Question about Norcent Technologies LT-2722 27 in. LCD Television
Norcent LT2722 I was given this tv from a family member and it is not working. Usually when I plug the device in I get the blue LED light on the fromt but nothing else. I was reading your posts for this model and am curious if replacing the fuse will do the trick. If so I believe the part that needs to be replaced is labeled as F901. Thank you for any help that you can provide.
  • bmangiameli Oct 16, 2008
    Is this something that can be done easily? Or with what little I know are there repair services available for this television? And if so how much would it cost to repair? Thank you.
  • billgall Oct 16, 2008
    I have the similar problem. When I turn on the TV, the lamp does not come on. If I let it on for 10 minutes and then turn it off and on, it comes up. Any ideas?
  • 2,326 Answers
The fuse is good if you're still seeing some kind of light on the front of the LCD. There might be defective capacitors in the power supply and that is why the LCD is not powering up, but also there is a possibility that the back light inverter board might be defective.
Let me know if you need further assistance.
Posted on Oct 15, 2008
Removing the stand on Norcent TV model # LT-4247
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
May 25, 2015 | Norcent Technologies Televison & Video
Need the code for a norcent tv with my unimote controler
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 22, 2014 | Norcent Technologies2703 27" TV
My freesat remote just stopped working. Ive put new battries in, turned box off and on, disconnected and reconnected it but the remote just wont work anymore please help me
Have you got a video camera? Here is the trick to find out if the remote doesn't really work, or it's the TV that is not picking up the remote signal. Most remote use an infrared led to beam signals to the TV's. And this trick will show you whether that remote's LED is actually working. You and a friend or member of the family is all you need to begin testing your remote. Ask your friend or family member to hold the remote and you hold the camera on without recording. Point the remote about 5-6 feet from the camera. You watch the camera monitor screen while your friend or family member presses the On button or presses the buttons that you think are not operating the TV. With a dim room light, you should be able to see a flickering light coming from the remote in the camera screen. If it's hard to see, which I doubt, since remote infrared LED are pretty bright, you can turn your room lights off and try again. If the flickering LED from the remote is seen and is bright, then try all the buttons on the remote, or at least try the ones that you say are not working with the TV. If all is well, then there is nothing whatsoever wrong with the remote, but chances are that though the remote may beam out infrared light, it doesn't mean it is the right frequency for the TV. It could have lost the frequency and no longer sends the correct signals for the TV. However, the problem can also be with the TV remote's LED receiver. This falls into the hands of a technician's inspection on whether the receiving end of the remote is effective or needs replacement. In this part, you need to have the TV checked.
Nov 17, 2014 | Televison & Video
My Norcent LCD TV LT2722 Turns on, but whenever you press a button on the remote or TV, it shuts off.
Green "ON" lights comes on (after some jiggling of the on/off button). Nothing else. Black screen, no sound. Where should I go next?
Aug 27, 2011 | Norcent Technologies LT-2722 27 in. LCD...
Does this tv have a VGA port?
The best way to find out is to look on the back of the set where all the plugs are. The computer VGA port is a trapezoid shaped plug usually blue with many holes for the pins of your computer cable.
Jun 09, 2011 | Norcent Technologies LT-3021WS 30 in. LCD...
No power
If there is no power at all replace the powerboard, but if there is a led light on when clicking it to turn it on, then it will be the mainboard.
Jun 18, 2009 | Norcent Technologies LT-3222 32 in. LCD...
Dead no power
hi change ic surface mounted u405 on back of signal board
Nov 17, 2008 | Norcent Technologies LT-2725 27 in. LCD...
Norcent tv model lt2722
I'm Looking for a remote for the Norcent LCD TV model number lt2723? My Norcent will run for 10 minute and turn off so I would have to unplug it to get it back on for another 10 minute is there a sleep timer on this unit? I think that the remote will have that mode.
John
jamac48@aol.com
Oct 27, 2008 | Norcent Technologies LT-2722 27 in. LCD...
Mainboard norcent lcd tv
http://stores.ebay.com/Modules-Accessories-Parts-and-More_Norcent-TV-Parts_W0QQcolZ4QQdirZ1QQfsubZ15964894QQftidZ2QQtZkm
this is all the parts this seller has you coul contact himand see if he has your part and it is not listed yet.
May 08, 2008 | Televison & Video
Norcent Technologies LT-2722 27 in. LCD Television Logo
332 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
