With a/c on, not getting any cool air, someone came out and charged the unit with coolant, two days later, air is back to not being cool.
    Problem Solver:
  • 14 Answers
Might be a leak in the system call to come out again if there is no refrigerant then they need to fic the leak if thats to much then replace
Posted on Oct 16, 2008
If the thermostat sticks on my 2004 land rover discovery what will happen?
You'll probably get a check engine light and an attached computer will throw an error code. Replacing the thermostat is typically recommended on the Discovery's and LR3's at around 105,000 miles. The coolant should likely be replaced at the same time.
Once the fluid is replaced there is a process for bleeding the air out of the system so that everything cools properly and you get heat from the vents. Have a LR dealer or someone that really know Land Rovers do this. But here's the general process:
Only bleed the system when completely cold. Open reservoir cap then the bleed screw. Pour coolant in until it comes out the bleed screw. Replaced bleed screw. Replace cap. Run engine to normal temp with heater blowing and once at temperature, check level in resevoir. Add more coolant if needed. a few days later check the coolant level when cold before starting. If it is down, refill to the cap and recheck 2-3 days later.
Jan 23, 2014 | Bosch Land Rover Discovery Series Ii 1999...
Fridge freezer not cooling
if its cooling but the fridge side is too cold then the damper door that control the cold air from the freezer to the fridge side is stuck open and not closing when the fridge is no longer calling for cold air
Jan 31, 2013 | Refrigerators
While running the air conditioner the Thermostat goes hot, when I turn the air conditioner off it goes back down. The low coolant light came on but the coolant is full. What else could it be?
To start with, you are talking about the temp gauge. The thermostat is in the engine.
The coolant system could be low or have air pockets and still look full.
First thing I would check is the cooling fan, then the coolant level.
Jun 30, 2012 | 1999 Ford Taurus
A local garage mechanic says the clutch has stopped working on ac that is why it blows hot air instead of cool says it will cost $900. to fix cause I have to buy the whole ac unit does this sound correct?...
have you tried charging the ac system? most ac compressors have a pressure switch that will not allow the relay to engage the clutch if the coolant pressure is low. $15 can of r134a and maybe a $20 Haynes manual is well worth the price difference, eh?
Jun 07, 2011 | 2004 Kia Sedona
2 days ago I turned on my air & it wouldn't get hot a few min. later my ford mustang started smoking. I looked under the hood to find that no engine coolant was in there. Once I put some in there the...
Sounds like you do.
With the engine cold top off the radiator with coolant. Start the engine allow it to warm up. Look for any drips or wet spots from cooling system components. Things like Radiators and water pumps would be fairly common. Pin holes in hoses or leaking gaskets may be a little harder to spot.
The make a tool called a cooling system pressure tester that will pressurize the cooling system to make it easier to spot leaks.
Also most shops will check the cooling system for a moderate fee. Once you know what is leaking you can decide if you want to tackle it yourself or let them handle the repair.
Oct 05, 2010 | 2005 Ford Mustang
My 2001 chevy cavalier was serviced last year for over heating and the a/c unit not blowing cool air. It has a new radiator but the fan has stopped turning and the a/c blows hot only. Ive tried re-charging...
might just be a bad engine coolant temp sensor , it tells car computer engine temperature and computer controls fans , as for recharging a/c , did you pull system under vacuum ? to check for leaks ? vacuum also helps remove air to get a better charge because air expands
Jun 27, 2010 | Cars & Trucks
Indoor unit coil air temperature 60F - 70F after R22 charge..
Clean the outside and inside coils and filter. This could be an air flow problem
Aug 21, 2009 | Sanyo Split System Air Conditioner
Outside air temp around 100 unit wasnt cooling good noticed evap coils dirty cleaned them cooled alittle better checked low side showed 90 lbs had friend reclaim to get it to 70 lbs 30 minutes later it...
90 psi suction too high possible bad valves or non condensablies in the system (AIR) what is the head pressure and what type of freon r-22 410-A? your unit is never shutting off watch out for that electric bill. and did you take apart the condenser and clean it? Tom
Jun 25, 2009 | Heating & Cooling
When do you know to add coolent to a central cooling unit
You dont add coolant to centrl air systems. They have to be charged with the appropriate refrigerant by an EPA certified technician. If the unit seems to not be cooling sufficiently that would be your sign to call someone. this is generally an item checked on an annually cooling heating inspection and tune up. Unless the unit is very old or leaking refrigerant somewhere there really shouldn't be an issue since it is a closed system. Be sure you need a recharge before asking for one, it is not cheap by any means, depending on the type of refrigerant it can run you anywhere from 25-55 dollars per pound and the typical system takes 6-10 pounds to charge fully.
Jun 17, 2009 | Samsung AW0603B Air Conditioner
Window air cond unit, several years old, doesn't blow as cold
The problem with window units and any service tech will tell you it cost more to repair than you can buy at Walmart or home depot. Unless you know someone who can charge it for you. Window units are a sore subject. A 200 dollar window unit might cost 200 dollars to charge system. SORRy rusty
Jun 13, 2009 | Maytag M6X06F2A Air Conditioner
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
