Question about SanDisk Sansa m250 MP3 Player
My device version V02.01.09A - SanDisk Sansa m250 MP3 Player
Perihale blootooth driver
To resolve this issue, you will need to install the device driver for your Bluetooth device. If the device came with a CD or DVD containing device drivers compatible with your version of Windows, insert that disk into the disk drive and follow the instructions to install the driver.
If your Bluetooth device did not come with a driver installation disk, you will need to go to the device manufacturer's website and download and install the latest driver for your device. To do this, go to the hardware manufacturer and search on the latest version Bluetooth driver for your device. Follow the instructions.
Windows 7 Compatibility Center
Windows Mobile Devices
If youre using a Windows Mobile device, follow the steps below to updte to the latest version of Windows Mobile Device Center 6.1
  1. Go to the Microsoft Windows Mobile Device Center 6.1 site
  2. Click Continue.
  3. If prompted, download the Windows Genuine Advantage software.
  4. Click Download, then click Run.
  5. Follow the onscreen instructions to install Microsoft Windows Mobile Device Center 6.1.
  6. Click the Start button, type device manager in the Search box, then click Device Manager.
  7. Expand Unknown Device, right click on Bluetooth Peripheral Device, then click Update driver software.
  8. Click Browse my computer for driver software, then click Let me pick from a list of device drivers on my computer.
  9. Select Bluetooth radio from the list. Under Company name choose Microsoft Corporation, then under Drivers, choose the latest version of Windows Mobile-Based Device Support.
  10. Click Next. If any warnings should appear, click Ignore, then when prompted, click Finish.
  11. Restart your computer.
Nov 09, 2013 | Lenovo Computers & Internet
Tip
Windows Vista: How to roll back a driver
Device drivers are often updated to add functionality or increase performance. Usually, installing the newest driver is a good thing, but sometimes there is a bug in the driver software, or the new driver is incompatible with your system, and you'll want to go back to the previous version. Windows saves a copy of the old driver, so you can easily "roll back" to the version that you know works.
To roll back a driver in Windows Vista, follow these steps:
A. Click the Vista orb to open the Start menu.
B. In the Search bar, type "device" and then click Device Manager in the list of results.
C. Click Continue when the User Account Control window pops up.
D. In the Device Manager, click on the plus sign (+) next to the appropriate category, and double click on the device that needs its driver rolled back.
E. Go to the Driver tab, and click the Roll Back Driver button.
F. Follow the system prompts.
If the Roll Back Driver button is grayed out, that means there is no previous version of the driver to roll back to. You can visit the device manufacturer's web page and try to find an older version of the driver there.
It's important to note that rolling back a driver installs whichever version of the driver you had loaded on your system, not the second most recent version. So if you had version 1.0 installed for your wireless keyboard, then you updated to version 3.4, rolling back your driver would reinstall version 1.0, no matter how many versions had been released between the two.
on Jul 20, 2010 | Computers & Internet
Tip
Samsung rest code Service codes Samsung: E900...
samsung rest code Service codes Samsung:
E900 software version: *#5002*8376263#
E900 full reset: *2767*3855#
Service codes Spice:
S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200
S410 engineer mode: *#3646633#
S900 software version: *#8375#
S900 serial no: *#33778#
Service codes Philips:
S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
Service codes "Chinese" models:
default user code: 1122, 3344, 1234, 5678
Engineer mode: *#110*01#
Factory mode: *#987#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Restore factory settings: *#987*99#
LCD contrast: *#369#
software version: *#800#
software version: *#900#
Service codes BenQ:
software version: *#300#
test mode: *#302*20040615#
Service codes Pantech:
software version: *01763*79837#
service menu: *01763*476#
reset defaults (phone/user code reset to default): *01763*737381#
Service codes VK-Mobile 3xx, 5xx:
software version: *#79#
software version: *#837#
service menu: *#85*364# (hold #)
Service codes VK200, VK2000, VK2010, VK2020, VK4000:
service menu: *#9998*8336# (hold #)
reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
on Feb 09, 2008 | Samsung SGH-E900 Cellular Phone
49 FF81 error on HP Laserjet 3035xs MFP
49.XXXXX ERROR To continue turn off
then on
A critical firmware error has occurred.1. Turn the device off, and then turn the
device on.
2. Go to www.hp.com/support/
LJM3027mfp or www.hp.com/support/
LJM3035mfp to check the latest
firmware image version. If the latest
firmware image version is newer than
the one installed on the device, upgrade
the device.
3. Try printing a job from a different
software program. If the job prints, go
back to the first program and try printing
a different file. If the message appears
only with a certain software program or
print job, then the error is in the software
program and not in the device. If the job
fails to print using a different software
program, then turn off the device and
disconnect all cables that connect the
device to the network or to a computer.
4. Remove any DIMMs and EIO cards, and
then turn the device on.
5. If, after removing DIMMs and EIO cards,
the device behaves normally, turn off
the device and reinstall DIMMs and EIO
cards one-by-one, turning off the device
off and then on again each time you
reinstall a DIMM or EIO card. If a certain
DIMM or EIO card causes the message
to reappear, replace the DIMM or EIO
card.
6. Reconnect all cables that connect the
7. If the message persists, replace the
formatter (see Formatter on page 116).
Apr 03, 2012 | HP LaserJet M3035xs MFP All-In-One Printer
Trying to set up TomTom 340 XL TM. downloaded new map, etc but when i want operate it, i get a 'no maps found!' message. At my TomTom Home screen, it doesn't appear that maps are not on my device but the...
It happens when the device doesn't recognize the maps. That's why - in such a case - you have to downgrade the version of the maps.
What Navcore Version do you have on your device? Here's a cart to help you.
[DON'T FORGET TO RATE MY SOLUTION IF HELPFUL! THANK YOU!]
Mar 06, 2011 | Tomtom GPS
Hi. is there any applications to restart my nokia N900...? thank you...
Restore a backup
1 Select > More... > Backup.
2 Select the desired backup and Restore.
3 Select the data types to restore.
4 Confirm that you want to restore the data.
If the backup is password-protected, enter the password,
and select OK.
5 If your device contains a newer version of the files than
the backup you are restoring, the device asks you to
confirm if you want to save the backed up version, or
cancel data restore. Select from the following:
Yes - The device overwrites the current version with
the backed up file.
Yes to all - The device overwrites all conflicting files
without further confirmation.
No - The version on the device is not replaced
hope this helps
John
Jan 22, 2011 | Nokia N900 Smartphone
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
Blackberry Device Software 8300, Version 4.5
Try this one: First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
Dec 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
Open Questions:
SanDisk Sansa m250 MP3 Player Logo
110 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
