Question about Gateway Computers & Internet
My laptop is running very slowly. HELP ! - Gateway Computers & Internet
  • cocodenim Oct 15, 2008
    help
  • jljonesiii May 11, 2010
    When was the last time you did a de-frag on your hard drive?
    Fragmented files will slow the computer down.
    Genius:
  • 1,124 Answers
This issue can be caused by any of the below possibilities.
Hard disk drive is short on available disk space.
Several software programs have been installed/uninstalled leaving behind bad files and/or confusing the software.
Data Corruption.
Computer is overheating.
Bad Hardware.
Additional information:
If your Internet is slow this document does not contain information about this issue. See document CH000986 for additional information about why your Internet connection may be slow.
PC Solution:
Below are steps for Microsoft Windows that should help speed up the computer or determine why the computer is running slow.
Not enough hard disk drive space
If you have a hard disk drive that is 10GB or smaller, ensure that there is at least 200MB of hard disk drive space free. If you have a hard drive larger than this size, verify that there is at least 500MB of free hard disk space. This available space allows the computer to have room for the swap file to increase in size as well as room for temporary files.
Hard drive corrupted or fragmented
Run Scandisk or something equivalent to help ensure that there is nothing physically wrong with the computer hard disk drive.
Run Defrag to help ensure that data is arranged in the best possible order.
Background programs
Remove or disable any TSRs or programs that automatically start each time the computer boots. .
Hardware conflicts
Verify that the Device Manager has no conflicts, but if conflicts are present, resolve them.
Issues with Windows XP prefetch
If you have Windows XP try deleting all files in the prefetch directory. These are prefetch files and can lower system resources if loading programs no longer being used. See our prefetch definition for additional information about prefetch.
Issues in Windows 95 / 98 autoexec.bat / config.sys
If you are using Microsoft Windows 95 or Windows 98 and do not plan on running any MS-DOS programs from MS-DOS follow the below steps.
Click Start, Run and type command and press enter.
In the MS-DOS window type cd\ to get to C:\> and then type ren autoexec.bat autoexec.ch and ren config.sys config.ch
This will rename your autoexec.bat and config.sys and help make sure memory is being optimized through Windows.
Computer or processor is overheating
Make sure your computer and processor is not overheating, excessive heat can cause a significant decrease in computer performance some processors will even lower the speed of the processor automatically to help compensate for the heat related issues. .
Specific operating system basic troubleshooting
Try running through the basic troubleshooting steps for your operating system.
Erase computer and start over
Virus Problem
Be sure that your computer is not virus or spyware infected
Run antivirus program
Finally, if none of the above solutions resolve your issues, it is recommended that you either reinstall Windows and/or erase everything and then start over.
Hardware issues
If your computer continues to be slow after going over each of the above recommendations it's possible that your computer is experiencing a more serious hardware related issue such as a failing component in the computer. This could be a failing or bad CPU, RAM, Motherboard, or other component.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Posted on Oct 15, 2008
Why are pages broken with code showing?
Run chkdsk.f to check for hdd errors.
Jul 17, 2014 | Computers & Internet
Slowly runing
If you download Advanced System Care from iobit, that has a very good registry repair system for free. If that doesn't help, try updating the drivers from hp and test the RAM.
Jan 20, 2014 | HP ProBook 4510s Notebook
Need help on my computer hardware problem. I am
You are correct to a point. The lower memory is an issue but the main issue is your desktop is so much older so the processing power of the desktop isn't nearly the same of your laptop so it is going to run slower.
Sep 09, 2013 | Computers & Internet
Running very slowly at start-up and accessing file
Look into Upgradeing your ram (memory) also if you hard drive is full you computer will boot up slowly and the computer it self can run very slowly.
Aug 25, 2013 | Computers & Internet
RUNNING VERY SLOWLY
you might have a virus check in your task manager look in process and shut down some process look to see if the cisvc process is running if it is shut it down this will totally make your computer run better
Sep 28, 2012 | ASUS Eee 2G Surf Notebook
The cooling fan of my laptop is not functioning correctly. What do i do?
well is it running slowly or making noise? if it's making a rattling type sound the bearing may have gone out and if that's the can you should replace it, you can find a guide online on how to disassemble it. the fan itself should be relatively cheap. if it's running slowly or something along those lines you can always blow the inside of the laptop out with compressed air. good luck!
Jan 27, 2012 | Compaq Computers & Internet
The laptop runs erally slowly, i have tried defragging, anti-virus software, anti-spyware. I have deleted any programs i dont use and now really dont know what else i can do. Help appreciated. Thanks
run task manager by pressing CTRL + Shift + Escape
then order by CPU and you will see if there is a process that is consuming too much processor then you can end it or see what it is..
also see if you have enough ram
May 14, 2011 | HP 530 Notebook
Compaq cq50 touchpad isnt working, and the keyboard isnt working either when using the usb mouse, and it is all running very slowly.
You have a device conflict. Laptops do not like USB mice.
To fix this you will need the hands-on help of an expert, or
assistance from Compaq (good luck) or the mouse maker.
Feb 19, 2011 | HP Compaq Presario CQ50-110US Laptop
My laptop is runni really slowly
Not sure if you are watching via the internet, but if so than it sounds as if your internet bandwidth is not good enough for the type of viewing you desire. If you can find out what the specs are on that and in addition give me the specs on your computer like what type of operating system, how much memory, and type of Processor you have including make and model of your computer I can help you possibly speed up your viewing process.
Mar 13, 2009 | Acer Aspire 6530-5143 Notebook PC
Compaq presario notebook v5000 windows XP slow start up
This probably won't help much, but it will clean up things.
Also after logging in to windows
  1. Start
  2. Run
  3. type in msconfig
  4. click OK
  5. click startup
  6. click disable all
  7. click apply
  8. click ok
  9. restart
  10. click on the do not show this again when it boots up and displays configuration has been changed.
Apr 13, 2008 | Compaq Presario 2170US Notebook
Computers & Internet Logo
79 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
