Question about Acer Computers & Internet
Notebook was working fine when using from electrics then the battery power showed up on screen as critical stage and then the screen went blank, i tried to charge and also work without the battery just using the electrics but nothing happened
  • 70 Answers
You probably need a new power adapter
Posted on Oct 15, 2008
Hi Good Monring .. I was working on my HP DV2
Hello, heres a few ideas.
Does the computer show no signs of power at all? If so, it might be your motherboard that went bad.
I would also try without the battery in and just plugged in, if it works wihtout the battery then its the batteries fault.
If your computer DOES show signs of life, try plugging it into an external monitor, then power it on. It should show up on the external monitor if its a screen issue.
Another thing to attempt would be to take your ram out. There should be some small "sections" on the back of the laptop. Remove the one that has a small image that looks like a little chip (attempting to look like ram) Then take one stick out and see if it boots, and if not, attempt to switch the two.
Letme know how that goes, and i'll be willing to help you more.
Mar 12, 2011 | HEWLETT-PACKARD Pavilion Dv2102Au...
My HP laptop was working fine, and then suddenly the screen went blank. When I reboot, the power light stays on and you can hear the hard drive spinning, but the screen stays blank.
unhook all usb cables and power cable, take out battery. Hold down Power button for 60 seconds, which will get rid of all static electricity. Plug in all cables again and check.
If still facing problem there will be some connection issue inside the lap.
Please let me know whether this works or not.
Dec 20, 2010 | Computers & Internet
DELL 1525 laptop boot issue. When switching ON it shows only blank screen. Grateful if you could help resolve this issue
Have you got an external screen you can plug in to prove the video? Try this check list:
Dead Laptop.
Try firstly removing the laptop's battery as it may be at a critical voltage and the system will not start because of it. Plug in your ac adaptor and monitor what happens. Does the power light illuminate? If it does it should then boot up, if it doesn't, try a known good ac adaptor before going any further.
If the adaptor is fine then you have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Nov 09, 2010 | Dell Inspiron 1525 Notebook
Yesterday I reinstalled my windows on my laptop which has 20 gb hard disk, i created two partition drive c (5 gb) and drive d (15 gb) and installed successfully. after that i put my pen drive and copied...
you killed the laptop with out a UPS and you get a power surge with a dead battery them laptop takes the surge and kills the computer. You can remove the battery and unplug the power supply and hold the power button down for a minute then plug the power back in without the battery and try pushing the power button to see if it comes on if it does your lucky. IF it does not put the battery back in and try again. if There is still no power you have killed the power converter or killed the computer.
Feb 05, 2010 | IBM ThinkPad A31 Notebook
My Acer Aspire 5100 just went blank. There is a
Generally, an indication that the battery is critically low. It appears that the AC adapter is not powering the system and not charging the battery.
Jan 09, 2010 | Acer Aspire 5100 Notebook
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Compaq presario V2000 doesn't start
you might have shot out your battery because if electrical curent is goging in to the computer (te orange light is going on) but the computer wont turn on it might be a problem with your battey
please rate
May 30, 2009 | HP Compaq Presario V2000 Notebook
Laptop won't power up
You need to replace the RAM ..
May 20, 2009 | Fujitsu LifeBook S6231 Notebook
HP Pavillion DV9700 Laptop Blank Screen on Boot Problem
remove battery,ac adapter and other external medias,then hold on power button for 30seconds
later
with ac adapter attached try to power on still probs ...then its bios probs need to use bootable disk or recovery disk of your laptop
Feb 20, 2009 | HP Pavilion dv6000z Notebook
Acer One Screen Won't Come On--
Hey,
if this computer is still under warranty you can contact acer to get a replacement or repair for it.
If you are outside of warranty there are a few things we can try, one unplug the battery and ac adapter for 15 minutes, plug in the ac power and try starting up.
if that doesn't work, call acer and confirm your warranty. if you don't have warranty we can try other things. if you do have warranty and the repair is free, use it.
Let me know if you need anything else.
Thanks,
Ekse
Feb 16, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
