hand. Gravity should then take over and automatically close the doors, ensuring a good seal to keep the fridge closed and running properly.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Maytag MFI2568AE Side by Side French Door...
Should my fridge be level or should the door close by itself
shuold be tilted back just a little so when you lightly push the door it will close all the way,if you have a level tilt it back like a 1/4 of the bubble in the level,if the freezer door opens when you shut the fridge door put something heavy on the inside of door so it won't pop open on you and wash around the area where the gaskets touch the frame so anything that might be sticky doesn't rip them,good luck and hope this helps you
Dec 18, 2009 | Kenmore Refrigerators
Problem W/ freezer door
Since you checked the top for level and it was ok you should check the sides for plumb with the level. The fridge has been racked so it is now a parallelogram and not a rectangle. You will have to rack it back to get the door to fit. Basically you will have to push the top of the fridge on the high side until the body is bent back. You will have to eye-ball it.
Apr 30, 2009 | Refrigerators
Refrigerator Door does not always seal properly
When you close it put pressure on the door to displace air inside and create a vacuum. Then release it.
Aug 06, 2017 | Refrigerators
Fridge Door not shutting/sticking
the fridge door stays shut only by strip magnets inside the door seal. cause is possibly that the hinges are out of line or the cabinet distorted. try levelling the fridge and tilt slightly backwards
Apr 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Maytag MZD2669KE Side by Side Refrigerator Logo
113 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
