Question about Amana NDE2330AY Electric Dryer
Dryer won't start
I was using the dryer and opened the door to untangle the sheets, shut the door and it started. next time i went in i noticed a hot burning smell and the dryer was off. I tried to start it again and it doesn't do anything. I live in the boondocks with no repair men so i am on my own! thanks! denene
  • katayatz Oct 15, 2008
    well actually the dryer won't start at all. no turning or heating. does this change your solution? thanks for the quick replies!
    Novelist:
  • 130 Answers
Sounds like you have a bunt wire someplace within its cabling. Usually, there are a couple of screws underneath the top of the dryer. Naturally, make sure that the electrical plug is disconnected.
Once the screws are removed, you may lift up the top... check for binding issues and remove any additional screws that may be affixing the top to the shell. Once open, you will probably find a wire that is burnt and is probably hanging by itself. You can make a more secure connection with this wire once you locate where it goes [kind of straight forward].
Does not sound like a heater coil since the unit would still turn on but simply won't heat.
Posted on Oct 15, 2008
  • mdscntst Oct 15, 2008
    easier to check the circuit breaker for the dryer [double pole breaker since it is 220VAC]. Switch it off, back on and check the dryer. More than likely it will still be a burnt wire due to what you have explained in your post.
    Kind of like any problem in life, the more information you provide, the easier it is for someone to be able to troubleshoot the problem to its entirety.
SOUNDS LIKE THE HEATING ELEMENT.
Samsung dryer DV42h5000ew won't power up
Kenmore Whirlpool Dryer Won Start Easy Fix
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Jan 02, 2017 | Samsung Dryers
It will not turn on. When I unplug it and plug it back in the start light is constantly blinking. I checked for error codes and the 4 lights blink 9 times and the start button blinks 14 times.
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Nov 09, 2015 | Kenmore Dryers
How can I fix my HE4 Gas dyer it will not start
Jun 21, 2014 | Kenmore 659 Electric Dryer
Won't work. No service code.
the first things to check is the door switch,open the door and push in the switch,if it doesn\'t click when pushed in the switch is bad,next thing to check is the belt,on some models there\'s a switch on the pulley assy. if there isn\'t any tension on the pulley the dryer won\'t start.if you need more help i need the model number off of the dryer,open the door and lolook around the opening where you put the clothes in and you\'ll see a tag with the model number,if the dryer hasn\'t been taken apart and cleaned out the thermal fuse could have popped,if the dryer gets to hot inside from a blocked vent line or the duct that the lint filter slides into is blocked the fuse will pop and it\'s non resetable.
Mar 18, 2013 | Kenmore Dryers
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Electric dryer was running fine.had towels in there an opened door to check how wet an noticed it was really hot inside an then closed it an went to pull knob outward to start the dryer again an it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
Heating element won't stay hot.
Hello vsjant3,
I assume you cheated out the door interlock switch when running your test. If you did not, then the dryer will shut off when the door is open as part of the safety interlock system. If you did cheat it out and the element shut off after about 20 seconds, then you may have a problem with one of the temp sensors. When an overtemp condition occurrs, it disables power to the heater and it will shut off.. Other considerations are the wiring to the heater.. if you had a poorly tightened heater wire that was ok when first started and cold but when hot and passing current opened, that would also exibit the same symptoms. If I were a betting man, I'd say you probably have a bad temp switch. You can measure them with an ohm meter ( dryer unplugged of course).. or simply jumper the wires together to bypass one to see if it is the fault. Make sure you replace a bad sensor and do not leave it bypassed or you risk fire.
Here is a link to the wiring diaghram of your dryer.. http://www.pcappliancerepair.com/model-display.php
Hope that helps,,
Regards,
Rick
Jan 08, 2009 | Maytag PYE2300AY Electric Dryer
Whirlpool Electric Dryer
More than likely the belt for the drum or the door switch is faulty. What is the model of your whirpool?
Mar 05, 2008 | Dryers
Amana NDE2330AY Electric Dryer Logo
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
