Question about Canon MultiPASS F50 All-In-One InkJet Printer
Canon MultiPASS F50 won't copy but will scan
My Canon MultiPASS F50 will not copy. A few copies were very light and now the paper is clean. However the scan function operates as normal. I can scan to pdf or image software and then print the document. Printer funcrions are normal in color or black and white. Fax functions are normal. ???? Does anyone have a clue?
  • sargentd Oct 17, 2008
    Copy function won't work on platen. Scanner function works ok on platen. The light bar scans the entire document. It also moves to the left when using the document feeder. It scans to pdf or image, and prints ok from image or pdf so a copy can be made in 2 steps. Everything is normal except the copy function from the platen or doc feeder. The light in the scan bar is the same brillance in copy or scan. The scan bar does scan the document. ?????? Is there a system reset other than removing the power plug?
  • 2,016 Answers
Does the copy function work if you place the document to be copied on the platen (open the cover and lay it on the glass)? If so, check the area to the left of the platen. There should be a strip of glass with a clear plastic cover over it. This area is used for scanning when feeding paper through the automatic document feeder (ADF) from the top. This area must be clean. If this area is clean and clear, it's possible that the scanner element (below the glass) is no longer going all the way to the left when using the ADF. This would be a problem that would require servicing.
Posted on Oct 16, 2008
I have a Canon F50 printer and it is not printing correctly. It misses lines on the copies. I have put in a new Canon cartridge but it continues to do so. It keeps saying it is out of ink, but the new...
Use the canon utility and run a cleaning cycle.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 28, 2011 | Canon MultiPASS F50 All-In-One InkJet...
The ink cartridge in my Canon MultiPASS F50 ran out. I replaced the cartridge correctly, but now when I try to copy a document using either the laser copier or the fax part of the machine, the papers come...
...I try to copy a document using either the laser copier or the fax part of the machine...
These isnt laser copier, you probably refer to scaner assy... but never mind.. lets solve your problem!
First, new inks are reffiled or original?
Remove inks and look for small hole, ussually on top of crg. and blow in it verry hard.After that from crg. must start to drop ink. Put the ink back in and try to copy/print something.Also run head cleaning for few times.
If now it works that could mean two things:
1) the ink was for long time on warehouse, and nozzles are clodged.
2) your purge unit is faulty and it cant drain ink from crg.Replace purge unit, wich isnt cheap solution.
Or,... buy new LASER Canon multifunctional copier that uses TONER.
Hope that helped!
Aug 09, 2010 | Canon Office Equipment & Supplies
Changed ink cartridges, error code Wrong Cartridge, won't print, copy or scan
I had this same problem with my HP All in One. They told me the cartridge was defective, or the sensor was bad. Try a new cartridge first.
Apr 22, 2010 | Canon MultiPASS F50 All-In-One InkJet...
Need drivers to install in vista program
Canon does not support Vista at this time.
But you can set your MultiPASS to print only mode in which case it will be recognized as another model printer and you'll get basic printer function.
Press the buttons in this order. Menu-Scan-Copy-Set-Set
Restart you computer and it will recognize the printer as Canon BJ S630 This should provide basic print functions.
Apr 14, 2010 | Canon MultiPASS F50 All-In-One InkJet...
Have a Canon F50 Multipass. The alarm light is
Attempt to re-surface any replaceable rollers with a brillo or Scotch Bright pad ONLY if you are unable to locate replacement rollers. This will reduce the life of the rollers further and can permanently render them defective
Any rollers in the paper path and in the tray area(s) should have texture and should not be glossy or completely smooth with the exception of hard-plastic rollers used only as guides.
Apr 28, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Multipass F30 - Paper Feeding Problem
Open up the document feeder and clean the scanner glass
Mar 04, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Looking for a canon f50 multipass reference manual. Reason: trying to use flatbed scanner to scan - not the automatic document feeder. automatic document feeder works. The article I wish to scan does not...
To scan from the platen glass:
1. Click the "Setting" icon on the multipass toolbar
2. Select "Toolbar Settings" tab
3.Under "Image Source", click the "Scan From" drop-down menu and select "Platen"
Mar 02, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Cannot edit after scanning a document into MultiPass F50.
hmmm. because it's a fix image... but try to use adobe photoshop to edit your work. ^^
Feb 04, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Canon MultiPASS F50 All-In-One InkJet Printer Logo
131 people viewed this question
old marine
old marine
