Question about HP LaserJet 3055 All-In-One Printer
HP LJ 3055 Toolbox Not Connected
I access the Laserjet 3055 AIO through a router in a network configuration. I'm able to print fine, however, when I try to get to the Toolbox, error message says "cannot connect to the device" and advises me to check connections. How can connection be working for printing but not toolbox?
  • 1 more comment
  • SaveWetland Oct 16, 2008
    Hi Bob,
    Thanks for venturing a guess given my scanty info. The subject computer is used within a home, not office, network. I downloaded the complete software package myself and believe it's all installed. In fact, when I go to Programs, the Toolbox appears as a component under the LJ 3055.
    Bob,
    I had written HP tech support concurrently and they came back with suggesting a reinstallation as well, which I was hoping to avoid. This will be my fourth reinstallation in as many weeks and the software's finickiness (an excellent description) is getting old. Moreover, after the last install, I had deleted the software I downloaded, a hefty file which I will now have to download again (ugh!).
    In its directions, tech support advised me to run Scrubber utility between uninstalling old stuff and reinstalling the software anew, which I had not done previously owing to ignorance. In fairness to HP, the finickiness is probably partly attributable to poor communications of scenarios and landmines.
    Your idea of configuring as a local printer while using a network port sounds intriguing, though I'm unsure of what it all means and how to make it happen. In any event, I appreciate your interest and helps.
    SW
  • SaveWetland Nov 20, 2008
    wylertay,
    Using every precaution, I reloaded the software and in the process got rid of the connection issue. As an aside, in reloading the software, I used the CD instead of downloading from HP's web site after reading elsewhere that the downloaded copy was more error prone.
    Had my problem not been solved, I think the troubleshooting steps included in your link would have been helpful, though error message referenced was not identical to mine. Thanks for posting it.
    SW
It sounds like a Firewall configuration issue:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=378056&prodTypeId=18972&objectID=c00192126
Ports 5225-5226 need to be open on the router and on your machine.
Posted on Nov 13, 2008
    Scholar:
  • 47 Answers
Hi SaveWetland!
Without being able to see your machine, I'm going to make an educated guess at your problem. Many times, when a printer is used over a network, only the printer driver itself is actually installed on each user's machine. Utilities, such as the HP Toolbox, may not be installed. If your network administrator allows it, you could download and install the complete printer software package off the HP website, which I'm highly confident would solve your issue. If not, I'd advise you to contact your IT person and have him/her install the complete package for you.
Good luck and I hope this helps. Please let me know, and also provide a rating if you deem it appropriate.
Bob
Posted on Oct 15, 2008
  • Robert Horton
    Robert Horton Oct 16, 2008
    Hi again!
    Well, that is weird. Do you have a computer hooked up directly to the printer, and if so can you access the toolbox through that computer? If so, I guess that would be a workaround.
    HP printer software is the most finicky on the market, in my humble opinion. I've worked with a lot of printers, and the HP software sometimes seems to have a mind of its own -- and even their high level tech support often gets stumped! When you installed the printer, did you install it as a network printer or did you by chance install it as a local printer, telling the printer to use the network port to print through? If you don't know what I'm talking about here, don't worry about it; it's just an alternate way of connecting a network printer that makes sure that the entire software package was installed.
    If it were me, I'd completely un-install all the HP software for the printer and try again. If you know how to configure the printer whereby it is used across a network but configured as a local printer that uses a network port, I'd try that, as that would assure that all the SW is being installed. If not, I'd just try again on the "normal" network install. If all else fails, you could try HP tech support. I've had good experience with them on the few occasions that I've needed them. Thanks for the rating, and if this fixes it for you, I'd appreciate another rating (if the system lets you; I'm still pretty new around here!).
    Bob
How do I fix "Not
This error indicates that the scanner has not been linked to the desktop of the attached PC. Either launch the HP Toolbox and follow the scanner setup instructions, or if you do not have toolbox installed you will need to install the printer from the original disks that came with it.
Mar 29, 2011 | HP LaserJet 3055 All-In-One Printer
How to take configuration test page in HP businessjet 1000 series printer
Found this in a HP support forum
You'll need to load the entire 'HP LaserJet 1000 Printing Software Solution' so you'll have access to the toolbox. Once you've got the toolbox installed you'll be able to print a configuration page and see the page count.
Here's a link that should get you to the software downloads:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?locale=en_US&pnameOID=45675&taskId=135&prodTypeId=18972&prodSeriesId=45674&submit.y=0&submit.x=0
Original Post:
http://h30499.www3.hp.com/t5/Printers-LaserJet/Laserjet-1000-page-count/m-p/324372
Oct 20, 2010 | HP LaserJet 1000 Printer
I get an error message when I scan. It says Error
ISSUE: The error Waiting for PC is displayed on the control panel when scanning, using the Start Scanbutton on the control panel. The user will also notice a Not Setup on PC error when pressing theScan to … button. Note that scan from the PC works properly without an error. SOLUTION: The probable causes for this issue are listed below:
  • Firewall denying access to PC
  • Device polling not enabled
  • The scan to function is not enabled in the HP Toolbox
  • The destination has not been added to the Scan to button from HP toolbox
  • The HP Toolbox is losing the scan to destination
How to troubleshoot this issue:
  1. PC protection software such as firewall software may prohibit proper communication between HP AiO products and Toolbox and scanning software. Firewalls may need to be reconfigured to allow Toolbox to communicate with the AiO. The Toolbox software is similar to Microsoft Outlook and Internet Explorer in this way. Temporarily disabling firewall software may be helpful in determining if it needs to be reconfigured for Toolbox to operate properly. Please contact your third party firewall software vendor if assistance is needed to reconfigure the firewall. The following third party support Web sites may be useful:
  2. When Device Polling is turned off, the Alerts and the Scan to e-mail or folder options in the HP Toolbox are disabled, and the START SCAN function on the HP LaserJet AiO product control panel is also turned off. CLICK HERE for instructions on how to turn on Device polling.
  3. To program the device SCAN TO ... button, view the device settings. Open the HP Toolbox and click the Scan to tab. For more information, CLICK HERE to view the document titled HP Color LaserJet 2840 AiO Series Products - How to use "Scan To E-mail" or "Scan to Folder" from the Device
  4. The User loses the folder when choosing to save scanned files under the Scan to Folderoption of the Scan to Tab. The User also may lose the email settings under the Scan to Emailoption of the Scan to Tab. The User restarts the toolbox and it works for some time and the problem repeats again. Perform the following in the order listed to resolve this issue:
    1. Run the Fix Scan Utility and see if it resolves the problem. Click here for the Fix Scan Utility at http://www.hp.com If not, proceed to the next step.
    2. Check the firmware version and make sure that it is up to date. print a configuration page to see what the current firmware version is. Compare it to the latest version offered on HP.com Click here for HP.com at http://www.hp.com . If it is not the latest version then upgrade it to the latest version available on the web.
    3. Download the Software Update Version 3.0 from HP.com and install it. Click here to download the software update from http://www.hp.com
  5. For Toolbox Reset Persistent Data issues, CLICK HERE to view the document titled HP Color LaserJet 2800 All-in-One series - Toolbox Reset Persistent Data
  6. If the issue persists, uninstall and reinstall the printer software. CLICK HERE to view the document titled HP LaserJet 2820 and 2840 AiO Series Products - Uninstalling or Removing the Printing Software and Shared Components
Apr 07, 2010 | HP LaserJet 3015 All-In-One Printer
HP LASERJET 3055 Manual IP Address not saving
Try flashing the firmware: one of the fixes is this - (Improved IP address management of DHCP to Manual changes).  See link below. Firmware
Gerben People tend to evaluate events in light of their paradigm rather than evaluate their paradigm in light of events.
Sep 27, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Jul 05, 2008 | HP LaserJet 3055 All-In-One Printer
How to install Hp laserjet 3055
If the connection is ethernet. Print configuration from Printer.
Manually install printer.
Select computer is on local port
Local port to select is TCP/IP
then type in the network address to the printer.
Driver will still be inside computer.
Mar 03, 2008 | HP LaserJet 3055 All-In-One Printer
Plz help me am in trouble
Network Configuration page
NOTE The Network Configuration page is only available on the HP LaserJet p2015n,
HP LaserJet p215tn, and HP LaserJet p215nw printers.
A Network Configuration page prints whenever a printer configuration page is printed. You
can also print a Network Configuration page by pressing the network Reset button at the
back of the printer
The Network Configuration page provides information about the network configuration,
including the IP address, firmware revision, network statistics, protocol information, and so
on. The Network Configuration page automatically prints when you print a configuration
page from the control panel.
ENWW Printer information pages 37
Using the HP Toolbox
The HP Toolbox is a Web-based program that you can use for the following tasks:
● Check the printer status.
● Configure the printer settings.
● View troubleshooting information.
● View online documentation.
You can view the HP Toolbox when the printer is directly connected to your computer or
when you are using a supported network connection. You must have performed a complete
software installation to use the HP Toolbox.
NOTE You do not have to have Internet access to open and use the HP Toolbox. However, if you
click a link in the Other Links area, you must have Internet access in order to go to the site
associated with the link. See Other links for more information.
To install the HP Toolbox, you must install the TCP/IP protocol and the most recent version
of the Java™ Virtual Machine on the computer. You must also install the DOT4 protocol for
all USB connections, LPT connections for Windows 2000 and Windows XP, and LPT1
connections for Windows 98 S.E., Windows Me, and Windows NT 4.0. See the system
administrator or computer manufacturer's documentation for more information about
installing the TCP/IP protocol and the DOT4 protocol.
Jan 22, 2008 | HP LaserJet P2015dn Printer
Scan To Button is not working over Network PCs
I uninstalled the Norton Antivirus from my PC. Now it is working fine.
Jan 13, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 Won't Scan
Dears
My hp 3055 is working fine on the network bt problem is "SCAN TO" Button is not being configured with the PCs.It displays all the PC names bt not able to scan. it diplays an error "Unable to Connect".
can any body help me out of this matter
Dec 27, 2007 | HP LaserJet 3055 All-In-One Printer
Can not network print
had the same problem, when I switched to a new router. It was possible to get around the problem by manually including the officejet in my 'lmhosts' file in windows, before installing the printer driver.
Regards,
Ian
Nov 20, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
1,159 people viewed this question
Seeker5211
Seeker5211
