Question about Electrolux Central Vacuum
Electrolux Central Vac Hose Clogged
Our hose is clogged with a paper towel just behind the handle. I can get it out so I wonder if it's possible to remove the handle? I pulled out the lock pin but don't know how to remove the handle from the hose.
Thanks for any help.
John
  • 4 Answers
John,
There are several handle types. The pump style has about 8 phillips screws that hold the handle together. Make sure it is not connected to the wall as some have 120V cords or direct connect pins to supply power to a motor driven brush.
The two halves will separate and if it has slip rings the tube will lift up out with the hose.
If this is a low voltage hose, there are three tabs at the base of the handle you press in and pry out the end piece. You will need to remove the switch contacts before the hose will pull out. Remove the phillips screw that holds the switch trim in place and lift out. This will allow the cover to be removed to lift the contacts off the slip rings and the hose will drop out.
Hope this helps!
VR
Posted on Nov 18, 2008
We have suction at the outlets but when we plug the hose in we have no suction at the carpet vaccuum head.
Is there suction at the end of the hose? If not, the hose is clogged. Generally the blockage is located near the handle, but sometimes at the other end. Occasionally, if something long, like a straw, is sucked up, it will get caught somewhere else in the hose that's impossible to get to.
You can try to hold the wand end of the hose directly to the CV tank and turning it on. This should clear the clog. If not, hold the handle end to the blower of a shop vac or canister and turn it on. The other end should be either in a large plastic bag, inserted in the in port of the vacuum, or directed outside.
If there is suction at the end of the hose, the most likely place for a clog is at the elbow on the power nozzle or just behind the brush. This can be cleared by using the handle of a wooden spoon or similar blunt object to push the clog back out toward the brush.
If none of these help, take the vacuum to the nearest Aerus Electrolux store for assistance.
http://www.aerushome.com/storelocator/
Jan 16, 2011 | Electrolux Central Vacuum
I have an older model Electrolux central vac. When I put the hose into the wall outlet, the cannister comes on but there is no suction ? What is needed to correct this?
Three things are the most likely.
1. Since it's an older model, the hose is likely well worn and probably has leaks at each end where it attaches to the handle and connector at the other end. If this is the case, a new hose is needed.
2. A blockage in the hose. To check the hose for blockages, detach both ends and drop a coin down one end. Lift the hose a little at a time so coin drops out the other end. If it doesn't, there's a clog. It will probably need to unclogged at an authorized Aerus Electrolux store.
3. A dirty filter. This is probably the first thing to check for, since it's so easy. If it's dirty, it needs to be thoroughly rinsed under warm water. Then allowed to thoroughly air dry prior to use. For this reason, it's highly recommended that an ECV owner have an extra filter on hand.
Is there suction at the end of the hose, or is it just at the power nozzle there's none. If the hose has good suction, check the power nozzle airway. If it's blocked it can easily be cleared by pushing the clog back toward the brush with the handle of a wooden spoon, or other similar object.
Jan 15, 2011 | Electrolux Central Vacuum
Poor suction in system - I have used shop vac to suction all three receptacles. Have checked bag and cleaned everything. Still poor suction. I have one receptacle in garage that works perfectly. Must...
Have you checked the hose for clogs or leaks. Clogged and leaky hoses are an area of concern with any central vac. Unless you hose has a hose sock, then wear and tear from constant rubbing on floors and other surfaces will result in holes and cracks. Pulling the hose can also result in leaks where the hose attaches to the handle and intake connector.
Mix some dish soap with water.
Use shop vac to blow air through hose, with other end capped or "clogged".
Apply soap solution to each end of hose.
If bubbles form, this indicates leakage. Hose will need to be replaced.
Oct 25, 2010 | Broan-NuTone CV450 Central Bagged Central...
Is there a second filter
You have not posted a brand, however central vacs with an internal hanging `self cleaning ` filter seldom contain another filter with the exception of Eureka or Kenmore which may have a secondary optional paper filter installed. Check the bucket and the gasket first. Eureka and Kenmore made by Eureka are prone to a defective gasket which disintegrates with wear. The bucket should sit snug on any unit with no play.
To test for proper suction check at the vac intake itself. If the suction is strong here and weak elsewhere your problem will be either a clogged vac line, a leak in a pipe or an inlet door sagging open, last of all a clogged or partly clogged hose.
Check your hose by dropping a coin through the handle and shaking it down to the other end. If a coin makes it through your hose is clear.
You can test each inlet with a numbered tissue and your hose. Mark one for each inlet and check the tank to see what made it through. If any fail to make it through, go to that inlet with another vac and draw the blockage backwards out the inlet. Then retest
Also listen for a hiss at each inlet with the hose plugged in elsewhere. The hiss indicates a leak behind the inlet in the wall. Check for worn seals or misaligned o rings in the backing plate where the inlet connects.
Last of all inspect the pie for possible cracks from impact . If you listen closely you will hear an audible echo along the pipe path (even within the wall) if a connection has separated or a pipe is damaged.
Please post back with what you find or if you need more help.
Oct 13, 2009 | Vacuums
Low suction
1) Have you checked the filter? If it is clogged your suction will be low. Also, you could have a pipe loose where you can't see. Make sure that you can get a coin to go all the way through the hose. make sure the suction motor ( the unit ) is coming on.
2) Call the repair man.
Aug 10, 2009 | Electrolux Central Vacuum
Metal hanger stuck in central vac hose
there should be a pin push it in then pull out power head then try to pull out hanger
Feb 08, 2009 | Electrolux Central Vacuum
I need a new hose for my Electrolux central vac
Do you need a new powerhead too or only the hose? If you need a new powerhead than I would recommend looking at the Imperium Pro Elite Attachment set. It is an excellent quality powerhead and hose. If you only need a new hose than you will need to contact the Aerus because they will be probably be the only company who can sell you a hose that wil be compatible with your powerhead. Their website is http://www.aerusonline.com/products/
Jan 21, 2009 | Electrolux Central Vacuum
Electrolux central vac problems
I work on many types of units. If you electric floor brush runs but you have no suction then there is possibly a problem with the relay board that allows you to turn on the suction from the hose handle. This is a low voltage (24 V) switching loop circuit that will cause the 120 V motor in the unit to run.
Inside the wall valve are two brass pins. NOTE: there are 120V valves installed on some systems known as a Super Valve. A shock hazared exists if you work on that type of valve. That being said. In the round portion of the valve you can use a garage hose that has a 360 deg. chrome ring to test the valve. The ring completes the circuit causing the unit to power up and suction at the end of the hose. If the suction is weak, there is a colg in the pipe. If you hear no airflow, the relay inside the unit did not energize or the motor is bad.
To test: go to the unit and turn the switch on the side to "manual" if the unit turns on the motor should be ok. DO NOT RUN THE UNIT without and open valve. In some brands dammage to your motor will occure.
If the unit did not run, look for a small button near the switch. This is a circuit breaker for the motor. If it is poped out and you hear a "click" when you press it in there is most likely motor problems and someone should be contacted for repair.
Hope this helps!!
VR
Mar 07, 2008 | Electrolux Central Vacuum
Vacuums Logo
838 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
