Question about Samsung SCH-i600
Reset or hard reboot
I would like to clear the data from my i-600. How do I do a hard reset or delete all data?
    Scholar:
  • 125 Answers
Hey here is the manual for your phone take a look at it and see if you can find the info you are looking for. Alright.
Posted on Oct 15, 2008
How to reboot cherry mobile spark tv?
Here`s how to hard reset you Spark Tv
1. Turn off the your Cherry mobile Spark
2. Press power button, Volume down and home button at the same time.
3, Wait for a Spark TV logo then release power buttons and continue holding Volume down and Home.
4. Scroll down and select wipe data then press home button
5. Select reboot and your phone will be unlock but all files in the internal storage will be deleted.
or try this
SPARK TV cherry mobile HARD RESET too many patterns attempt solution
POWER ON + VOLUME DOWN BUTTON press together in 20 seconds or until the Android system recovery <3e> appeared
Press volume down to wipe data/factory reset then press power on
Press volume down Yes -- delete all user data then press power on
Press power on to reboot system now
After reboot HARD RESET was done
May 20, 2014 | Nokia E Cell Phones
Need to do hard reset on samsung sph m910
Follow these simple steps to reset the phone
[hold the vol down button and call button press Same time and then release the power button]
and then menu appear, it work for sprint samsung intercept
Step one, Turn the power off. You need to pull the battery out and reinsert it if your phone gets frozen
Step two, Hold the Volume Down button
Step three, Press and release the Power button
Step four, a menu appears that allows for Fastbook, Recovery, Clear Storage, and Simlock
Step five, press the Volume Down button to Select Clear Storage
Step six, Press and release the Power button
Step seven, make your decision by touching one of the two options: Volume Up for YES and Volume Down for NO
If you selected YES, all data will be deleted from the phone including third-party applications. The Samsung Intercept will reboot to its original data.
Source:
http://samsung-phones-apps.com/how-to-hard-reset-samsung-intercept-sph-m910-to-factory-default-settings.html
Aug 16, 2011 | Samsung Cell Phones
Every so often my thunderbolt will crash and reboot for no apparent reason. Is this normal or a malfunction with the phone
There are a lot of software issues with some applications that lock up the phone.
Try deleting newly downloaded applications and work backwards until your phone does not reboot again. Any paid for apps can simply be re-downloaded through the Android Market.
If this does not work, attempting a factory reset will be your next step.
Factory Reset
1) Make sure you back up all of your contacts, pictures, etc. Factory Resetting could possibly delete all data off of your microSD card, and you wouldn't want to lose any of it.
2) Once done, from the home screen tap the Menu key.
3) Tap the Settings Option.
4) Under Settings, tap Privacy
5) Select Factory Data Reset
6) Tap Reset Phone.
Once done, your phone should be restored to factory defaults.
If for some reason your phone has decided to continue crashing and rebooting, you must perform a Hard Reset. This will undoubtedly remove contact information.
Hard Reset
  1. Remove the battery and replace it.
  2. Press and hold the Volume Button
  3. Press and hold the Power Button until the phone powers on.
  4. You should see a simple menu showing options such as Fastbook, Recovery, Clear Storage and Simlock.
  5. Using the Volume Down button to navigate, Highlight Clear Storage
  6. Press the Power Button to select Clear Storage
  7. Confirm your decision with Volume Up for Yes. If you feel like backing out, press Volume Down.
Remember, everything will be lost from this point on; so be sure you have EVERYTHING backed up that you do not wish to disappear. This will return your phone to it's original, out-of-the-box condition, software-wise.
If even, after the Hard Reset your phone still reboots, contact your Customer Service department for a warranty replacement.
Jun 03, 2011 | HTC Thunderbolt (8 GB) Smartphone
My phone reboots on its own......what could be the problem?
Hi there
You can try doing a factory reset/hard reset of your phone to resolve the problem. You don't have to worry about the data and files in your phone's microSD card since that will not be deleted. But it will delete all your data and customized settings and remove all applications that you installed. If you want, do a backup of any data or files that you want to keep before proceeding with the hard reset.
There are two ways to do the hard reset: via settings and using phone buttons.
Performing a factory reset via settings
1. From the Home screen, press MENU and then tap Settings.
2.Scroll down the screen and then tap Privacy > Factory data reset.
3.On the Factory data reset screen, tap Reset phone, and then tap Erase everything.
Performing a factory reset using phone buttons (If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.)
1. With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
2.Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button..
3.Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.
4.Press VOLUME UP to start the factory reset.
May 07, 2011 | HTC Desire Cell Phone
Master reset code galaxy s
How to hard reset the Samsung Galaxy S
We show you how to factory reset the Samsung Galaxy S to clear all data and restore its original settings
Published on Jun 3, 2010
The Samsung Galaxy S is highly customizable and you have been hard at work tweaking it to your liking, but now the fun is over and you want to return it to its factory settings again. Here, we show you how to hard reset the Samsung Galaxy S with step by step instructions.
Please note that all data will be deleted from the Samsung Galaxy S as a result of this procedure. This process does NOT delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password, then tap Yes to confirm
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your Samsung Galaxy S is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Press and release the Power button
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button
  7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If you selected YES, all data including third-party applications will be deleted from the Samsung Galaxy S. Once the wipe is complete, the phone will reboot to its factory fresh state.
Dec 11, 2010 | Cell Phones
I have no sound on U tube
In this regards I would suggest you to reset the Internet explorer settings on the computer by following the below steps:- Internet Explorer 7:
? Tools ? Internet Options ? Delete? Delete files ? Yes
? Delete cookies ? OK
? Delete history ? OK
? Close (browsing history window)
? OK and then reboot(restart) the computer.
If Internet Explorer 8:? Tools ? Delete Browsing History
[. ] Preserve Favorites (leave blank)
[x] Temporary Internet files
[x] Cookies
[x] History
? Delete
and then reboot(restart) the computer. If using Mozilla Firefox 3:? Tools ? Clear Private Data
[x] Browsing History
[x] Download History
[x] Saved Form and Search History
[x] Cache
[x] Cookies
? Clear Private Data Now
and then reboot(restart) the computer. If using Mozilla Firefox 3.5/3.6:? Tools ? Clear Recent History
Time range to clear: ? Everything
? Details
[x] Browsing & Download History
[x] Cookies
[x] Cache
? Clear Now
Nov 22, 2010 | Computers & Internet
Phone keeps rebooting
is the button near the reset hole? possibly the button is somehow pressing the reset switch, possibly stuck somehow. Other than that try a hard reset, instructions below.
Soft Reset
Put your stylus in the hole in the lower left corner where it says “Reset” Soft Reset will reboot your device just like when you reboot your PC. No data will be lost, under normal circumstances that is.
Hard Reset
Hold down the Power button (Top Right corner) and at the same time put your Stylus pen in the hole where it says “Reset” (Lower Left corner).
Hard Reset will delete all data you have put on the device, Programs, Settings, Mail, SMS, MMS, etc., so be careful and make a backup before doing this.
After a hard reset, you will have a complete clean new install of Windows Mobile on your device.
Things that are not deleted
  • Data on \Storage Card
  • Data in \Storage folder
Oct 15, 2008 | Siemens SX66
Palm treo 600, hangs while picking up calls and wireless mode goes off, deleting all data
Perform a hard reset, and clear the data off the treo.
Hold down backspace and the K key. While holding both of those down, hit the reset button on the back. Hold all for a few seconds. The screen will flash white and then turn off.
Then plug it into the charger cable. It'll turn back on and get you to put in all the settings again.
Then it will work correctly.
Feb 07, 2008 | Palm Treo 600 Handheld
Deletinjg contacts.
I suggest you hard reset the Treo 600 to remove all former data and the username associated with the phone. Press the power button next tot he antenna and perform a soft reset at the same time. Dont let go of the power button until the Palm Logo appears. Then you will see a message asking if you want to delete all data. Removing portions of the old data is not an easy task.
Sep 12, 2005 | Palm Treo 600 Handheld
BIG PROBLEM: After hotsynch Palm resets over and over
You need to hold the "up arrow" while resetting, this will allow you to delete all info. That may not be what you want to do, if so, the only other option you really have is to do a soft reset, which is holding the up arrow and selecting "don't delete data". If the delete all data is STILL hanging after a hard reset, you can do a battery reset, which drains the battery, erases all data and goes back to "factory settings" There are two methods for this: While holding down the J & L keys, click the reset button on the back and hold it for 4 seconds. Or While holding down the K & backspace keys, click the reset button on the back and hold it for 4 seconds. Google "treo 600 battery reset" for more details
Samsung SCH-i600 Logo
280 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
