Whirlpool Washer I am finding metal clips in the drum about 1/2 x 3/4 inch. The machine washes and the spin cycle works fine but getting a noise or a grinding sometimes. I have found 3 or 4 clips so far. Please help before something else goes wrong. Thank You Dave
  • 750 Answers
Need the model number???
The grinding sound sounds like the transmission if it is a top load washer.
If that starts to happen that the transmission it is not always worth fixing.
If the washer is 8 years old or more and you have to invest in a trans!!!!!
No the clips can only be some thing that was in a pocket or fell into you laundry basket .
And sounds unrelated to the grinding!
If you plan to keep the washer, better not leave that grinding go!!!!!!!!
Let me know how you do.
Thank You for using our site.
Huuum
Posted on Oct 15, 2008
Samsung front load washer, jerks and makes noise when it first starts spinningthen it smooths out, and works fine.
on many machines that is normal, the shaking continues until the load is distributed relative evenly around the spinning drum. It is also possible it is the main bearing but I am not sure. The noise I am talking about would have been there since new. These links may help. Washer has noise during spin cycle Whirlpool Maytag Sears GHW9100LW1 Washer is Making Loud Noise
How To Fix Washing Machine Making Noise During The Spin Cycle
http://www.partselect.com/Repair/Washer/Noisy/
May 28, 2016 | Samsung Platinum Front Load Washer -...
Duet washer making a loud noise on spin cycle, it squeaks on low spin and then when it gets up to high speed, it is really loud. What could this be?
In most cases it is something that is sticking between the drum and the housing. Check inside the boot by the door. If that is not helpful move the drum by hand and listen to see if you can locate the area of the noise.
Dec 30, 2015 | Whirlpool Duet GHW9150P Front Load Washer
My maytag hav2558aww wont turn on wash cycle
Possible that the grinding noise comes from the drum, irregular movement or broken paddles.
You can try and attempt only if equipped with a fundamental understanding of the working .
I shall give you some tips to this click 1..: Washing Machine
2. Replacing bearings
Jan 24, 2013 | Maytag HAV2558 Top Load Washer
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
Grumbling Noise on Spin Cycle
If there is any form of grinding at all when the drum is turned than the rear bearings in the machine is going bad. This will only progress an get worse, then eventually start leaking and grinding and finally lock up.
Apr 26, 2012 | Bosch Washing Machines
The agitator works well during the wash cycle. When the drum spins, the agitator will not if the clothes touch the agitator. The water empties, but the agitator prevents the drum from spinning.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following Whirlpool Service manuals for top load, direct drive washers. They describe what happens in the transmission when the washer goes into spin mode:
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Also see the Whirlpool Parts list for their Commercial washers, although the consumer models use the same transmission.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Basically whats happening is this.
When the washer goes into spin mode two plastic cams are forced together and raise a gear on the main agitator shaft that is supposed to keep the agitators from spinning. If the cams are worn (not necessarily broken) the gear doesn't lift high enough to completely disengage the agitators. We had the same problem. Ours was a major gear noise but a clicking could also be a symptom as well as the agitator keeping the drum from spinning. A set of Whirlpool Agitate Cams (part number 62580/01) cost about $15.00.
It's a bit messy to fix (15 oz. of 80-90 weight gear oil in the transmission available at auto parts stores) but very inexpensive.
See the following for how to remove the transmission.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators.
The top agitator uses a plastic 1/2" drive bolt. A 1/2" socket extension works well.
You don't have to remove the drum.
You can also see this site for removing the transmission.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 15 Oz of 80-90 weight gear oil. (Available at auto parts stores)
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
I'd also check the Motor Coupler (a $15.00 item that tends to wear) while you have the transmission out.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Jan 20, 2011 | Kenmore 22422 Top Load Washer
When in spin cycle there is a grinding noise
Here are solution on how to solve the noisy problem.
Although a noisy washing machine is not typically a sign that something is broken, it definitely can be annoying. Usually the noise from a washing machine can be fixed fairly easily, but a few different fixes may need to be tried before it can be determined what the true culprit of the noise was.
Instructions what you need to solve this problem.
  • Flashlight,Screwdriver,Drive belt
  1. Check the drum bearings if the washing machine is making a rumbling noise. The noise may possibly stem from water getting into the bearings. Take the belt off and spin the drum by hand. If there is a rumble, remove the bearings and replace them with new ones.
  2. Check the spider at the back of the drum. The spider is the three-armed device that holds the drum in place. If there is one loud noise on each revolution of the drum, there is a good chance the spider has partially become loose. Tighten the bolts on the spider to silence the noise it causes.
  3. Check for coins. If the noise the washing machine makes sounds like metal on metal, there is a good chance that some change has slipped from a pocket and is now in the dryer. Take a flashlight and look in the drum for coins, paper clips, and other small items.
  4. Adjust the legs. Many washing machines make more noise than they should because they have not been properly balanced. Re-adjust the legs to make sure that they are all even. This will keep the washing machine from moving and will ensure that the noise it creates while it moves will go away.
  5. Replace the drive belt. Often a high-pitched squeaky noise can come from a drive belt that has been worn down. Simply replacing the old belt with a new one will fix this problem.
Please rate this solution.
Good luck and thanks for using fixya.
Jan 12, 2011 | Maytag Performa PAV2200
Missing balance ring clips on whirlpool washer model # LXR9445JQ0
just buy the clips, watch a video to remove the housing of the washer. it is a simple fix. should be below $20 to get the clips, j
http://www.partselect.com/PS874751-Whirlpool-3956205-Balance-Ring-Top-of-Inner-Tub-White.htm?SourceCode=1&SearchTerm=LXR7244JQ1&ModelNum=LXR7244JQ1#Instructions
Jul 15, 2010 | Whirlpool LXR6432JQ Top Load Washer
Whirlpool WF665/1 clunking/grinding
Could be worn drum bearings.
Jun 04, 2010 | Washing Machines
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
