Ram upgrade on Sony Viao PCVRS420
Hi
I want to upgrade the ram on my machine but I keep on getting conflicting information. The box has a max memory capacity of 2GB and 4 slots for RAM sticks. Can I upgrade to 2GB by using 2 x 1GB PC2700 RAM sticks or do I have to use 4 x 512 MB PC2700 RAM sticks? The crucial website (crucial.com) lists 2 x 1GB as being guaranteed compatable but other sites list as 512 MB max. Really confused and would appreciate help.
  • 6,487 Answers
You can use even 1 stick of 2GIG of RAM or 2 X 1GIG of RAM or any combination will do for as long it will just be a max of 2GIG since that's the max support of your motherboard....
Posted on Oct 15, 2008
    Genius:
  • 1,124 Answers
Either way.
But you have to be sure to get the right memory.
1Gigabyte Module for Sony VAIO PCV-RS420
RAM type DDR DIMM
Form factor 2.5 Volts, Proprietary Design
Storage capacity 1 GB
Technology DDR DIMM
Access time PC2700 (333 MHz)
Slot(s) required 1
Data integrity check non-Registered, non-ECC
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
How much ram can i upgrade my compaq presario? I keep getting conflicting info. The tech at Office Depot said I was maxed out 2Gigs and upgrading any more would shut it down. But I'm reading forums...
One good and easy way to find out for sure how much RAM your computer can hold is to go to WWW.CRUCIAL.COM and run their SCAN MY COMPUTER feature.
This handy utility will scan your hardware configuration and tell you exactly how much RAM you currently have installed and what type it is.
It will also tell you how many RAM slots are fitted on your motherboard and what the maximum memory capacity is for each slot and the total capacity for that motherboard.
If your computer does have room to add more RAM, it will provide you with specific recommendations as to exactly what type and size of RAM stick to get to maximize the memory capacity and performance of your computer.
I hope that was helpful to you, good luck.
Joe.
Nov 05, 2011 | HP Compaq Presario SR5350F Desktop PC...
Can I do a memory upgrade on Sony VGC -LS 37E?
the specs for your computer, it states that it is equipped with 2gb of memory 2x1gb and max at 2gb, so I doubt that any higher memory upgrade installed would work, or else it would cause your system to crash or even damage it.
Jan 24, 2011 | Sony VAIO® VGC-LS37E PC Desktop
Can i put ram from packard bell easynote into an acer aspire 5315.thanks
RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support)Max RAM: Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) This is the kind of memory you need, no matters the branch
Dec 21, 2010 | Acer Aspire 5315 Notebook
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Hi, my Asus a8m has 512 mb of ram. I'm considering buying a macbook, but wondering if it would be worth upgrading to 1 or 2 mb of ram and having a professional 'clean out' my asus. Would it be worth it?...
max supported memory is 2GB (2x1GB sticks replacing your current memory). Yes, it'd be worth it to add more memory of you were keeping the machine, otherwise restore it to original configuration and sell it "as is". Don't get a professional, just used your ASUSes restore option to set it back to factory configuration.
Feb 07, 2010 | ASUS A8M Notebook
How to upgrade RAM memory what to buy and is anything else be upgraded before this
It is a very simple thing to upgrade your Ram which is a great idea since you have only 512 MB. I suggest you buy at least 1 GB or more if you can afford it. Go to the link I am posting and let them scan your computer. They will tell you exactly what you can install and the price. This is a reputable site I use all the time. This will require a download of the scanner tool which is perfectly safe. http://www.crucial.com/
Nov 05, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Can the memory be upgraded (increased) from the basic (factory installed) 512mb on the Sony PCV-W300G?
Hi there.
As far as i know you can upgrade the RAM to 2GB, 2x1GB 184pin PC2100 DDR DIMM Desktop RAM modules is what it can take.
Thanks for choosing FixYa!!
May 28, 2009 | Sony VAIO PCV-W300G PC Desktop
IBM thinkpad g40..i want to upgrade
To upgrade your CD drive there is a screw on the bottom of the machine that holds it in place. Remove this screw and the drive will slide out. I buy most drives for my customers and shop from Ebay. I've found that there are some very good vendors with good prices and warranties there. Now for the memory. The memory you need for your machine is PC2100, and 1g is the max. I mainly use Kingston or Infiniton. Both of these are good chips, and there are other good chips out there. I suggest that you use two 512mb chips that are the same make. I've found that sometimes two different chips will create a conflict with each other. The memory is located under a panel on the bottom of the machine. For memory I use pricewatch.com If you have any other questions please fell free to ask.
Jul 21, 2008 | IBM ThinkPad G40 Notebook
Need to add ram
The RAM is behind the system cover, and rather then try and explain things, as I seem to have a hard time doing with others, I will direct you to your user manual, it has instructions on upgrading the RAM.
If you've misplaced, or did not receive, your manual, it is available from the Sony Website, and a direct link to product home page is http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCVW600G
Click on the VIAO User's Manual, it will pop open a new window and the manual will take a few mins to load. Be sure you have Adobe Reader installed to view the file as well. You will find a section marked 'Upgrading your VIAO' with a set of specific instructions to upgrade and change your RAM.
Hope this helps!
-Backu
Jan 15, 2008 | Sony PCV-W600GKIT1 PC Desktop
Computers & Internet Logo
385 people viewed this question
David Payne
David Payne
