Question about Apple Power Mac G5 Desktop
G4 350 mhz agp powermac
I wanted to install a burner in the G4 and once I did nothing works. I have checked all cables, the dvd-rom was set to master and I made sure the cd-rw was set to master as well, after installing the cd-rw I booted the machine up which by the way was running fine, OSX 10.2.8 the boot up froze on me so I reset the boot up and then nothing. After putting the dvd-rom back thinking that it had something to do with the cd-rw still nothing. To get the dvd-rom door to open I have to un-plug the ribbon cable, same as hard drive, to get it to spin up properly I have to un-plug ribbon cable. I have bad feeling that the mother board is toast. Any other suggestions would be appreciated as I am new to Mac's.
  • djeffs Oct 17, 2008
    there is a zip drive attached to the same ide cable as the dvd-rom, I did re-attach it as well but nothing seemed to work after installing the burner. I then put the dvd-rom back as it was when I got the mac and nothing seemed to work again. As I said in my previous post both ide channels have to be un-plugged to get any response from either the dvd-rom or the hard drive. The only time I have seen this before is in a PC when you hook up two hard drives on the same cable and both are set to master. I then tried to hook the dvd-rom up with out plugging the zip drive in and hooking the hard drive up on the other ide channel but still the same problem. Thank you for any help you can give me, I am a newbie when it comes to mac's but am A+ certified with PC's, I work in printing and got the powermac given to me so if you think it is the mother board then I will purchase one. Thanks again.
  • Krabby May 11, 2010
    Is there a zip drive installed as well?
    Novelist:
    Champion:
  • 233 Answers
There are two IDE buses on these. On each bus the devices must be set as master and slave just like a PC. Disconnect the ZIP 100 drive as it is obsolete. This will free up a slave position on that bus. You can also get a PCI card if you want to add more devices such as hard drives.
Posted on Dec 19, 2008
    Problem Solver:
  • 5 Answers
Can you try installing the new burner as a slave and the zip as the master?
Had a pc once that refused to boot at all with a new DVD burner in it, alongside a DVD-ROM. The burner was replacing a CDRW drive, swapped the drives master and slave settings over and it worked.
Posted on Dec 02, 2008
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
How do i instal as a second player on an intel board
you remove the first dvd or cd rom. in the back where you plug in the cables, search for a diagram of master, slave and cable select pin sets. on both of these roms, there will be one. set one to master and the other to slave. make sure the master is connected to the ide cable plug closest to the motherboard. the slave will be the last one on the IDE cable.
Jun 04, 2010 | LG GSA-H42N 18x DVD RW DL IDE Drive...
If i put in a cd, it doesnt load or install or anything. nothing comes up. can you please help?
Please check if the CD/DVD driver is installed properly:
To check:
1. Click Start - Right-click My Computer Choose Properties
2. Click Hardware then Device manager
3. Check if there is a yellow question mark on CD/DVD
If Yes - Reinstall CD/DVD using WINDOWS UPDATE
Alternative:
1. Try to check for loose connection between your IDE cable and IDE Socket
2. Check if the 12V Cord from the Power supply is properly connected to device
3. Check MASTER or SLAVE setting:
Normally the IDE Hard disk will be your PRIMARY and the CD/DVD will be your secondary/slave -----
MORE DETAILS ARE DESCRIBE THOROUGHLY IN THIS SITE:
http://www.ehow.com/video_4444761_setting-pins-cd_dvd-hard-drives.html
Please Rate. Thanks.Cheers!
Apr 22, 2010 | Samsung SM-352F CD-RW/DVD-ROM (Combo)...
My cd dvd drive is not working ... i troubleshooted and it says everything is ok ... i can hear it attempting to spin the cd but it wont spin it just clicks over and over again
Is this a new problem--ie it was working before? Or is this a newly installed drive?
If it is newly installed then the jumpers are not set correctly. Check that the jumper on the drive is set correctly--Cable select, slave or master as approriate
Dec 18, 2009 | Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo)...
Installed hp dvd r/rw drive, computer does not recognize hareware
You may want to check your Master/ Slave or CS settings on the back of drive.
If you are useing one cable, IDE cable for both the HD and CD, the Hard Drive sould be set to Master and the secondary drive ( CD ) will be set to slave.
If two cables are used, both should be set to master.
You can F-10 into your BIOS settings to check and see if machine is seeing the connection changes.
Sep 27, 2009 | AOpen ( 91.4ID37.074) (91.4ID37.074)...
CD ROM MODEL LTR-48327S IS MY CD BURNER WHEN I added a new cd/dvd player burner my cd burner quit working what is the problem?
each one has jumpers on the back. tiny plastic thing that slides over two pins. there are six pins. three sets of two. one device must be set to master one to slave or they wont work.
they are usually labeled with a picture or M S CS
master, slave, cable select.
Aug 22, 2009 | Lite On LTR-48327S CD-RW Burner
Dvd/cd burner
Go to bios settings, usually you go there by pressing F2, or Del, etc , depending on your motherboard.
In the first bios page often you find installed drives, your dvd should be there.
On some motherboards, like many dell's PC MB, you need to do explicitly HDD/cd/dvd autodetections to have the DVD installed . In this case you need to locate the bios command saying autodetect disk drive. If the disk is not detected you may need to check the jumpers at the back of the dvd (eventually test it a Master on single cable). If you are using IDE ribbon cable check also that the cable is plugged in the right way.
Check this page for a general procedure.
Regards
Apr 13, 2008 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Dvd rom drive
is cable on master jumpers or slave ?
Feb 07, 2008 | NexxTech (COB6V5216) Burner
Nero cr-rw burner install
is your hard drive the master on the primary cable? You shouldn't need a digital audio cable unless you want digital audio. Are you using Nero software witht he drive? may have to re-install the software, or better, uninstall it, clear the registry with CCleaner (free download on the web) and then try a fresh install.
Dec 13, 2007 | LG CED 8120B CD-RW Burner
Msi motherboard
Try using the cd rom on the second cable as a master.
Let me know whats up
Nov 15, 2007 | Intel Motherboard
Apple Power Mac G5 Desktop Logo
76 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
MarkMAlford
MarkMAlford
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
