Question about Lexmark X5470 All-In-One InkJet Printer
Problem with paper feed
I have a problem with my printer, will be glad if you could help. When I try to print, the printer tries to pick paper from the feeder tray but the paper crinkles up and the screen says to load paper. I try to put in fresh clean paper and the same thing happens over and over again. Could you please help. Thanks for your help
  • trobb49 Oct 17, 2008
    I have the same problem. There is paper caught where it is completely inaccessible at the bottom of the paper feed, apparently wrapped around something. I've taken the screws out of the back but can't manage to get the thing disassembled to pull the paper out. If I find a solution, I'll post it here.
Hmm, no plastic pieces in my case. There is a full sheet of paper wrapped around a spindle in the very back, bottom section of the printer. There is no way to open it up that I can find so I have no way to remove the paper. Considering the cost of repair (out of warranty) and the time it would take to get it repaired, I simply went out and bought another printer -- this time something more sturdy --a Canon MX-850 which has the same basic feature set but also does double sided copying and printing and is networkable. The front panel is virtually identical in layout to the Lexmark 5470 so it was an easy transition.
Posted on Oct 19, 2008
I had the same problem. Solution - with the printer disconnected turn it upside down and shake it. A piece of plastic from nowhere fell out and printer has been fine ever since.
    Genius:
  • 1,605 Answers
Check the paper pickup path. there is something or a paper stuck in the path.
you need to physically look and figure out the paper path. from pickup to feed out.
Posted on Oct 15, 2008
My Brother MFC 210C Printer, Copier, Scanner isn't feeding the paper.How do I fix this?
Use a water dampened cloth to clean the pickup roller. They get residue on them over time that causes them to not grip the surface of the paper when feeding.
Feb 06, 2015 | Brother Office Equipment & Supplies
Printer wil not feed paper in -keeps trying but paper will not move in.
Hi Jamieos,
Turn the printer off and on.Solved?
Turn the printer off and disconnect from PC.Unplug from power.Reboot the PC.
Remove the papers from the feed tray and look through the paper path for any obstructions.
Load the print papers and make sure they are correctly aligned on the feed tray.
Cear any print queues on your PC.
Connect everything now and start the PC.
Try printing.
Hope this helps.Thanks!
Please rate this answer.
Dec 14, 2011 | Epson Stylus 1400 InkJet Photo Printer
Printer will not pick paper
As a test, please try to print something using paper in the manual feed bin.
If that works, remove the tray, take all the paper out, verify the springs on the tray are working again then reinsert the paper and tray and try again.
Thank you.
Oct 04, 2009 | HP LaserJet 1320 Printer
My printer stopped picking up/feeding paper. If I
try cleaning the pick up rollers , they must be a little sticky
Apr 03, 2009 | HP DeskJet 5550 InkJet Printer
Paper does not feed all Malfxn lights on
Can you tell if the feed rollers are turning? Depending on what type of printer it is, you feed rollers could be worn and not picking up the paper.
Feb 27, 2009 | HP LaserJet 5p Printer
Epson cx3800 paper feed problem
no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
Jan 29, 2009 | Epson Stylus CX3800 Printer
Printing business cards
Feed sheets through front manuel feed slot.
base tray is mainly for up to 90grm paper,anything heavier
can feed for a time but tends to fault.also try and clean the
paper pick up rollers regularly.
mongrelken.
May 20, 2008 | Brother HL-2040 Laser Printer
Paper doesn't advance through the printer
Hi, Sounds very much like the feed rollers are worn out. If you can get to them without too much trouble you can clean them up with regular rubbing alcohol and a rag which will help the paper feed. You might also want to try unpluging the printer and trying to roll the paper feed buttons by hand and seeing if a piece of paper will feed through without catching anywhere. If it does catch somewhere, then you may very well have a small piece of paper jammed in the paper path causing the jam. Good luck.
Aug 25, 2007 | Lexmark Z31 InkJet Printer
Paper not feeding
Is this a top feed - that is paper loaded on top at the back bottom feed from a tray underneath? Top feed take one sheet of paper and gently push it down whilst the printer is trying to grab it. Tray feed - take tray out make sure no paper fragments are in the tracks and find a nail board and gently abrade the pick up rollers.
May 13, 2007 | Brother MFC-620CN All-In-One InkJet...
Paper feed or pick up problems
The rubber paper rollers on your printer that picks-up paper may have wiered out. So try replacing them. This may occur when the rubber rollers get dirty also. In that case just cleaning them with a wet cloth will do the solution (no water drop should fall on the printer assembly).
Jan 06, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Lexmark X5470 All-In-One InkJet Printer Logo
65 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
