Question about Cameras
JVC GR-D91U MINI DV NO POWER SO CAMERA WILL NOT WORK AND TAPE WILL NOT EJECT REPLACED BATTERY AND STILL HAVE PROBLEM ALSO WHEN CHARGER IS PLUGGED IN --CAHRGING LIGHT DOES NOT GO ON
I haven't exactly fixed this problem as of yet but I do know what is causing it. The tape that you last put in is defective and to keep from causing more problems the camera has shut down. The problem is that the only way to fix it is to remove the mini-dv. I am looking for a tool small enough to remove the screws that will allow me to manually extract the defective mini-dv. I am hoping this works, and will let you know what I discover.
Posted on Jan 13, 2009
Why doesn't my Mini DV have any power?
Your power lead is really only a charger and doesn't actually power your camera. What you have is a dead battery. All rechargeable batteries eventually give up, and it's time for a new one. You can risk a 2nd hand one, but it may show the same problem sooner or later. The good news is that they are only about 10 pounds on auction and similar sites..
May 13, 2014 | JVC Video Cameras
JVC Mini DV Camcorder GR-D31EK When plugging in the power supply, nothing happens. Power lead is working. Will not charge battery. Cannot eject tape cassette.
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jan 24, 2011 | JVC GR-D31 Mini DV Digital Camcorder
Safe mode when ejecting tape
hi,
its a moisture problem, if you are tecenition then open your camera and clean the power cable properly and fix it properly , you got magic,and its 110% working
Sep 27, 2009 | JVC GR-DVL320 Mini DV Digital Camcorder
Tape jammed in jvc camcorder
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape.
Sep 08, 2009 | JVC GR-D250 Mini DV Digital Camcorder
Canon ZR-800 Mini DV Camcorder tape stuck
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined.
Feb 23, 2009 | JVC GR-DV800U Camcorder
My JVC GR-D77OU Mini DV Digital Camcorder is giving me the next messages: eject en reinsert tape. unit in safeguard mode. After ejectirn and reinserting the video tape it still does the samething. I have...
Remove the battery and or the power supply (plug), leave it out for a few minutes, then reattach. This should solve your problem.
Let me know if this helps....
Jan 03, 2009 | JVC GR-D370 Mini DV Digital Camcorder
JVC Comcorder in a safemode
my jvc gr-d91u is in the safe mode. it will not eject the tape or it will not record. how do i fix this problem? Please help me out kingb256@yahoo.com
Jun 26, 2008 | JVC GR-D50 Mini DV Digital Camcorder
Lost power cord
See the links below for the part you are looking for.
A/C Adapter (plugs into camera)
Battery Charger (charges battery without camera)
Mar 05, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Jvc digital video camera mini dv gr-d244u
I have had the same problem...usually had success by taking off the battery, putting it back on, turning the power off and on, etc.  It has always gone back in eventually.  I also tried re-charging the battery and replacing.  Could this be an old battery problem?  Mine is 4.5 years old.
Jan 06, 2008 | Panasonic Palmcorder PV-GS9 Mini DV...
Jvc digital video camera gr-d244u mini dv
My jvc gr d244u digitial camcorder it torn up. when i go to eject the tape and it pops out it want retract it back in. what can i do to fix this problem.
Jan 04, 2008 | JVC GR-D244 DV Digital Camcorder
Cameras Logo
100 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
